Downgrade to the previous version of the integration until the service is implemented. You have 4 or 5 months until the attribute will no longer be supported.
Hi @DavidFW1960 for some reason i do not see an hourly forecast even when choosing the hourly weather entity. I just get one reading. how do i see the hourly forecast?
Ibelieve a change in home assistant broke this and the bom weather integration needs an update
Love the BOM Integration and that Platinum Card. Iām trying to find the chance of rain sensor to add to the card but canāt find it in the BOM integration. Has anyone managed to get this to work or do I need another weather integration for this data? I can see the % on the BOM website but canāt find it in the integration. Thanks in advance.
Itās definitely in the integration - maybe itās a sensor you need to enable in the configuration
Thanks for the quick reply. I canāt seem to find it. I have 98 entities with the BOM integration and non of them appear to be rain chance in a % or any number. There also isnāt any hidden sensors I could enable.
I check the attributes too of the entities and I canāt see a rain chance or likely hood anywhere. Do you have that BOM integration and possibly show me what Iām looking for?
I have 131 - so quite a few more than 98. Rain data is 32 sensors, rain_amount_min_0 through _7, rain_amount_max_0-_7, rain_amount_range_0-_7 and rain_amount_chance_0-_7.
Sounds like you are missing all of those?
Maybe the data isnāt present for your location? BOM does not supply every entity for every site, but Iād expect rain forecast data to be there.
thanks. That is a very good point. Iāll try putting in Melbourne location rather than my suburb and see what it comes back with.
ok that was itā¦ When I put in lat and long for Melbourne it came back with 163 sensors. So more than my standard suburb closest station. Thanks everyone for the advice and feedback.
Does anyone know how to get rain probability from the BOM data?
I was using a template like this, but it stopped working in a recent update.
{{ state_attr(āweather.bomā, āforecastā)[0].precipitation_probability }}
The data must still be in the BOM entity, as if I use a HACS weather card, itās able to show the rain probability.
Replace <your_location>
Today
{{ states('sensor.<your_location>_rain_chance_0') }}
Tomorrow
{{ states('sensor.<your_location>_rain_chance_1') }}
Hmm. Interesting, I donāt have those entities. Iām guessing I may need to re-configure my location again to pull them in. Thanks for the point in the right direciton.
I have noticed a big change in the available hourly forecast data in version 1.3.0 compared with 1.1.21. and I see from above discussion that may be to do with non-station locations. This is what the older version returned:
and the newer version is much truncated:-
![image|690x322](upload://4qN
How do we go about restoring the missing data?
Canāt see your second photo but if itās like mine, the attributes under forecast are missing? Iāve been trying to access via templates and canāt find any way to do so.
I tried previous versions back to 1.2.3 and tried other locations to see if it was just my station, but still not working.
I opened an issue on GitHub but the only reply was that it was only me, and it was closed. If this is the same issue as you have, and you never resolved it, please post and say itās not just me.
Otherwise, if youāve fixed it, could you let me know how?
I have never been able to fix it. I figured a new version would come along some day but has not happened so far. Same issue, all of the forecast attributes are missing.
And no different if an actual Station is used.
I will post in the github link as well.
Maybe I am just not understanding how the new config should be setup.
This is my 2nd image.
It is odd that clicking on the info button lets you see the forecast, which means the data is there, but we canāt access it in any way.
Even my card is broken since the updates. I have missing data there.
Here is my card config
- Entity_forecast_max: sensor.camberwell_temp_max_0
card_config_version: 8
entity_apparent_temp: sensor.melbourne_olympic_park_temp_feels_like
entity_extended: sensor.camberwell_extended_text_0
entity_fire_danger: sensor.camberwell_fire_danger_0
entity_forecast_icon: sensor.camberwell_icon_descriptor_0
entity_forecast_icon_1: sensor.camberwell_icon_descriptor_1
entity_forecast_max_1: sensor.camberwell_temp_max_0
entity_forecast_min: sensor.camberwell_temp_min_0
entity_forecast_min_1: sensor.camberwell_temp_min_1
entity_pop: sensor.camberwell_rain_chance_0
entity_pop_1: sensor.camberwell_rain_chance_1
entity_pos: sensor.camberwell_rain_amount_range_0
entity_pos_1: sensor.camberwell_rain_amount_range_1
entity_summary: sensor.camberwell_short_text_0
entity_summary_1: sensor.camberwell_short_text_1
entity_sun: sun.sun
entity_temperature: sensor.melbourne_olympic_park_temp
entity_todays_fire_danger: sensor.camberwell_fire_danger_0
entity_todays_uv_forecast: sensor.camberwell_uv_category_0
entity_wind_bearing: sensor.melbourne_olympic_park_wind_direction
entity_wind_gust: sensor.melbourne_olympic_park_gust_speed_kilometre
entity_wind_speed: sensor.melbourne_olympic_park_wind_speed_kilometre
old_daily_format: false
option_time_format: 24hour
option_tooltips: true
section_order:
- overview
- extended
- slots
- daily_forecast
slot_l1: daytime_high
slot_l2: daytime_low
slot_l3: wind
slot_l4: pressure
slot_l5: sun_next
slot_l6: remove
slot_l7: remove
slot_l8: remove
slot_r1: possible_today
slot_r2: humidity
slot_r3: uv_summary
slot_r4: fire_danger_summary
slot_r5: sun_following
slot_r6: remove
slot_r7: remove
slot_r8: remove
type: custom:platinum-weather-card
Not sure what I have wrong there either.
