Here is a flow for node red. Insert your Token and IP-adress
[{"id":"905cb3bda191e36b","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"f4b6f0d33931d39a","type":"http request","z":"905cb3bda191e36b","name":"Status Request","method":"GET","ret":"obj","paytoqs":"body","url":"http://192.168.1.208/api/v2/status","tls":"","persist":false,"proxy":"","authType":"","credentials":{},"x":446,"y":126,"wires":[["a9ce5880e1915c95"]]},{"id":"e9aecd05222f9fbb","type":"inject","z":"905cb3bda191e36b","name":"Paus","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":166,"y":126,"wires":[["f4b6f0d33931d39a"]]},{"id":"a9ce5880e1915c95","type":"switch","z":"905cb3bda191e36b","name":"Auto?","property":"payload.OperatingMode","propertyType":"msg","rules":[{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":596,"y":126,"wires":[["5679a4688fdcdcbc"]]},{"id":"29a3d8cdd48fde0e","type":"http request","z":"905cb3bda191e36b","name":"Set Manual","method":"PUT","ret":"obj","paytoqs":"ignore","url":"http://192.168.1.208/api/v2/configurations","tls":"","persist":false,"proxy":"","authType":"bearer","credentials":{},"x":598,"y":180,"wires":[["02aad748458b5e87"]]},{"id":"5679a4688fdcdcbc","type":"function","z":"905cb3bda191e36b","name":"API-Nyckel TOU 10","func":"msg.payload = \"EM_OperatingMode=10\"\nmsg.headers = {}\nmsg.headers ['Auth-Token'] = 'insert token here'\nmsg.headers [\"Content-Type\"] = \"application/x-www-form-urlencoded\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":402,"y":180,"wires":[["29a3d8cdd48fde0e"]]},{"id":"02aad748458b5e87","type":"debug","z":"905cb3bda191e36b","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":778,"y":180,"wires":[]}]
