Hi, I am running hass on a raspberry pi and the latest core update 2024.10.2 broke the integration for me.
Logs below
Logger: homeassistant.loader
Source: loader.py:1067
First occurred: 12 October 2024 at 20:55:35 (2 occurrences)
Last logged: 12 October 2024 at 20:55:35
Unexpected exception importing component custom_components.tapo_control
File "/usr/src/homeassistant/homeassistant/loader.py", line 1067, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/tapo_control/__init__.py", line 54, in <module>
from .utils import (
File "/config/custom_components/tapo_control/utils.py", line 15, in <module>
from pytapo.media_stream.downloader import Downloader
SyntaxError: source code string cannot contain null bytes
Logger: homeassistant.setup
Source: setup.py:334
First occurred: 12 October 2024 at 20:55:35 (1 occurrences)
Setup failed for custom integration 'tapo_control': Unable to import component: Exception importing custom_components.tapo_control
File "/usr/src/homeassistant/homeassistant/loader.py", line 1007, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1078, in _get_component
raise ImportError(f"Exception importing {self.pkg_path}") from err
ImportError: Exception importing custom_components.tapo_control
File "/usr/src/homeassistant/homeassistant/setup.py", line 334, in _async_setup_component
component = await integration.async_get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1027, in async_get_component
self._component_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1019, in async_get_component
comp = self._get_component()
