yes try to put that
i dont understand why not shows me. if you use HASS.IO too, that is no problem.
yes iâm using hass.io is your script working by itself try using another entity like a light or switch.
input_text.dummy_tiles:
custom_ui_state_card: state-card-tiles
config:
columns: 3
column_width: 75px
row_height: 75px
entities:
- entity: light.mi_cuarto_1
image: /local/ok.png
column: 2
row: 5
data: {value: ok}
by the way iâm not an expert on this
yes, i going to try it
nop⌠doesn´t work if you have GitHub give the link pls
When we make modifications to the script, do we have to restart the home assistant service?
config:
columns: 4
column_width: 75px
row_height: 75px
entities:
- entity: input_boolean.switch1
icon: mdi:lightbulb
- entity: input_boolean.switch2
icon: mdi:lightbulb
column: 2
row: 1
icon: mdi:ceiling-light
column: 3
row: 1
column: 4
row: 1
- entity: switch.bosinas
icon: mdi:volume-high
column: 1
row: 2
- entity: switch.cafetera
icon: mdi:kettle
column: 2
row: 2
- entity: light.arilux_lc0x_rgb_led_controller_0stateoffbrightness85white_value0colorr208g52b0
icon: mdi:led-strip
column: 3
row: 2
- entity: light.sn1_led
icon: mdi:led-off
column: 4
row: 2
- entity: switch.vizio_switch
icon: mdi:television-classic
column: 1
row: 3
- entity: switch.bar_switch
icon: mdi:surround-sound
column: 2
row: 3
- entity: switch.netflex
icon: mdi:netflix
column: 3
row: 3
- entity: switch.fuente
icon: mdi:water-pump
column: 4
row: 3
- entity: script.example_script
label: sistem test
column: 1
row: 4
value: top
- entity: script.example_script3
label: alarm
column: 2
row: 4
value: left
- entity: script.example_script2
column: 3
row: 4
value: ok
- entity: script.rain_radar_push
label: sample
column: 4
row: 4
value: right
group:
g1:
entities:
- input_text.dummy_tiles
input_text:
command:
dummy_tiles:
frontend:
extra_html_url:
- /local/custom_ui/state-card-tiles.html
this is my set up i hope it helps
Thank you @Kem the problem is solved was the google chrome cache I needed to clean it. Now its working. Thanks for all patience.
Hi All - this is amazing, fantastic work! A couple of questions as I work on adding this to my setup:
The text on my tiles is left-justified, but I see that itâs centered in all of the examples. Did I accidentally change something?
Is there a way to use templating to display state values of sensors? I have some temperature sensors that I could love to display as a label, but Iâm getting an error when trying.
label: {{ states.sensor.living_room_temperature.state }}
Thanks!
i think it is not implanted yet.
Anyone else using this on a tablet? In the âFully Kioskâ app I use for my wall panel, the tiles display but they are not the correct sizes.
Only if you change the config
@eddi89 how i can add texto and icon inside on the same button?
When I changed the customization file i.e. words on buttons for example âs1â to âoffice lightsâ - I donât see the change until I reboot. Same applies for any change really
Than you changed the config! So you must restart Home Assistant. Itâs not neccessary to reboot the host.
Guys, awesome idea. I have implemented but I have only one issue.
The big space between rows is too big. Isnât there a way to have the same gap as the width between columns?
Really liking this so far. I just have one suggested change to state-card-tiles.html
Add a min-width
property to paper-button
paper-button {
box-shadow: none !important;
margin: 0 !important;
background-color: var(--tiles-color);
color: #fff;
min-width: 10px;
Then, instead of defaulting to 100px
for column width, change it to 1fr
ready: function () {
var config = this.config;
this.updateStyles({
'--tiles-columns': config.columns ? config.columns : '3',
'--tiles-column-width': config.column_width ? config.column_width : '1fr',
'--tiles-row-height': config.row_height ? config.row_height : '100px',
'--tiles-gap': config.gap ? config.gap : '4px',
'--tiles-color': config.color ? config.color : 'var(--primary-color)',
'--tiles-color-on': config.color_on ? config.color_on : 'var(--google-green-500)',
'--tiles-color-off': config.color_off ? config.color_off : 'var(--google-red-500)',
The result of these two changes will auto fill to the container width if column width is not specified, which I think should be the default behavior:
nicely auto expands to this
