Custom energy dashboard: how to place energy-date-selection card in header?
I just jumped in this topic as i was “fiddling” with custom:header-card
In Regards to energy-data in common there are lots of “choice”, depending upon what you want to have an overview over, and how , it all comes to ones “taste” and opinion, using different cards/views and using card-mod.
as for the header-card, it will have 2 rows as shown above, another card worth mention is custom:history-explorer-card.
Works with “sensors” of different “measurements” and “graphs/staples/time-line”
For “inspiration” custom:history-explorer-card in a Panel-View mode , and as a single card “cut out of another standard-View, with 3 columns”
03.01.2023_20.11.52_REC
Do you mind sharing the code for the layout you used in your custom energy dashboard? As it’s matching the standard energy dashboard ( the graphs are shown bigger). Want to do exactly the same😁. On a mobile phobe I suppose all card are behind eachother? Many thanks!
Sure
1st card is in a Masonry layout, Bottom is in Panel mode
type: custom:history-explorer-card
    cardName: advanced-history
    uimode: dark
    defaultTimeRange: 1w
    decimation: false
    header: []
    graphs:
      - type: bar
        options:
          interval: daily
        entities:
          - entity: sensor.monthly_net_consumption_*******
            color: '#208020'
            state_color: true
            name: Daily Consumption
Did you use the custom-layout-card for creating the layout of all cards in your dashboard? And what config? Great to have the graphs bigger than the gauge cards :+1:t2:
Standard masonry layout.
if you want a card to “span” more than 1 column, in a View/Dashboard, you can use grid
… or place gauge-cards in Horizontal stack card(1 “view/Dashboard” column) ( to make them smaller )
PS, as your questions have nothing to do with “energy-selection card in header, i suggest you search elsewhere( for i.e energy dashboards in layouts, grid or Vertical / Horizontal-stack) or open another Topic”
As the first card “seems” so big is because then i only had 2 columns i the that View, so what you need to do is decide how you want to structure your Energy-View. Dashboard, and for best “adaptive” look, i.e viewing from phone, laptop, tv, use masonry-view ( Grid can be a pain in the ass, in specific if you use px , in height/width )
Try the energy-period-selector-plus card. GitHub - flixlix/energy-period-selector-plus: An upgraded Energy Date Selection Card for Home Assistant, with added customizability, while maintaining the Energy Dashboard's original design.. Hope this provides what you need.
Thanks, great work!
I added the card and have some questions.
  • Does the date selector take the locale settings into account? I am using English as language but am using the Dutch locale settings. So the date should be 31/12/2022 instead of 12/31/2022
  • For some reason the compare button is placed on a separate row. In the editor it is shown on the same row als the day/week/month/year selector. I am using the sidebar layout (same as the original energy dashboard)
Card select
I was able to get the date selector in the header by using this code:
header_cards:
  justify_content: null
  cards:
    - type: energy-date-selection
      card_mod:
        style: |
          ha-card {
            --ha-card-background: "rgba(30, 30, 30, 0.0)";
            --ha-card-border-width: 0px;
            --ha-card-border-radius: 1px
The above code wasn’t working for me and this was driving me crazy for days but it turned out the solution is so simple (duh…)… Just use a vertical-stack card in header_cards, with only the energy-date-selection in it. You can style the vertical-stack card easily like most other cards.
header_cards:
  cards:
    - type: vertical-stack
      cards:
          card_mod:
            style: |
              ha-card {
              height: 35px !important;
              background: none;
              border: none;
Hey… sorry for the dumb question… kind of HA newbie here. Where do you exactly put this code?
I’ve tried in the view yaml but it’s ignored. Thank you!
Go to your dashboard and edit it. Click the 3 dots in the upper right hand corner and select raw config editor.
Then paste code at the very top and save.
Are you using the header card to filter data on your charts? If so, I would love to see how this works - I’m wanting to do the same thing without needing to use Influx and Grafana
I must have missed your reply but I was using it to filter data on my charts...however a recent update seems to have broken this because this is how it looks now.
I am now just using the date picker card at the top of my custom energy dashboard. It filters the data in the graphs and the cost + energy used. Like so:
