@JurajNyiri, is this an expected behaviour with the latest version?
This error originated from a custom integration.
Logger: custom_components.tapo_control
Source: custom_components/tapo_control/__init__.py:189
Integration: Tapo: Cameras Control (documentation, issues)
First occurred: 17:08:54 (2 occurrences)
Last logged: 17:08:54
TEST
in the last update i read the information that it is recommended to disable the new SD sensors in record and log. For a HA noob like me: how can i do this? I canât find any hint in github repository or this forum (maybe donât find the right words for my search).
I found out how to set up recorder from the recorder help. But what are the names/groups (it is a entity, domain,⌠which one) i have to use for taposd sensor?
I have a c310 where the motion alarm has stopped working. It only shows âunavailable.â
It has worked fine before.
I have restarted both the camera and home assistant.
Check your logs, check your entity under the integration, Just Posting
âIt Dont Workâ !!!
Sounds like a âGuessing Contestâ , im sure you can do better, if not, then read the Welcome-Post, an get ideas to what you can do to help us help you
I have a C320WS. It can detect motion, people, and vehicles. It seems that HA can only see the motion detection. Is it possible to create an automation on just the person and vehicle but not the motion? I can troubleshoot further but wanted to confirm that it is possible.
hello, i have 3 C210 installed in my home and i have an automation that:
when someone of the family enters home, moves the cameras to the âprivacyâ preset and turns on privacy mode
when the last family member exits home, disables privacy mode and moves the cameras to the ânormalâ preset so we can check what our cats do
It works. But it works since i put a lot of delays (something like 10 seconds for each one) between each preset selection / privacy mode toggle.
Otherwise, i get errors on errors.
My question is if i can use something different than a ugly delay to check when the camera is ready to accept a new commandâŚ
I have integrated Tapo cameras successfully, thank you very much.
But I have a question: how can I get the video recordings to be saved in my NFS folder that I have added to HA?
Do I have to add something to the yaml configuration file?
I donât have an sd card and I want everything to be saved on my server with NFS.
You will need to buy SD card allow recordings and then follow readme for sync (it is a sync, recordings will get deleted once no longer present on SD card). In order to do it without you are looking for NVR solution which Hass is not (look into frigate).
Thank you for your quick response sir. It has saved me hours of frustration. I guess Iâll have to buy an SD card.
Or go for one of those NVR solutions like frigate but I donât want to complicate things and I want to keep everything simple so I guess it will be an SD Card.
