Check the About page to ensure Custom UI is installed.
yes. That is what I have too. just my HA version is 0.81.2
did you change the path, and still get the error?
in config.yaml :
customize: !include customize.yaml
customizer: !include config/customizer.yaml
frontend: !include frontend.yaml
in frontend.yaml :
## https://home-assistant.io/components/frontend/
## https://home-assistant.io/developers/frontend_creating_custom_ui/
javascript_version: latest
extra_html_url_es5:
- /local/custom_ui/state-card-custom-ui-es5.html
extra_html_url:
- /local/custom_ui/state-card-custom-ui.html
in customize.yaml:
sensor.fibaro_system_fgms001zw5_motion_sensor_temperature_2:
templates:
icon_color: >
if (state > 25) return 'rgb(0, 128, 0 )â;
if (state >= 18 ) return ârgb(223, 76, 00 )â;
return ârgb(35, 76, 99 )â;
sensor.fibaro_system_fgms001zw5_motion_sensor_temperature:
templates:
icon_color: >
if (state >= 18 ) return 'rgb(223, 76, 00 )';
return 'rgb(35, 76, 99 )';
my entityid : sensor.fibaro_system_fgms001zw5_motion_sensor_temperature
please range the path here also: !include customizer.yaml
next, I think it would be wise to set
customize_glob:
â.â:
custom_ui_state_card: state-card-custom-ui
set that in configuration.yaml
homeassistant:
latitude: !secret latitude
longitude: !secret longitude
elevation: !secret elevation
unit_system: metric
time_zone: !secret time_zone
customize: !include_dir_merge_named customize
customize_glob: !include customize_glob.yaml
and this in the customize_glob.yaml
# Customize entities matching a pattern
# to override use: custom_ui_state_card: null
# YAML keys canât start with an asterisk - *, so in that case quotes are requires.
# However in the middle or end of the key an asterisk is allowed.
# https://community.home-assistant.io/t/customui-discussion-thread/48694/237?u=mariusthvdb
this is my config, and it doesnât work. Anyone who can help me ?
in config.yaml :
in frontend.yaml :
extra_html_url_es5:
extra_html_url:
in customize.yaml:
templates:
icon_color: >
templates:
icon_color: >
costomize_glob.yaml
hi back again!
You donât mention the contents of your customizer.yaml. You can take that line out if you donât have it, or at lest correct the path to !include customizer.yaml
you actually have these files installed? in /config/www/custom_ui/ ?
I have. I use the local automatic installation (using the update.sh script). It will download these files to the correct folder.
Did you look at the installation instructions?
this I added in my configuration.yaml:
# Enables configuration UI
config:
# enable custom_ui for icon color customization
customizer:
custom_ui: local
⌠yes,
and thatâs why I told you you shouldnât use the customizer: settings you posted above.
Youâre using the update.sh script, which takes care of installing the files, just add the front-end settings and the customize_glob and youâre set to go.
hmm sorry, I totally missed the context of your question. It was to help Faecon.
But youâre saying the customizer: part is not required?
Indeed, unless you want to set other specific settings as described in the docs on the github, not needed for installing custom-ui when the update.sh script is used for automatic installation.
Nothing is changing. Is it possible something is overwriting the colour ? From another yaml file ?
did you take out the custom_ui: local after customizer: ?
I already had removed the customizer
#customizer: !include customizer.yaml
hi guys.
this works for me
friendly_name: kamer Joachim en Saar
templates:
icon_color: >
if (state > 25) return '#008000';
if (state >= 18 ) return '#df4c00';
return '#234c63';
not in rgb but in hexa
well thatâs good to hear, finally⌠proves custom-ui is working.
you can use any css color format, including rgb. see: home-assistant-custom-ui/docs/features.md at master ¡ andrey-git/home-assistant-custom-ui ¡ GitHub
templates:
icon_color: >
if (state > 25) return 'rgb(0, 128, 0)';
if (state >= 18 ) return 'rgb(223, 76, 0)';
return 'rgb(35, 76, 99)';
or use the color names:
templates:
icon_color: >
if (state > 25) return 'green';
unless for some reason your lights donât support these color settings. You can check that in the dev-state page and look in the attributes column:
Is there one post to start from?
I am trying to give device_tracker items a green colour when they are home. This thread seems to be cluttered with 10 ways of doing it where half donât work and the other half donât provide a step by step plan but assume you know each file where the code needs to go, etc.
yes, you shouldinstall custom-ui first, read the documentation ann then you probably have concluded this will do it:
homeassistant:
customize_glob:
device_tracker.ping_iphone_*:
show_last_changed: true
templates:
icon_color: >
if (state === 'home') return 'rgb(251, 210, 41)';
return 'rgb(128, 128, 128)';
_stateDisplay: >
if (state === 'home') return 'Online';
return 'Offline';
to set customization globally,
or:
homeassistant:
customize:
device_tracker.appletv:
templates:
theme: >
if (state === 'home') return 'green';
return null;
_stateDisplay: >
if (state === 'home') return 'On';
return 'Off';
for an individual entity
Thanks for helping out. Got it figured out in the end and will describe here how for newbies.
First I have to state that I was not clear in my post about what I wanted to accomplish. Apologies for that. I was looking for badges/labels/icons that would change colour based on the state of device_tracker, thus home or not_home. The code given above this post will change the colour when a listbox is rendered or when an entry (also device_tracker ones) is clicked on and a layover box is opened. But the badge/label wonât change. Again, my mistake for not being clear.
So, here is how to do it:
Part 1 - CustomUI
Install CustomUI by following the âAutomatic installâ procedure from home-assistant-custom-ui/docs/installing.md at master ¡ andrey-git/home-assistant-custom-ui ¡ GitHub.
Then activate with method 1.1 from home-assistant-custom-ui/docs/activating.md at master ¡ andrey-git/home-assistant-custom-ui ¡ GitHub.
Finally add this to configuration.yaml:
customizer:
custom_ui: local
Restart HA. You can find this by clicking Configuration - General from the webinterface.
Confirm CustomUI to be working by looking at the dev-info page by clicking the i-button in the developer tools area from the webinterface:
Custom UIs:
CustomUI: 20180831
If Custom UI is not mentioned, then it is not installed and/or activated.
Part 2 - Styling
Always use the check config feature in the webinterface located at Configuration - General between edits.
To have the icon and badge colours changed:
This goes into configuration.yaml:
homeassistant:
customize_glob:
device_tracker.*:
state_card_mode: badges
templates:
theme: >
if (state === 'home') return 'green_badge'; else return 'red_badge';
Likely it can be dropped into customize_glob.yaml if you have this separate file and call it from configuration.yaml. For newbies reading this, realize that YAML uses indentation as part of code structure. So using wrong indentation will lead to errors. Also elements can only be called once. Here in the code above homeassistant: is called, which is by default in the configuration.yml already, so what you need to do is copy only new code and put it âinsideâ the reach of homeassistant:.
Here an example of how the first part of your configuration.yaml might look when integrating the above code:
homeassistant:
latitude: 53
longitude: 9
elevation: 20
time_zone: CET
# Customization file
customize_glob:
device_tracker.*:
templates:
theme: >
# Show links to resources in log and frontend
#introduction:
Continuing in configuration.yml:
frontend:
themes:
green_badge:
label-badge-red: green
label-badge-border-color: lightgrey
label-badge-background-color: white
label-badge-text-color: green
red_badge:
label-badge-red: grey
label-badge-text-color: red
Again here, frontend: is already in the configuration by default so insert the new code with the right indent.
Restart HA as described earlier.
Now it should work.
Borrowed most of this code from cameron earlier in this thread.
My questions still:
Would there be a better way to organize this? Like a different method instead of themes? Since themes will be displayed in the skin selector menu.
Can the label be renamed to something else? Since devices are not always away but just offline.
How about something like âstate groups.â Some devices are critical and always online, so when offline something must be wrong, thus you would want to show them as red when offline but show normal devices as orange when offline. Also, some devices can be offline but wonât leave the house thus when offline they should be given even another colour. Etc.
If no easy answer, I hope to answer the questions myself one day. At least CSS skills onboard. ![]()
You sir are gold.
Finally all the info in one place and WORKING!.
BTW, I use Hassio, so I used manual install (local) and activated using 1.2 chapter from links above.
Thank you
ps.
Somebody make this a sticky and into documentation please.
