Yes, that is correct, I could do that, however, would it not show the numbers as: high/low? (the low now being in bold?). I’ll admit, I haven’t tried it, but, I suspect that’s what it would do. I prefer my forecast to look like the attached image. If you felt so inclined to add an option for this, that’d be great, otherwise, I’ll just keep tweaking the code with each new update. I appreciate your work!
Yeah it will always bold the second one. It’s probably not a difficult change. I will take a look and see.
ok. Can you pull master instead of 0.82 and add a flag
tempformat: highlow
and then it will show this:
If it is working for you then I will push an update.
Empty cache and hard reload and ctrl+r a few times…
OH CRAP… hang on… I need another change cos when it refreshes it reverses again…
ok I fixed that. it should work as you want now. Please let me know.
DAMN I need to push to master… DONE.
once more… when it refreshes after 30 seconds it sticks now… that was harder than I expected lol.
Ok, I have it installed, and, so far so good. I will keep a close eye on it and make sure and let you know if I notice a problem. This is, really, truly, awesome. Thank-you so much for your work. I’ve been looking for something like this for so long. I can’t understand why the default weather card is so limiting. This has allowed me to combine my personal weather station, for current info, with the National Weather Service information for forecasting.
I’ve got some spare time to switch over to Brendan’s BoM component today. So any changes to this procedure you would recommend?
- Remove BoM custom component (Old core BoM integration).
- Remove existing BoM templates.
- Install Brendan’s BoM integration.
- Restart.
- Configure BoM integration.
- Add new templates.
- Add new BoM weather radar card.
- Restart.
Pretty much Tom. If you look on my github for an updated package etc you can then just search and replace my city for yours and it should just work. If you did install a previous version of Brendans integration delete that as well and restart HA. He changed some sensor names… I updated all the docs, templates etc today.
David
Just wanted to say thanks for your hard work on this card (and prior versions) really useful here in Sydney.
Cheers
Rob
could you show us your config?
got the sensors working , but i can not get the UI to work
TA
LeeB
I did not get around to doing this yet.
Have a look at David’s configuration.
If you get any sensor name wrong in here the card will not show at all. I had a lot of fun finding my typo when I changed over.
thanks … some debugging (##) identified the problem…
all my issues have been caused by BOM being dropped due to scrapping etc …
now to fix the simple weather card !!! arrghh
Thanks all for your work. I have installed the custom component within HACS and also BOM but I am getting the error: Platform error sensor.bom_forecast - Integration ‘bom_forecast’ not found.
Any tips? Thank you!
All the sensor names have changed in the new integration
Add the repo as a custom repo in HACS and install the Bureau of Meterology component.
Restart HA
Add Bureau of Meterology integration, enter lat/long and finish. You should then get a bunch of sensors.
Hmm I’m not seeing the changed sensors.
I have
sensor.sydney_olympic_park_wind_speed
sensor.sydney_olympic_park_temperature
sensor.sydney_olympic_park_temperature_feels_like
etc
runing version 0.8 via HACS on HA 0.117.4
you need to remove the integration, restart and add the integration back again to see the new names
Thank you for this amazing card. Is there somewhere I can find a bunch of examples I could copy and paste from? I am trying to get rid of this white space but can’t sus it out.
type: 'custom:bom-weather-card'
title: BOM Weather
entity_current_conditions: sensor.carlisle_icon_0
entity_temperature: sensor.perth_airport_temperature
entity_forecast_high_temp_1: sensor.carlisle_max_1
entity_forecast_high_temp_2: sensor.carlisle_max_2
entity_forecast_high_temp_3: sensor.carlisle_max_3
entity_forecast_high_temp_4: sensor.carlisle_max_4
entity_forecast_high_temp_5: sensor.carlisle_max_5
entity_forecast_icon_1: sensor.carlisle_icon_1
entity_forecast_icon_2: sensor.carlisle_icon_2
entity_forecast_icon_3: sensor.carlisle_icon_3
entity_forecast_icon_4: sensor.carlisle_icon_4
entity_forecast_icon_5: sensor.carlisle_icon_5
entity_forecast_low_temp_1: sensor.carlisle_min_1
entity_forecast_low_temp_2: sensor.carlisle_min_2
entity_forecast_low_temp_3: sensor.carlisle_min_3
entity_forecast_low_temp_4: sensor.carlisle_min_4
entity_forecast_low_temp_5: sensor.carlisle_min_5
entity_summary_1: sensor.carlisle_short_text_1
entity_summary_2: sensor.carlisle_short_text_2
entity_summary_3: sensor.carlisle_short_text_3
entity_summary_4: sensor.carlisle_short_text_4
entity_summary_5: sensor.carlisle_short_text_5
entity_daily_summary: sensor.carlisle_extended_text_0
entity_sun: sun.sun
locale: en
static_icons: false
tooltip_bg_color: 'rgb( 75,155,239)'
tooltip_border_color: orange
tooltip_border_width: 3
tooltip_caret_size: 10
tooltip_fg_color: '#fff'
tooltip_left_offset: -12
tooltip_width: 100
tooltips: true
old_daily_format: false
time_format: 24
show_beaufort: true
show_decimals: false
temp_top_margin: 0px
slot_l1: remove
slot_l2: remove
slot_l3: remove
slot_l4: remove
slot_l5: remove
slot_r1: remove
slot_r2: remove
slot_r3: remove
slot_r4: remove
slot_r5: remove
Check the github repo for additional variables to set.
I have install the Bureau component with HACS, did the integration but could not see any new sensors. Just now I did update of the component in HACS and getting message in notifications:
Invalid config
The following integrations and platforms could not be set up:
* bureau_of_meteorology.sensor
* bureau_of_meteorology.weather
Please check your config.
Is there anything I have to add to my config? What am I missing?
Thank you
