Great feedback Taz. I am moving to a new house in 3 weeks, and first there I will get my Cameras in their final positions, so I look forward to take some of your learnings and implement them.
/B
Itâs the least I can do after all your efforts on this component.
Hopefully Iâll be able to refine my filters further, and Iâll update if I do.
Version 0.1.2
This will most likely be the last release for a few weeks, as I am moving to a new house - I have tons of new devices that I will be installing - looking forward to that
Plans for the future is to add code so that this component can be installed from the Integrations page, thus avoiding editing of configuration.yaml
. The work has startet, but the next few weeks I will be busy with work, and preparing the move.
If you find any errors, I will try to fix them ASAP.
What is changed in V0.1.2:
New: Added a new Switch component. If enabled the system will create a switch for each camera, that can enable or disable the motion recording. You can already do this by running the services
camera.enable_motion_detection
andcamera.disable_motion_detection
but this gives a convenient way to do it from the Frontend. See the Github README.md for setup instructions. -
Change: Cleaned up some unused code
Thanks for keeping up the good work
Goâ flytning og pøj pøj med det nye hus (danish: I wish you a good move and the best of luck with your new house )
Thank you for this. I am now using it in my HA setup with Protect.
Good luck with the house move - and thanks for the hard work.
Part #2 of my refining of driveway camera notifications.
To cope with passing foot traffic on the path / shadows from cars during daytime, and headlights at night all triggering my notifications Iâve:
- added some basic tracking of the length of the motion events using an input_datetime
- tightened up the motion_score filtering in my automations
This lets me only notify users based on a high motion score and / or length of motion event (I have a stealthy postman who only scores 40 when delivering to the house but takes over 10 seconds to do so, making him an ideal test scenario ).
Hopefully the automations are self-explanatory.
# record start of driveway motion
- id: unifiprotect_driveway_motion_started
alias: "Driveway Motion Started"
platform: state
entity_id: binary_sensor.unifiprotect_motion_driveway
to: "on"
condition: []
- service: input_datetime.set_datetime
data_template:
entity_id: input_datetime.driveway_motion_started
time: "{{ (as_timestamp(now()) | timestamp_custom('%H:%M:%S', true)) }}"
date: "{{ (as_timestamp(now()) | timestamp_custom('%Y-%m-%d', true)) }}"
# movement on driveway signalled via unifiprotect - filtered by motion score attribute
# daylight only, minimum score 60
- id: unifiprotect_driveway_motion_notification
alias: "Driveway Motion Detected"
hide_entity: True
platform: state
to: "on"
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.driveway_notify
state: "on"
- condition: state
entity_id: input_boolean.holiday_mode
state: "off"
- condition: state
entity_id: input_boolean.notify_via_sms
state: "off"
- condition: template
value_template: "{{ ((is_state('sun.sun', 'above_horizon') and (state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') | int >= 60))) }}"
- service: camera.snapshot
data_template:
entity_id: camera.driveway
filename: >
{% if state_attr('automation.driveway_motion_detected', 'last_triggered') != None %}
{{ states('sensor.snapshot_local') }}driveway_{{ now().strftime('%Y%m%d%H%M') }}.jpg
{% else %}
{{ states('sensor.snapshot_local') }}driveway_{{ as_timestamp(state_attr('automation.driveway_motion_detected', 'last_triggered')) | timestamp_custom('%Y%m%d%H%M%S%f') }}.jpg
{% endif %}
- service: notify.all_mobile
data_template:
title: "Driveway Alert"
message: "Motion detected at {{ now().strftime('%H:%M') }}. Score: {{ state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') }}"
android:
notification:
image: >
{{ states('sensor.snapshot_remote') }}driveway_{{ now().strftime('%Y%m%d%H%M') }}.jpg
{% else %}
{{ states('sensor.snapshot_remote') }}driveway_{{ as_timestamp(state_attr('automation.driveway_motion_detected', 'last_triggered')) | timestamp_custom('%Y%m%d%H%M%S%f') }}.jpg
{% endif %}
# long movement with lower score on driveway signalled via unifiprotect - filtered by motion score attribute and length
# minimum length 10 seconds (+/- 3 seconds scan time) and score >= 10 (but less than 60 reporting)
# daylight: score >= 10 and < 60 (ie. not already reported when trigger 'on'
# night: score >= 50 (no night trigger due to security lights being triggered)
- id: unifiprotect_driveway_long_motion_notification
alias: "Driveway Long Motion Detected"
hide_entity: True
platform: state
to: "off"
condition:
condition: and
conditions:
- condition: state
state: "on"
- condition: state
state: "off"
- condition: state
state: "off"
value_template: "{{ ((is_state('sun.sun', 'above_horizon') and (state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') | int < 60))) or (is_state('sun.sun', 'below_horizon')) }}"
value_template: >
{{ ((is_state('sun.sun', 'above_horizon') and (state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') | int >= 10)) or
(is_state('sun.sun', 'below_horizon') and (state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') | int >= 50))) }}
value_template: "{{ (as_timestamp(now()) - as_timestamp(states('input_datetime.driveway_motion_started')) | int >= 10) }}"
- service: unifiprotect.save_thumbnail_image
data_template:
filename: >
{% if state_attr('automation.driveway_long_motion_detected', 'last_triggered') != None %}
{% else %}
{{ states('sensor.snapshot_local') }}driveway_{{ as_timestamp(state_attr('automation.driveway_long_motion_detected', 'last_triggered')) | timestamp_custom('%Y%m%d%H%M%S%f') }}.jpg
{% endif %}
data_template:
message: >
Motion detected at {{ as_timestamp(states('input_datetime.driveway_motion_started')) | timestamp_custom('%H:%M') }}.
Score: {{ state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') }}, Length: {{ (as_timestamp(now()) - as_timestamp(states('input_datetime.driveway_motion_started'))) | int }}s
android:
notification:
image: >
{% else %}
{{ states('sensor.snapshot_remote') }}driveway_{{ as_timestamp(state_attr('automation.driveway_long_motion_detected' ,'last_triggered')) | timestamp_custom('%Y%m%d%H%M%S%f') }}.jpg
{% endif %}
is it normal that itâs off sync? if i wave my arms in front my camera it can take up to 15 sec before it shows up on my HA
If you read previous entries in this thread, this seems to be normal when using stream. I donât believe this is specific to this component. I am not sure how really to optimize this for now. I believe the delay you see is dependent on the HW Home Assistent is running on, nut even with the powerfull platform I run on, I see this delay when using an RTSP stream - just not 15 sec.
New Release V0.1.3
Between putting everything in to boxes and preparing for the move, I found a little time to make some changes.
As per discussion on Github, I made some changes to the component. The prime purpose of this, is to make it possible to set both recording modes (Always and Motion) from Home Assistant. Please see below for how this is done. Note that there is a breaking change on the Switch component, where there is a name change on the previous switch.
Ideally I would have made a Dropdown box, from where you could select the recording mode (Like the input_select
component), but at the moment I cannot figure out how to do that, so I made two Switches instead.
Breaking Change The Switch component has changed due to implementation of a new Switch. The previous switch name
switch.unifiprotect_recording_[camera Name]
does no longer exist. It has been replaced by two new switchesswitch.unifiprotect_record_motion_[Camera Name]
andswitch.unifiprotect_record_always_[Camera Name]
The first sets recording mode to motion and the second sets recording mode to always. They are mutually exclusive, so turning on one, will turn off the other. -
New: Added new Service
unifiprotect.set_recording_mode
. When called, this service sets the recording mode for the chosen camera to the specified recording_mode. The value can bealways
,motion
ornever
. The mode always, will let the camera record all the time, motion is the usual motion recording and never disables all recording. - Change: Cleaned up some unused code
Mmm I have a script, which I run to turn recording to âalwaysâ. Only fires the first camera, camera.garden
sequence:
service: unifiprotect.set_recording_mode
entity_id:
- camera.garden
- camera.front
- camera.driveway
recording_mode: always
Have I done something wrong?
You are close. In order to perform the same action on several entities, you need to create a call to the service pr camera. So you script should look like:
sequence:
- data:
entity_id: camera.garden
- data:
entity_id: camera.front
- data:
I think I have seen a smarter way to do that, but I canât remember right now. But the above works.
Awesome component, I was able to remove all my generic camara streams and just use this. Running all the latest versions when I attempt to add the new switch option I get the following error when checking the config. When I disable the switch configuration the config validates fine.
Platform error switch.unifiprotect - cannot import name âTYPE_RECORD_ALLWAYSâ from âcustom_components.unifiprotectâ (/config/custom_components/unifiprotect/init.py)
Hi Jared,
Glad to hear that it is usefull. With regards to the error you see, can you tell me how you installed it? Manually or via HACS?
I was just checking my own installation, with the latest V0.1.3, and here I donât get that error.
If you installed via HACS, could you try to remove it, and then install again. Just to make sure you donât have something old in cache. Remember to restart Home Assistant.
Let me know how this goes.
Installed via HACS.
I uninstalled and reinstalled and everything works now, should have tried the old ârebootâ prior to posting
Thanks again, good luck with the move!
Hi @briis, Iâm getting the following exception when I try to run this custom component via HACS on homeassistant 105.0 as a container:
Error during setup of component unifiprotect
File â/usr/src/homeassistant/homeassistant/setup.pyâ, line 174, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File â/usr/local/lib/python3.7/concurrent/futures/thread.pyâ, line 57, in run
File â/config/custom_components/unifiprotect/init.pyâ, line 111, in setup
host, port, username, password, use_ssl, minimum_score
File â/config/custom_components/unifiprotect/unifi_protect_server.pyâ, line 44, in init
self._api_auth_bearer_token = self._get_api_auth_bearer_token()
File â/config/custom_components/unifiprotect/unifi_protect_server.pyâ, line 74, in _get_api_auth_bearer_token
raise NvrError(âRequest failed: %sâ % response.status)
AttributeError: âResponseâ object has no attribute âstatusâ
Any idea on why this is happening?
Iâm using a UDM Pro to run UniFi Protect, so I wonder if thereâs something weird with how Protect runs on there. My Protect version is 1.14.7
The UDMP has introduced the new UnifiOS operating system, and that uses a new Authentication which this component does not support. As UDMP is currently only shipped in the US, and I am based in Europe I have no access to this, so it is not possible to directly support it.
BUT the good news is that @Silvenga has made a proxy that you can use to get authentication working. Please have a look here for setup instructions
Any suggestions for reducing the amount of notifications you get with fog? I have the usual problem with UniFi Protect, it was foggy overnight and I was swamped with 300+ notifications. I guess I could put a condition on it not being foggy but has anyone got any cooler suggestions?
Here is my code already (stolen from some code above)
#Notify When Motion Detected on Driveway
alias: 'Driveway Motion Notification'
initial_state: true
- platform: state
to: 'on'
condition:
condition: and
conditions:
- condition: template # only notify once every 2 minute(s) at most
value_template: "{{ ( as_timestamp(now()) - as_timestamp(state_attr('automation.driveway_motion_notification', 'last_triggered')) |int(0) ) > 120 }}"
- condition: template # notify differently with sun is up or down
value_template: >
{{ ((is_state('sun.sun', 'above_horizon') and (state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') | int >= 60)) or
(is_state('sun.sun', 'below_horizon') and (state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') | int >= 40))) }}
- condition: or
conditions:
- condition: state #check someone is at home
entity_id: input_boolean.family_home
state: 'off'
- condition: state # check bedtime
entity_id: input_boolean.bedtime
state: 'on'
filename: /config/tmp/driveway.jpg
- delay: 00:00:05
- service: notify.telegram
message: "Driveway motion detected at {{ now().strftime('%H:%M') }}. Score: {{ state_attr('binary_sensor.unifiprotect_motion_driveway', 'motion_score') }}"
title: Send Unifi image
message: "Unifi motion detected"
photo:
- file: /config/tmp/driveway.jpg
# caption: Driveway motion detected
I might not have the best solution, but here is at least what I did.
I was having so many issues setting the motion detection on these cameras, especially because it is not possible to filter on objects (not to my knowledge). So I got these Xiaomi sensors, which are placed pretty close to the cameras. When both Sensor and Camera is Triggered it then fires a Notification. That has brought down the number of Notifications dramatically. I have tested it, since I record always and it actually seems throughout a day, I only get Notifications when there actually is movement by a car / person.
Finnaly I have tweaken my automation, so it starts a timer and then it asks for a picture every 20th second, while the motion sensors are still active. When the motion detectors switches to off, the timers stops and reset.
Maybe it doesnât make sense, but at least it works very well for me
Saw this and immediately had to install it! My Unifi Protect system now feels as though part of my automation system! No motion in the basement, turn off the lights and wall heater! No need to buy more Aqara Motion sensors or dig my heels into the Frigate/Coral setup. Dude ⌠@briis ⌠let me know how I can buy you a coffee! Thank you
