MarkR
May 21, 2018, 12:18pm
1
Hello
I have been trying for ages to get some ping sensors to change colour when they are online of offline. So far I have failed! Anyone know why please? This is what I currently have
Config:
Sensor:
sensors:
arcade_state:
value_template: '{% if is_state("device_tracker.arcade", "home") %}Online{% else %}Offline{% endif %}'
friendly_name: 'Arcade Machine'
customize.yaml
binary_sensor.arcade_state:
friendly_name: Arcade Machine
icon: mdi:desktop-classic
templates:
icon: >
rgb_color: "if (state === 'Online') return [251, 210, 41]; else return [54, 95, 140];"
I’ve tried Binary sensors, globs, etc but nothing changes the colour of the icon.
Any idea please?
Cheers
Mark
petro
(Petro)
May 21, 2018, 1:13pm
2
You had an extra “icon:>” for some reason.
templates:
MarkR
May 21, 2018, 2:17pm
3
thanks… same problem. I am starting to think this was pulled in 0.66 and I have to use Custom UI?
petro
(Petro)
May 21, 2018, 2:35pm
4
I’m not sure, there’s a guy who uses this all the time. Maybe he knows. @Mariusthvdb any ideas why this isn’t working?
i always check 2 things:
is the state being referenced the correct one? in this case, does the binary sensor really show state Online and Offline?
does it work in Chrome. Im a Safari user, but many customizations of this kind only show correctly in Chrome.
Example:
customization for a binary_sensor:
binary_sensor.asus_router:
templates:
theme: >
if (state === 'on') return 'green';
return 'red';
Chrome:
Safari:
dev_state
the rgb color is done like this (change the color of the icon, if you want the whole line to change, use theme):
sensor.audio_auditorium_state:
templates:
icon: >
if (state === 'on') return 'mdi:music';
return 'mdi:music-off';
icon_color: >
if (state === 'on') return 'rgb(251, 210, 41)';
return 'rgb(54, 95, 140)';
You can also use the binary_sensor directly for this, dont need a template sensor:
# Binary sensors
# https://home-assistant.io/components/binary_sensor
# https://home-assistant.io/components/binary_sensor.ping/
- platform: ping
host: 192.168.1.1
in which case you can customize as follows:
device_tracker.ping_asus_router:
templates:
theme: >
if (state === 'home') return 'green';
return 'red';
_stateDisplay: >
if (state === 'home') return 'Online';
return 'Offline';
Cheers,
Marius
MarkR
May 21, 2018, 3:23pm
6
thank you so much… mine aren’t set as Binary Sensors. Does that matter? how does your Asus router binary sensor look please?
i have 3
I use the ping platform next to the Asuswrt in Device_trackers, creating both devices in the known_devices. Add that to the binary_sensor, and you have 3 sensors checking the status. believe me, they’re not always showing the same state, so having 3 ways to check an be helpful with the system critical devices
- platform: ping
interval_seconds: 20
consider_home: 60
hosts:
ping_asus_router: 192.168.1.1
MarkR
May 22, 2018, 6:42am
8
thank you… This works great now thanks… Cannot get RGB to work… thank you for the detailed reply! You do need custom UI installed for it to work.
binary_sensor.arcade:
templates:
icon_color: >
if (state === 'on') return 'black';
return 'red'
_stateDisplay: >
if (state === 'on') return 'Online';
return 'Offline';
device_tracker.arcade:
templates:
icon: >
if (state === 'home') return 'mdi:music';
icon_color: >
if (state === 'home') return 'black';
return 'blue';
_stateDisplay: >
return 'Offline';
