seriksson
(Stefan E)
February 21, 2019, 9:46am
101
Problem with the tracker-card. I hade 1.20 then I updated the card. Then bang… _“ERROR (MainThread) [frontend.js.latest.201902200] https://192.168.10.90:8123/customcards/tracker-card.js:231:1 Uncaught SyntaxError: Unexpected token export”
Running hassio 0.88 on Ubuntu 18.04 and Lovelace in yaml mode. Any ideas?
ZJAVA
February 21, 2019, 10:08am
102
Manual update to 1.2.2, works good.
callifo
(Callifo)
February 21, 2019, 12:40pm
103
Mines working OK, but all the custom components have dropped out.
Unfortunately as 0.88 moved the location of custom_components and the custom_component github repo’s store the phyical location on our HA installs, we need to wait for the authors to update their version file to reflect the new storage locations.
So I updated the tracker card and custom updater along with all custom cards. I deleted all “?v=…” from the urls under resources. The tracker card doesn’t show at all. Instead I get this error in home-assistant.log:
2019-02-22 23:29:33 ERROR (MainThread) [frontend.js.latest.201902200] http://xxx.xxx.xxx.xxx:8123/customcards/custom-lovelace/tracker-card.js?track=true:201:54 TypeError: null is not an object (evaluating ‘card.querySelector(’#’ + pending_updates[i][0]).addEventListener’)
Running hass.io 0.88.1 in docker on Ubuntu 18.04 with lovelace in yaml mode.
Any idea what I might be doing wrong?
Edit:
After the latest updates of both custom updater and tracker card and deleting “mode: storage”, everything works fine.
100lv
(100lv)
April 17, 2019, 10:46am
105
I have same problem. What I did:
docker exec -it container_name bash
#pip install pyupdate
SoL
May 9, 2019, 7:48am
106
Hi everyone,
I just installed custom_updater and tracker-card. The card appears in the frontend but I cannot see the version of current installed addons:
I enabled ‘custom_updater:’ in configuration.yaml and have the following in the ui file:
resources:
- url: /local/custom_ui/slider-entity-row.js?track=true
type: js
- url: /local/custom_ui/card-tools.js?track=true
type: js
- url: /local/custom_ui/layout-card.js?track=true
type: js
- url: /local/custom_ui/tracker-card.js?track=true
type: module
- url: /local/custom_ui/mini-media-player-bundle.js?v=1.0.2
type: module
Any tip to solve this issue?
Many thanks,
SoL
Tap update all and it will populate
tom_l
May 14, 2019, 1:46am
108
I have the following resources defined:
resources:
- type: js
url: /customcards/custom_ui/browser-commander.js
- type: js
url: /customcards/custom_ui/button-card.js
- type: js
url: /customcards/custom_ui/card-modder.js
- type: js
url: /customcards/custom_ui/card-tools.js
- type: js
url: /customcards/custom_ui/fold-entity-row.js
- type: js
url: /customcards/custom_ui/mini-graph-card-bundle.js?v=0.3.3
- type: js
url: /customcards/custom_ui/monster-card.js
- type: module
url: /customcards/custom_ui/mini-media-player-bundle.js?v=1.1.2
- type: js
url: /customcards/custom_ui/popup-card.js
- type: js
url: /customcards/custom_ui/slider-entity-row.js
- type: js
url: /customcards/custom_ui/tiles-card.js?v=0.1
- type: js
url: /customcards/custom_ui/time-input-row.js
- url: /customcards/github/custom-cards/tracker-card.js?track=true
type: module
- type: js
url: /customcards/custom_ui/vertical-stack-in-card.js
However the mini-graph-card and mini-media-player bundles are not showing up (tiles-card has not been updated in ages and is probably unsupported):
These are both bundles rather than js types. I’ve seen them in other peoples tracker-card so am wondering what I am doing wrong?
I have not added any options to the default configuration of the tracker-card or custom-updater.
Also, do I need to schedule an automation to run the custom_updater.check_all
service or does it happen automatically/regularly?
I moved mine around but if you use customcards folder instead of local, get rid of the version.
resources:
- url: /customcards/github/thomasloven/card-tools.js?track=true
type: js
type: module
- url: /customcards/custom-lovelace/upcoming-media-card/upcoming-media-card.js
type: js
- url: /customcards/custom_ui/dark-sky-weather-card.js
type: module
- url: /customcards/github/kalkih/mini-media-player-bundle.js
type: module
- url: /customcards/github/kalkih/mini-graph-card-bundle.js
type: module
- url: /customcards/github/maykar/compact-custom-header.js?track=true
type: module
- url: /customcards/github/thomasloven/fold-entity-row.js?track=true
type: js
- url: /customcards/github/custom-cards/button-card.js?track=true
type: module
- url: /customcards/github/thomasloven/auto-entities.js?track=true
type: module
- url: /customcards/github/custom-cards/config-template-card.js?track=true
type: module
- url: /customcards/github/custom-cards/podcast-card.js?track=true
type: module
- url: /customcards/github/custom-cards/bar-card.js?track=true
type: js
- url: /customcards/github/custom-cards/text-divider-row.js?track=true
type: js
- url: /customcards/github/maykar/lovelace-swipe-navigation.js?track=true
type: js
- url: /customcards/github/thomasloven/card-modder.js?track=true
type: js
It pops up with changes automatically for me… but if I know an update it out I force the update by clicking on check.
tom_l
May 14, 2019, 2:57am
111
Hmm. I removed the version info, saved, called the custom_updater.check_all
service, tried the check and update buttons and CTRL+F5 but the bundles are still not showing up.
note they are modules, not js
Also try the F12, right click refresh and hard reload, clear cache
tom_l
May 14, 2019, 3:12am
113
Sorry, yes modules.
Still not showing up after a browser cache clear and HA restart.
OK so last thing… there were some ‘quiet’ changes to the custom_updater… have you checked the repo for that lately? I had to manually update a few components last week but some of them had added files. Perhaps also check the repos for the cards as @iantrich changed a couple of his but the version didn’t change and I had to update those as well…
oh… also make sure you have this in config yaml…
# Custom Component Updater
custom_updater:
hide_sensor: false
track:
- components
- cards
- python_scripts
component_urls:
- https://raw.githubusercontent.com/pnbruckner/homeassistant-config/master/custom_components.json
card_urls:
- https://raw.githubusercontent.com/kalkih/mini-media-player/master/tracker.json
- https://raw.githubusercontent.com/kalkih/mini-graph-card/master/tracker.json
- https://raw.githubusercontent.com/iammexx/home-assistant-config/master/ui/darksky/version.json
tom_l
May 14, 2019, 3:30am
116
That was what I was missing. All good now. Thank you.
tom_l
May 14, 2019, 7:10am
117
Well not that good. My log is now filling up with:
2019-05-14 17:03:38 ERROR (MainThread) [frontend.js.latest.201904270] https://10.1.1.100:8123/customcards/custom_ui/mini-graph-card-bundle.js:1:38246 TypeError: a is undefined
2019-05-14 17:03:49 ERROR (MainThread) [frontend.js.latest.201904270] https://10.1.1.100:8123/customcards/custom_ui/mini-graph-card-bundle.js:1:38246 TypeError: undefined has no properties
What version of HA? Did you try empty cache and hard reload?
tom_l
May 14, 2019, 7:15am
119
v0.92.2
I did a cache empty not long ago. I’ll try again.
tom_l
May 14, 2019, 8:02am
120
The errors aren’t caused by the tracker-card. I also horizontal stacked some mini-graph cards today to make room on my system page. Putting them back to the original config has stopped these errors. Now to work out why…
