It seems that after upgrading HA to 0.84.2 (and applying the latest hass-variables fix), variables with "restore": true
don’t preserve their state after HA restart anymore. I have opened a new bug: https://github.com/rogro82/hass-variables/issues/11.
Hi i just upgraded to 0.84.2 and updated the variable.py. Still getting errors.
2018-12-16 11:58:36 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.variable. Make sure all dependencies are installed
File "/usr/src/app/homeassistant/loader.py", line 92, in get_component
module = importlib.import_module(path)
File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/variable.py", line 14, in <module>
from homeassistant.helpers.restore_state import async_get_last_state
ImportError: cannot import name 'async_get_last_state'
2018-12-16 11:58:36 ERROR (MainThread) [homeassistant.loader] Unable to find component variable
Any help please…
I have the same problem. Hope having a solution soon
Have a look here
Are you sure you updated to the latest variable.py correctly because your log shows an import from the previous version:
Line 14 should be:
Thank you
Hi there, when I tried to install the custom component HA complains on startup:
2018-12-20 15:43:36 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.variable. Make sure all dependencies are installed
File “/home/homeassistant/.pyenv/versions/3.6.3/envs/homeassistant-3.6.3/lib/python3.6/site-packages/homeassistant/loader.py”, line 92, in get_component
File “/home/homeassistant/.pyenv/versions/3.6.3/lib/python3.6/importlib/init.py”, line 126, in import_module
File “”, line 994, in _gcd_import
File “”, line 971, in _find_and_load
File “”, line 955, in _find_and_load_unlocked
File “”, line 665, in _load_unlocked
File “”, line 678, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/home/homeassistant/.homeassistant/custom_components/variable.py”, line 14, in
from homeassistant.helpers.restore_state import RestoreEntity
ImportError: cannot import name ‘RestoreEntity’
Do I need to install the dependency?
You need to run 0.84.x for the latest version of this component.
Ah thanks… that solved my problem!
Just pushed an update to github which should fix this issue.
HI @rogro82
would you care to make this card ‘trackable’ by the custom_component updater card please? https://github.com/custom-cards/tracker-card
would make updating you CC so much more comfortable .
thanks for considering
could it be that the restore state functionality of the Variable component is somehow compromised lately?
On each restart my variables lose their history, while I have enabled restore:
variable:
solar_angle_outside_light:
value: 'Not set'
restore: true
attributes:
icon: mdi:format-rotate-90
virtual_light_outside_light:
value: 'Not set'
restore: true
attributes:
icon: mdi:brightness-5
I did move from the default recorder to MariaDB lately but still have variable included in the domains in recorder,yaml. HA 84.3
Do you use the latest version of hass-variables? This issue has been fixed already - see https://github.com/rogro82/hass-variables/issues/11 .
yes I have dl’d that version, and think (…) it worked al right.
Unfortunately this component hasn’t got a version number in the file, and can’t be tracked by the updater card, but I’ve secured it manually
Is there a way to pass multiple values to this? For example, if I wanted to use the attributes (I use the motion example, works fine and I understand it’s “rolling” the values forward, so to speak) to hold device_tracker information? I’m not really clear on how I can do this with attribute template with perhaps value template? IE:
attributes_template: >
"latitude": "{{ ??? }}",
"longitude": "{{ ??? }}"
Not sure how to populate this using states.attributes.device_tracker.attributes.latitude/longitude (for example.)
EDIT: Solved it. Now to make it more template-ish as I do passing entity-id to the python script.
chris_gps:
value: 'Unknown'
restore: false
attributes:
latitude: 0
longitude: 0
- platform: state
entity_id: device_tracker.homeassistant_chris
- service: python_script.calc_gps_coords
data_template:
entity_id: '{{ trigger.entity_id }}'
zone_entity: 'None'
zone_data: 'None'
- service: variable.set_variable
variable: chris_gps
"latitude": "{{ states.device_tracker.homeassistant_chris.attributes.latitude }}",
"longitude": "{{ states.device_tracker.homeassistant_chris.attributes.longitude }}"
@rogro82 is it possible to manipulate variables from python script? I keep running into a roadblock (which I’ve googled around) that at first was due to using direct assignment, ie:
foo = foo # object does not support item or slice assignment
foo += foo
Which I thought I solved but now I’m running into an issue trying to use hass.states.set() which produces this error:
Line 72: Augmented assignment of object items and slices is not allowed.
Just wanted to share that I used this to track my daily rainfall. Since my oregon scientific pcr800 rain gauge only track cumulative rain from last reset as a standard. Perhaps it of use for someone else. replace “sensor.rain_total” with your own cumulative rain sensor.
configuration.yaml
sensors:
rain_daily:
value_template: ‘{%- if not (is_state(“sensor.rain_total”,“unknown”) or is_state(“variable.rain_cum_prior”,“unknown”) )-%} {{ ((states.sensor.rain_total.state | float) - (states.variable.rain_cum_prior.state | float)) | max (0) | round(1) }} {%- endif -%}’
friendly_name: ‘Rain Today’
unit_of_measurement: ‘mm’variable:
rain_cum_prior:
value: ‘unknown’
rain_daily_autmation.yaml
alias: ‘record cumulative rain to midnight’
- platform: time
at: “00:00:01”
variable: rain_cum_prior
value_template: ‘{{states.sensor.rain_total.state}}’
This script adds 1 to the variable corresponding to the minute, and then check if it is equal to 60, if true assign zero the variable.
This work for me.
xxx_sc_exalarmeduplo2_alarm1_on_minute_schedule:
variable: xxx_vb_exalarmeduplo2_alarm1_on_minute_schedule
value_template: "{{ (variable.state | int) + 1 }}"
- service: persistent_notification.create
data_template:
message: "{{ states.variable.xxx_vb_exalarmeduplo2_alarm1_on_minute_schedule.state }}"
title: "Minute test"
- condition: state
entity_id: variable.xxx_vb_exalarmeduplo2_alarm1_on_minute_schedule
state: '60'
value_template: "0"
I am restructuring my configuration to make it more manageable and run into this issue with variables:
When I put variables directly below the variable:
line, properly indented and all, it works fine.
But what I want to do is:
variable: !include_dir_list ../variables
And then have separate files for each variable in the mentioned directory, for example, in …/variables sits a file named house_state.yaml
with these contents:
house_state:
value: 'Unknown'
restore: true
attributes:
icon: mdi:home-heart
The error I see in the build log is then:
Testing configuration at /builds/[redacted]/hass-config/.
Failed config
homeassistant.packages.variable.variable:
- Package variable setup failed. Component variable cannot be merged. Expected a dict.
- variable: ?
- house_state: [source /builds/[redacted]/hass-config/./components/packages/../variables/house_state.yaml:4]
attributes: [source /builds/[redacted]/hass-config/./components/packages/../variables/house_state.yaml:7]
restore: True
value: Unknown
Not sure what that error means? Does the variable component not support the !include directives, or am I missing something here?
Using packages with variable here too. No dash in front of variable.
# Variables
variable:
value: 'Not set'
restore: true
attributes:
using
homeasistant:
packages: !include_dir_named packages
