### Describe the issue you are experiencing
After I installed the latest versio…n (5.4.0) for the File Editor I get "unknown tag" error with the "!include" and the "!secret" values. If I run a Configuration check, it gives no error, so the config files are OK, but the File Editor doesn't recognizes th3 "!include" and "!secret" values.
### What type of installation are you running?
Home Assistant OS
### Which operating system are you running on?
Home Assistant Operating System
### Which add-on are you reporting an issue with?
File editor
### What is the version of the add-on?
5.4.0
### Steps to reproduce the issue
1. Update File Editor from version 5.3.3 version to 5.4.0
2. Open any configuration file in Home Assistant
3. The first "!xxxx" kind of value is tagged as "unknown"
4.
![2022-09-07 18_52_19-Microsoft Text Input Application](https://user-images.githubusercontent.com/33165356/188935653-276ec243-82dd-44ce-a7b8-f6eca8137a9f.jpg)
### Anything in the Supervisor logs that might be useful for us?
```txt
Nothing
### Anything in the add-on logs that might be useful for us?
```txt
Nothing
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun configurator (no readiness notification)
s6-rc: info: service legacy-services successfully started
INFO:2022-09-07 18:34:05,464:hass_configurator.configurator:Starting server
INFO:2022-09-07 18:34:05,465:hass_configurator.configurator:Listening on: http://0.0.0.0:8099
INFO:2022-09-07 18:34:19,233:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2022-09-07 18:34:19,919:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2022-09-07 18:34:19,934:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2022-09-07 18:34:20,048:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:34:20,088:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:34:20,494:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2022-09-07 18:34:21,328:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:34:21,535:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/config/sensor.yaml HTTP/1.1" 200 -
INFO:2022-09-07 18:34:21,784:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2022-09-07 18:35:19,003:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/config/configuration.yaml HTTP/1.1" 200 -
INFO:2022-09-07 18:35:39,123:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2022-09-07 18:35:39,799:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2022-09-07 18:35:39,817:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2022-09-07 18:35:39,967:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:35:39,998:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:35:40,456:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2022-09-07 18:35:41,045:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:35:41,185:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/config/configuration.yaml HTTP/1.1" 200 -
INFO:2022-09-07 18:35:41,426:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2022-09-07 18:35:56,587:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2022-09-07 18:35:57,093:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2022-09-07 18:35:57,106:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2022-09-07 18:35:57,295:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:35:57,310:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:35:57,360:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2022-09-07 18:35:58,675:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:35:58,842:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/config/configuration.yaml HTTP/1.1" 200 -
INFO:2022-09-07 18:35:59,064:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2022-09-07 18:38:24,916:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
WARNING:2022-09-07 18:38:32,304:hass_configurator.configurator:Exception getting release
WARNING:2022-09-07 18:38:32,305:hass_configurator.configurator:<urlopen error [Errno -3] Try again>
Exception occurred during processing of request from ('172.30.32.2', 37968)
File "/usr/lib/python3.9/socketserver.py", line 683, in process_request_thread
self.finish_request(request, client_address)
File "/usr/lib/python3.9/socketserver.py", line 360, in finish_request
self.RequestHandlerClass(request, client_address, self)
File "/usr/lib/python3.9/socketserver.py", line 747, in __init__
self.handle()
File "/usr/lib/python3.9/http/server.py", line 427, in handle
self.handle_one_request()
File "/usr/lib/python3.9/http/server.py", line 415, in handle_one_request
method()
File "/usr/lib/python3.9/site-packages/hass_configurator/configurator.py", line 878, in do_GET
self.wfile.write(bytes(html, "utf8"))
File "/usr/lib/python3.9/socketserver.py", line 826, in write
self._sock.sendall(b)
BrokenPipeError: [Errno 32] Broken pipe
INFO:2022-09-07 18:38:36,550:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2022-09-07 18:38:37,661:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2022-09-07 18:38:37,677:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2022-09-07 18:38:37,907:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:38:37,921:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:38:38,209:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2022-09-07 18:38:38,571:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:38:39,617:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/config/configuration.yaml HTTP/1.1" 200 -
INFO:2022-09-07 18:38:39,845:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2022-09-07 18:45:30,651:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2022-09-07 18:45:31,395:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2022-09-07 18:45:31,409:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2022-09-07 18:45:31,558:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:45:31,588:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:45:31,924:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2022-09-07 18:45:32,682:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:45:32,841:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/config/configuration.yaml HTTP/1.1" 200 -
INFO:2022-09-07 18:45:33,067:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2022-09-07 18:51:49,144:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2022-09-07 18:51:49,858:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2022-09-07 18:51:49,882:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2022-09-07 18:51:50,014:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:51:50,050:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:51:50,506:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2022-09-07 18:51:51,124:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:51:51,285:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/config/configuration.yaml HTTP/1.1" 200 -
INFO:2022-09-07 18:51:51,505:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2022-09-07 18:54:32,499:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2022-09-07 18:54:33,239:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2022-09-07 18:54:33,263:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2022-09-07 18:54:33,375:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:54:33,427:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2022-09-07 18:54:33,850:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
### Additional information
_No response_
