After successfully setting up everything (ensure not to activate LED feedback), I proceeded to follow the LED section of the original tutorial, completing each step as outlined. Following that, avoid running the new installer, as it will overwrite the changes just made. If you need to reload the satellite, simply use:
Copy code
sudo systemctl daemon-reload sudo systemctl restart wyoming-satellite.service
That concludes the process.
