Excellent detailed step by step explanations Marius, thanks! I think only thing missing is
customizer:
custom_ui: hosted
in configuration.yaml
With your help, I got CustomUI working (I upgraded to 0.81.6 and I had the customization_glob wrong). Not sure, which one solved it.
However, unfortunately neither icons nor colors are changing still. So sad.
Do you have to be on the default template to have it working? I’m on dark orange.
No, I dont use that. You only need to use 1 setup method of the possible ones. I use the automatic setup using the .update.sh and download the custom-ui files locally. If you use the hosted setup, the files are read from the custom-ui server.
Not sure at you mean here, but I take it you’re referring to a theme? That shouldn’t have to do anything with custom-ui.
One thing important: if the sensors are template sensors, most of the customizing is done in the sensor declaration, and not via custom-ui.
Not sure if you posted that already, but what type of sensor are you trying to customize, please show (make a screenshot) the sensor on the dev-state page?
Heya Marius, it finally works!
I have tried so many things and installed, uninstalled and reinstalled CustomID, upgraded Hassio and various addons that I’m not sure why or how it started to work. But finally it does. Very happy indeed.
Thanks for all your help and patience!
ok.
I don’t know about person yet, so best ask others about that.
State won’t be customizable any longer, until a new way has been developed.
icon and icon_color still work, at least in 87.1
again, if person is customizable I wouldn’t know. Have seen issues in Lovelace with state filters on sensors and device_trackers too, so I could very well be Not Yet…
