yes, but you should use a real entity_id… this was just a generic exampleof course
well tbh, that’s not a dumb mistake, but a discrepancy/change of the new tiles card, and a bit against usual practice?
before we needed to code like this:
homeassistant:
customize:
input_text.tiles_switches:
custom_ui_state_card: state-card-tiles
config:
columns: 4
row_height: 70px
color_on: '#F0C209'
color_off: '#555B65'
text_uppercase: false
text_color_on: '#555B65'
text_color_off: '#F0C209'
text_size: 1em
text_sec_size: 1em
text_align: center
entities:
- entity: switch.sw_netwerk_auditorium_template
label_sec: Auditorium
icon_template: >
if (state === 'on') return 'mdi:wifi';
return 'mdi:wifi';
style_template: >
if (state !== 'on') return 'text-decoration: line-through';
as is needed with the legacy settings:
type: custom:tiles-card
legacy_config:
columns: 4
row_height: 70px
color_on: '#f0c209'
color_off: '#555b65'
text_sec_color_on: '#555B65'
text_sec_color_off: '#F0C209'
text_size: 1em
# text_sec_size: 1em
# text_align: center
# if (state === 'on') return '--tiles-icon-color: #555B65';
# return '--tiles-icon-color: #F0C209';
entities:
icon_template: >
return 'mdi:wifi';
style_template: >
if (state !== 'on') return 'text-decoration: line-through;--tiles-icon-color: #F0C209';
Agreed, it would be great if Tiles could utilise tap_action (along with action, navigation_path, etc), as documented in the built-in button card here: https://www.home-assistant.io/lovelace/entity-button/configuration-variables
Agreed that this would be awesome to have. I have a few RGB light strips and I’d love to be able to use hold_action to pull up more-info so that I could set the colors.
I do see that under entity, there is an option for more info, but I’m not 100% sure what it does based on the example on github.
entities:
- entity: light.light_1 #(Entity specific settings. Overwrite the global settings)
column: 1 #(optional)
row: 1 #(optional)
column_span: 2 #(optional)
row_span: 4 #(optional)
display: show #(optional)(hidden, none, show)
orientation: #(optional)(horizontal or vertical)
padding: 0px #(optional)
align: 'center middle' #(optional)(letf, center, right, top, middle, bottom)
disabled: true #(optional)(true or false)
shadow: 'elevation: 12dp' #(optional)(elevation: 2dp, 3dp, 4dp, 6dp, 8dp, 12dp, 16dp or 24dp or box-shadow css attributes)
more_info: switch.tv #(optional)
data: #(optional)
service: #(optional)
Has anyone managed to get any of the tiles to pull up the more-info window?
oh yes. its working. may i ask more help?
i want to show “seconds ago”… how this formula has to be?
you mean the text ‘seconds ago’ ?
this always done like : return state + 'seconds ago' ;
of course replace state
with whatever you’re showing
see my example above:
return Math.round(attributes.brightness / 2.55) + ' %';
it calculates the value and add s the % after that
like this, but its ugly:
entities:
label: Auditorium
label_sec_template: >
return entities['switch.sw_netwerk_auditorium_template'].last_changed
icon_template: >
return 'mdi:wifi';
style_template: >
or
entities:
label: Auditorium
return 'Changed ' + entities['switch.sw_netwerk_auditorium_template'].last_changed
icon_template: >
return 'mdi:wifi';
style_template: >
needs further templating to be useful
@jarrah I was trying to build a light count like you have. Built the sensor the same way you did for your blinds, just using my light and switch entities in it, and it does the count, but it doesn’t update when lights are turned on and off. I have the sensor config in configuration.yaml. If I restart home assistant it will update the count, but if I turn anything on or off, it won’t update again until I restart everything.
Wondering if you have any advice on what I might be doing wrong.
Actually, figured it out. I didn’t have the sensor.time setup in config.
I have this setup on how long since my garage door state changed. Here’s how I did it.
In the view config:
- entity: cover.garage_door_opener
row: 4
column: 1
column_span: 4
row_span: 1
icon:
templates:
label_sec: "return 'Garage Door is ' + entities['cover.garage_door_opener'].state + '.<br>
It has been ' + entities['cover.garage_door_opener'].state + ' for ' + (entities['sensor.garage_last_updated'].state) + '.'"
and the config to build that specific sensor is in configuration.yaml:
sensors:
garage_last_updated:
value_template: '{{relative_time(states.cover.garage_door_opener.last_changed)}}'
entity_id: sensor.time
and make sure that you have the platform for time_date in your configuration.yaml as well:
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'time_date'
- 'time_utc'
- 'beat'
That gives me this:
yes, and for the automation, he’d need something like this:
{{relative_time(states.automation.automation_ran.attributes.last_triggered)}} (which is an actual automation I have to see which automation ran)
btw: dont think you’d need the entity_id: sensor.time here. The entity_id would be enough since the template holds all data needed to ’ only update based on entity state changes.’ see: Automation Trigger - Home Assistant
So here’s another odd thing I noticed. If I have an icon set for the view, the icons will show for everything. If I don’t have an icon set for the view, all the other icons disappear.
Below is a part of the config:
title: Home
icon: mdi:home
panel: false
path: main
background: '#170e4d'
cards:
- type: 'custom:tiles-card'
card_settings:
align: center
gap: 1px
padding: 0px
columns: 4
row_height: 45px
column_width: 109px
templates:
style: "return 'box-shadow: 0px 0px;'"
global_settings:
label:
color:
value: white
value_on: white
value_off: grey
value_disabled: white
label_sec:
color:
value: white
value_on: white
value_off: grey
background:
value: '#2c446b'
value_on: '#4879c9'
value_off: '#2c446b'
value_disabled: black
icon:
value_disabled: 'mdi:cloud-off-outline'
color:
value: white
value_on: '#f8ff32'
value_off: white
value_disabled: red
entities:
- entity: group.actual_lights
templates:
label: "return 'Lights on: ' + entities['sensor.lights_on'].state;"
row: 1
column: 1
column_span: 4
- entity: switch.bathroom_light
templates:
label: "return 'Bathroom'"
icon: "if (state == 'on') return 'mdi:lightbulb-on';else return 'mdi:lightbulb-outline'"
row: 2
column: 1
column_span: 1
row_span: 2
if I remove the icon:mdi:home from the top, all icons disappear.
Anyone updated to .88 and now the tiles don’t give that nice ‘flash’ when you press them, but instead there is a blue outline around the tile. So, last tile pressed always has a blue outline around it?
Getting the same thing here… Haven’t had time to check if it’s related to the breaking change, a few custom cards have had to update to accommodate 0.88
Ther’s not even the blue outline in Firefox. If it wasn’t for the service-call pop-up lower left it would be impossible to tell if the button had been pressed.
Safari shows a slight dimming of the button.
Yeah, just checked firefox, no outline.
I get the blue outline on chrome, Fully Kiosk Browser, and Wall Panel.
Hi @rodrigodf, would you mind popping back on to help fix some of the issues seen on 0.88 with your excellent Lovelace version of Tiles please?
I thank yes
Same for me on Home Assistant 0.88.2. You need at least two views (otherwise Home Assistant won’t show the tab bar and thus no view icon). If I remove icons from the views and refresh the page (via browser/F5), not a single icon of the tiles card shows up (although they seem to be there in the DOM).
May have something to with https://www.home-assistant.io/blog/2019/02/20/release-88/#noteworthy-breaking-changes
Example Lovelace configuration below. Channel up/down icons disappear when removing icon: mdi:home
from first view (thus no view with icon).
resources:
- url: /local/tiles-card.js?v=0.1
type: js
- title: Home
icon: mdi:home
- title: Remote
panel: false
path: main
cards:
- type: "custom:tiles-card"
card_settings:
title: Fire TV
background: var(--paper-card-background-color)
global_settings:
entities:
- entity: script.lgtv_channel_up
label: Channel up
icon: mdi:menu-up
- entity: script.lgtv_channel_down
label: Channel down
icon: 'mdi:menu-down'
I assumed this card is not being developed anymore or at least on hold.
Does anyone have any information on that?
To me it is aesthetically unusable since 0.88 with the buttons being outlined after press. This is not a complaint, I’ll find another card, just wondering if anyone knows if the card is no longer being developed.
Hey all - I LOVE this tile customisation, I never want to look back.
But I just upgraded from 87 to 91 (not using Lovelace) and it appears that the ‘align:’ variable is broken. I first noticed when I had no ‘align:’ value set - so I was relying on the default ‘center middle’. I have entered ‘align: center middle’ since, to no effect.
The images are fine (they take up all tile space), it’s just the mdi icons and text labels that are noticeably affected.
Is this mod still supported somewhat? I hope so, it’s a huge improvement on the default IMHO
Cheers!
Matt
