Custom Integration to import long term statistics from a file like csv or tsv
Yeah, either the existing values and the imported values have to fit perfectly to each other, or you have to reimport everything.
For now, there is not really a simple way. As said, I am working on something, but that will only help if you have correct data after some specific date/time, and import the values before. Everything else will always be “not easy”, I do not even have an idea how to solve this. OK, maybe it could help to import hourly values and calculate the sum from them,
You could provide me a kind of specification containing:
  • what do you have currently in the database
  • which data you would like to import
  • how the result should look like
I cannot promise anyhting, but some input would help :wink:
Thanks man, its not a simple problem cause of the way they are stored.
So I had my DB crash March last year. So any energy data, Solar + Grid (Import + Export) and Battery (Charge + Discharge) is basically missing from Jan 23 to March 23. After is good
I have the data from my solar app and provider. Solar data (Battery inc) is good as it is already hourly. My data from provider is every 30mins but I used a pivot table to make it hourly.
I’m new to home assistant. I wanted to first knowing how to import statistics from an other older system. I struggled a bit with the documentation. Not finding Developer tools / Services.
Would be nice to update the README.md as there is no more service tab:
I thought it wasn’t useful to open an issue on github for that.
I’m succeeded to install this promising custom integration. I had to replace the “custom_components/homeassistant-statistics” mentioned in the readme with “custom_components/import_statistics” to get it working. But the service “import_from_file” is not registered. The UI says that the service should be added manually.
I’m running HA 2024.10 on docker. You can see my folder structure and the integration details below.
Can anyone help?
Sorry for that, I’ve found it:
Updated the readme. Thx for the hint!
Updated readme as well. This was wrong since months … thank you!
Regarding the remaining problem, also updated the readme.
Hi Klaus, great integration, thanks a lot!
I had problems with the import of my water data, too. I also used m³ as the measuring unit. When I switched to Liter, everything worked fine.
At least I found out, that I had to switch the codepage for the csv file to Unicode UTF-8.
Perhaps this is helpful, if a similar error occures somewhere else.
Best regards - and “Guten Rutsch”,
Andreas
Hi there. Great work with this, finally an integration that actually uses Home Assistant APIs instead of manually modifying the database eheh
Anyway I’m trying to import electricity readings from a file having this format:
statistic_id|unit|start|state|sum
sensor.energy_mains_total_f1|kWh|06.02.2024 00:00|83.48|83.48
sensor.energy_mains_total_f1|kWh|06.02.2024 01:00|83.48|83.48
sensor.energy_mains_total_f1|kWh|06.02.2024 02:00|83.48|83.48
sensor.energy_mains_total_f1|kWh|06.02.2024 03:00|83.48|83.48
sensor.energy_mains_total_f1|kWh|06.02.2024 04:00|83.48|83.48
sensor.energy_mains_total_f1|kWh|06.02.2024 05:00|83.48|83.48
sensor.energy_mains_total_f1|kWh|06.02.2024 06:00|83.48|83.48
sensor.energy_mains_total_f1|kWh|06.02.2024 07:00|83.48|83.48
Readings cover various non-contiguous dates from february to october 2024 (not every day because they are readings from my provider, but I managed to “simulate” 24 rows for each day, although I don’t know if that helps).
This is the result:
The first month shows a really high power consumption I guess because I don’t have any readings from before. Can I do something to use the first reading as a baseline and start measuring from there?
December shows a negative value which is exactly the same as february but with a minus sign. The reason why that is really escapes me.
Do I need to calculate a proper “sum” value? Can’t I use the same value as “state”? And if not, why?
Thanks, I will add this to the README. What error did you get?
Did you read the paragraph “whereas counters are more complex” from the readme? Could be that “You have to align the imported values with the first current value in your database” is violated.
hmm i seem to be having issues importing.
i’m trying to import this file, but i’m getting an error in logs, but “unknown error” on the gui.
i’m using container home assistant 2024.12.5
and these are the logs
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:526
First occurred: 2:17:21 PM (3 occurrences)
Last logged: 2:38:55 PM
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: expected string or bytes-like object, got 'NoneType'
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 764, in _async_call_service_step
    response_data = await self._async_run_long_action(
    ...<9 lines>...
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 727, in _async_run_long_action
    return await long_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2852, in _execute_service
    return await self._hass.async_add_executor_job(target, service_call)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/import_statistics/__init__.py", line 42, in handle_import_from_file
    stats = _prepare_data_to_import(file_path, call)
  File "/config/custom_components/import_statistics/__init__.py", line 83, in _prepare_data_to_import
    stats = _handle_dataframe(df, timezone_identifier)
  File "/config/custom_components/import_statistics/__init__.py", line 151, in _handle_dataframe
    source = _get_source(statistic_id)
  File "/config/custom_components/import_statistics/__init__.py", line 182, in _get_source
    if valid_entity_id(statistic_id):
  File "/usr/src/homeassistant/homeassistant/core.py", line 240, in valid_entity_id
    return VALID_ENTITY_ID.match(entity_id) is not None
TypeError: expected string or bytes-like object, got 'NoneType'
Hm. Can you please try to remove the first two columns (although I do not think that should be a problem). Then there should be a state column (values can be equal to sum for now, but I am also not sure if sum only should work as well.
If that does not help, please create a bug on the repo, including the file you try to import (not only a screenshot), and a screenshot of the HA GUI where you call the function.
Ok I needed to wrap my head around the alignment you were talking about, but I think I got it now:
Here is what I did:
  1. (while HA was stopped) delete all sensors data from the database and core.restore_state
  2. generate (and import) a csv with values with a calculated sum column:
sensor.energy_mains_total_f1|kWh|06.02.2024 00:00|83.48|0.0
sensor.energy_mains_total_f1|kWh|29.02.2024 00:00|83.5|0.02
sensor.energy_mains_total_f1|kWh|31.03.2024 00:00|92.13|8.65
sensor.energy_mains_total_f1|kWh|30.04.2024 00:00|122.63|39.15
The main issue was that when I started measuring, the meter was already greater than zero (previous owner energy consumption), so I could not use a sum value equal to the state value.
Thanks!!
It would be nice to have options in the import process to fill gaps of data like simple “lerp” or “repeat-previous”. From what I understand I need to do that myself in an external tool to make sure the tsv is spaced hourly to the current timestamp.
How would I go about creating a sensor for the data that is not updated / overwritten by homeassistant template sensor ?
Yeah, both is true. No plans to do that yet, I’ll put it on my list, but it will take some time until I can work on this integration again.
Not sure what you mean. You can use an external sensor (‘:’ instead of ‘.’), if you want to have statistical data only.
Hi Klaus,
Just switched to HomeAssistant and well impressed, with your custom integration!
I also have a similar issue: imported 2024 gas usage data. All seems to be fine except a few days in this year: 01/01/2025, 02/01/2025 & 07/01/2025.
The history seems to be fine; the line is climbing pretty smoothly.
The Gas Usage graph (and this months totals) indicate different:
Any ideas how to correct this?
Regards, Frank
Got it working by setting up a sensor in yaml that only updates on trigger and importing the data in that one.
template:
  - trigger:
      - trigger: event
        event_type: power_cycle_bill_cost_t1_update
      - name: "Power Cycle Bill Cost (T1)"
        unique_id: power_cycle_bill_cost_t1
        state_class: measurement
        unit_of_measurement: "€"
        state: >
          {{this.state}}
