Custom UI: Tiles
Hey guys, any progress to get Custom UI working in combo with Lovelace?
Is it just me or has the Tiles Repo on Github gone?
https://github.com/c727/home-assistant-tiles
He is also working on the lovelace project. Probably did not want to keep both projects up.
Ah ok. I have my config pointing directly to his repo for the html files required. So my Tiles are not showing up now. Where else can I find these files ?
Can someone please share their Tiles files?
Here you go. These are from 21.05.2018.
https://we.tl/OIs9Tt2JlS
Cheers :+1:
Is custom-ui-tiles being Implemented in Lovelace?
I hope so, because the tiles have way more options than lovelace atm.
but lovelace has a lot of potential
Thanks! Repo gone! Will give this a try.
@eddi89
I donā€™t get why this repo is gone. I get itā€™s not being updated anymore because of work on Lovelace, but since thereā€™s no tiles like functionality working in Lovelace, not to mention itā€™s still experimental, is there any reason why it canā€™t be used? I was looking for the instructions to add some more tiles and since itā€™s gone I have to rely on my memory which isnā€™t very good at times. Any chance we can have the repo back, or at least the last instructions? It would be much appreciated.
You can get almost exactly the same functionality with picture templates in Lovelace. Itā€™s not really more complicated, just another way of doing it and really you get more control.
Third picture down in this link is my first go at Tileā€™ish in Lovelace. Config is in this file.
@teachingbirds
Thanks. Iā€™ve been playing with Lovelace but canā€™t get a button or icon to change to a colour based on on/off state. May just be something Iā€™ve missed in the documentation but for scenes itā€™s nice to know which one is currently on. For some reason, only the picture-glance seems to change the colour based on the state. Canā€™t replicate the tiles like functionality. Ideas?
Iā€™m guessing you need state image
Thanks for sharing your example, Iā€™ll definitely be taking some time to explore your config :slight_smile:
For your tile implementation - doesnā€™t the click only work on the icon itself (vs the entire tile/button)? Iā€™m trying to think of how I could have the tile change, including the background color. Iā€™m trying to replicate the homekit UI to a certain degreeā€¦ Maybe itā€™s just a full size button image over a button template imageā€¦Iā€™ll have a go, but would be interested if you have any ideas/experiences!
Can you pass data value to script with lovelace?
This is from tiles:
      - entity: script.press_button
        icon: mdi:arrow-left-thick
        column: 1
        row: 5
          value: left
I recreated my device tracker tiles as previously posted above in Lovelaceā€¦
25
ā€¦as you can see they are identical to those I posted previously and now use only one colour image as the state is handled by CSS now rather than image replacement, example of one tile belowā€¦
  - type: image
    entity: device_tracker.huawei_p10_lite
    tap_action: more-info
    image: /local/images/tracker/sam.png
    state_filter:
      'not_home': saturate(0.0) opacity(50%)
    style:
      top: 50%
      left: 86%
      width: 22%
      # padding: 50px 50px 100px 50px
      border-radius: 5%
I made a white background image to force the card to be the proportions I wanted.
I did spend the weekend experimenting with Lovelace and itā€™s true, pretty much everything can be replicated with one exception, thereā€™s no current way of changing the background of a non-image based on the theme thatā€™s being used. For instance If Iā€™m using an icon on a background that changes color depending on the state, it turns grey or yellow. I can partially replicate the on/off state by making a two pictures, one totally transparent and the other a solid color of the on state, but thatā€™s a workaround vs having something that changes with the themes.
There is also an issue with picture-elements and state-icon where the icon doesnā€™t actually reflect the different on/off state. I raised that issue on github.
https://github.com/home-assistant/ui-schema/issues/153
I am using customize to change the icon colors. See here.
Awesome!! That does the trick! Thanks
