Ok remove the quotes from the product id.
I also think you want IDN10064 not IDN60901
Great thanks, Iād tried with and without the quotes with no success but changing the IDN did the trick.
Excellent! Yeah itās not all that intuitive and itās different to whatās in the BOM sensor - which is why you werenāt getting any data. I might even slip that graphic into the readme.
In other news the Icon code I changed today appears to work.
Yes the icons are working really well!
Thanks again for all your work.
Same here. After I did a force refresh.
Thanks David.
Edit actually what are the forecast day icons supposed to be?
I have some night some day.
Yep. It was actually really simple once it hit me and I even discovered an error in the original code for a different iconā¦ so itās a bit scary Iām actually starting to work it outā¦ for troubleshooting purposes anyway.
Thereās only a few icons with night versions.
So when the sun goes below the horizon it will pick the night icon if there is one - otherwise it will use the same for both. So 2 of yours (Sat & Sun) are probably partly cloudy but no night icon for the rest.
Yeah I just had a look.
I wonder if itās worth throwing a fiver at mechanical turk or some service like that to create some more?
It would be worth it to me.
I scoured the net for animated svg weather icons and found a few more that came with the original one other people found. There isnāt much around I found.
Well if youāre offeringā¦ I can easily integrate them now I know WTF I am doingā¦
I am.
Iāll have a look for a design service latter tonight.
Do you have a list of icons needed?
Just from the js these are the ones that map to BOM conditions:
The icon used is the second term
'sunny': `${this.dayOrNight}`,
'clear': `${this.dayOrNight}`,
'mostly-sunny': `fair-${this.dayOrNight}`,
'partly-cloudy': `cloudy-${this.dayOrNight}-3`,
'cloudy': 'cloudy',
'hazy': `cloudy-${this.dayOrNight}-1`,
'hazey': `cloudy-${this.dayOrNight}-1`,
'light-rain': 'rainy-1',
'windy': 'cloudy',
'fog': 'cloudy',
'foggy': 'cloudy',
'showers': 'rainy-3',
'shower': 'rainy-3',
'rain': 'rainy-5',
'rainy': 'rainy-5',
'dust': 'cloudy-day-1',
'dusty': 'cloudy-day-1',
'snow': 'snowy-6',
'snowy': 'snowy-6',
'storm': 'scattered-thunderstorms',
'stormy': 'scattered-thunderstorms',
'light-showers': 'rainy-5',
'light-shower': 'rainy-5',
'heavy-showers': 'rainy-7',
'heavy-shower': 'rainy-7',
'tropical-cyclone': 'tornado',
Some of them are compromisesā¦ they are in the /usr/share/hassio/homeassistant/www/icons/weather_icons folder and need static as well as animated versions. There are more there than I am using at the moment and Iāve picked what I think are the best matches.
Hey Dave, are these first two correct:
I may not fully understand but I donāt think I see corresponding icons (animated or static).
That js expression evaluates to day or night and that is the same as the icon name
Yes itās correct - they both use day.svg or night.svg
Ok. I see that now. So it would seem we could do with these extra icons:
hazey-day
hazey-night
rainy-night-1 (rename rainy-1 to rainy-day-1)
windy-day
windy-night
foggy-day
foggy-night
rainy-night-3 (rename rainy-3 to rainy-day-3)
dusy-day
dusty-night
Yeah that would pretty much cover it Tomā¦ Theresā also fiver,com, Upwork.com etcā¦ if youāre looking for outsourcingā¦ (Check your rainy ones though as I see a dupe? Oh you mean the icon nameā¦ yeah)
Actually maybe only one for the wind. Not sure it needs day and night.
Well itās just a moon or a sun right? Itās like cloudy as well. Iāve done the best I can with what I could find but the ones you propose would be great additions and easy enough to add now.
Going through what youāve picked I think youāve made excellent choices.
Yeah cloudy doesnāt need a sun or moon because you wouldnāt be able to see either if it was cloudy
Sure we could put a sun and moon behind the wind or dust icons I was just wondering if it was needed. I might as well ask for them I suppose.
Found a few good prospects on fiver. Writing up some design notes now.
Sounds good Tomā¦ just donāt forget to specify animated as well as static onesā¦ Thanks for the comments re:choicesā¦ itās all so subjective of courseā¦
Hey @DavidFW1960 Iāve been playing around with the card in my setup and love it, wondering if there is a setting to increase the margin between the forecast table and the detailed summary text at the bottom?
Iāve played with the margin settings in the lovelace.yaml and havenāt found one.
Thereās no easy way to do itā¦ itās part of the forecast block rather than a separate block. I can put a blank line before it thoughā¦ done that for the next release. Iāll investigate if I can do it with a new div as wellā¦ I donāt speak fluent js
