Probably not on the one line. Currently shows chance of rain and actual rain for today so it would be a new line with the predicted or possible rainfall for today. I could add one for tomorrow as well and you could configure it for a slot. Just remember there are a finite number of slots (4 each side)
Using a slot to show the predicted amount today would be good.
For the forecast I was thinking more along the lines of:
that looks good. might be getting a little crowded tho. id be happy to not have the % at all if its the only way to get it in. i just think the amount of rain is much more relevant than the percentage chance
It was a pretty quick mock-up without adjusting the spacing to the summary.
I find both values useful but as I said, I have them displayed in another card so no big problem if itâs too much hassle to do.
Well Iâm struggling to work it out not being fluent in Java. Itâs a fâking miracle I worked out the low actuallyâŚ
Ok Iâve got this⌠hang onâŚ
Ok so thanks to all you guys who wanted this in HACS⌠it caused me a LOT of grief because even doing a hard reload and clear cache the old code was like a zombie and it wouldnât reload my changes hence nothing was loaded or working that I changed.
Anyway⌠Just uploaded new version with a rain forecast for today and tomorrow. Check the readme and lovelace example for the new code.
Addition 1
entity_pop_intensity: sensor.bom_gosford_rain_today
entity_possible_today: sensor.bom_gosford_possible_rainfall_0
Configure the slots:
slot_l1: daytime_high #daytime_high
slot_l2: daytime_low #wind
slot_l3: wind #visibility but BOM has no visibility reported
slot_l4: sun_next #sun_next
slot_r1: pop #pop
slot_r2: humidity #humidity
slot_r3: possible_today #pressure but BOM has no pressure reported
slot_r4: sun_following #sun_following
NOTE: Only showing Today there but you can show tomorrow as well⌠personally I think thatâs voodoo but thatâs just meâŚ
When you are doing local changes delete the gz file in the same dir, if it exist hacs will serve that.
Now Iâve worked it out, I might see if I can add the other ones and show them as you indicated⌠not sure I can - probably above my pay grade but Iâll see.
Ok Tom⌠you asked for it and it wasnât as hard as I expectedâŚ
You will need to edit lovelace config as per the docs but suffice to say you need to have these lines in there.
entity_pos_1: sensor.bom_gosford_possible_rainfall_1
entity_pos_2: sensor.bom_gosford_possible_rainfall_2
entity_pos_3: sensor.bom_gosford_possible_rainfall_3
entity_pos_4: sensor.bom_gosford_possible_rainfall_4
entity_pos_5: sensor.bom_gosford_possible_rainfall_5
YES I renamed the entity for tomorrow as per the above.
Let me know what you think. This is release 0.3
Works perfectly. Thanks very much David.
Excellent. Iâm getting some odd html and I just pushed a fix but have not released it yet⌠just waiting to see. A refresh âfixesâ it anyway but weâll see if I need to push it or not soon.
Glad it works.
Yeah that. I have fixed it temporarily by hard wiring the mm - but itâs also a little bigger. I just need to work out how to use a class in the java script there but itâs not cooperating.
Version 0.33 âfixesâ it for now while I sharpen my js skills.
So Iâm seemingly too stupid to fix this as no matter what I try it seems reluctant to apply the class as anything other than text hence the error. I also noticed todayâs rainfall that I show in slot R1 shows mm in uppercase as well when it ârefreshesâ
So I donât know what to do yet. Iâll probably release 0.34 soon that will have larger units (supporting units other than mm) and that might be it without help from a guru that can show me how to apply the units class to the unit for this and also the current rainfall.
@DavidFW1960 - awesome work to bring this all together. Finally, a decent looking weather card for BOM.
Was wondering if you may be able to allow a card title? I have 2 weather cards, one for my home, and one for where I surf, about 120kmâs away. Would be great to allow a title so I know which is which.
The title
parameter appears to do nothing to the card at all.
Now - this is interestingâŚ
Not only am I going to use this - I donât have to change a thing! Gosford weather covers Kincumber just fine thank you very much
@DavidFW1960 - A fellow coastie! Howâs that!
Hi Andrew⌠I can take a look but unlikely. With my media view I use a markdown card in a vertical stack like thisâŚ
- type: markdown
content: ' '
title: Google Media Players
That will do what you want.
