I am trying to use the examples above to completely hide icon and the title, to keep only buttons for target temperature using climate entity but cannot reach the result. Any one with a little time to provide me with card mod code please?
using following yaml, I could achieve the following, but need to edit CSS directly to get rid of the icon background and the tiny icon.
icon: none
Olivier1974
(Olivier Toussaint)
December 9, 2023, 11:40am
22
Please open a new thread, this is not related to my initial question.
I have an answer for you but I’ll give it in the new thread, for other people to find it when needed.
“Customize” is not make it transparent?
Olivier1974
(Olivier Toussaint)
December 9, 2023, 1:49pm
24
No, the customization was about changing the icon color, solved in post 2.
What you’re asking is to remove the title and icon completely, which is a totally different card-mod code.
ok, thank you for your help
R_A_L_F
December 13, 2023, 4:37pm
26
How can I change the icon background color if the quantity is greater than 0?
This way it does not change.
Olivier1974
(Olivier Toussaint)
December 13, 2023, 4:42pm
27
Look at the solution.
Icon background is
.icon-container .icon$: |
.shape {
background: something !important;
R_A_L_F
December 13, 2023, 4:50pm
28
Thanks, but this doesnt’ work:
type: tile
entity: sensor.Fenster_AnzahlOffeneFenster
tap_action:
action: navigate
navigation_path: /lovelace/fenster-turen
icon: mdi:door-sliding-lock
name: Anzahl offener Fenster/Türen
show_entity_picture: false
icon_tap_action:
action: navigate
card-mod:
style:
.shape {
{% if states(config.entity) | float(0) > 0 %}
background-color: var(--red-color);
{% else %}
background-color: var(--grey-color);
{% endif %}
What am I doing wrong here? Sorry, I’m not that fit in YAML yet
Olivier1974
(Olivier Toussaint)
December 13, 2023, 4:56pm
29
My config, working
type: tile
entity: binary_sensor.zigbee_ping
icon: mdi:z-wave
hide_state: true
card_mod:
style:
.shape {
background:
{% if is_state(config.entity, 'on') %}
rgba(0,255,0,0.15)
{% else %}
rgba(255,0,0,0.15)
{% endif %} !important;
EDIT: I should write it another way (sorry Ildar_Gabdullin)
type: tile
icon: mdi:z-wave
hide_state: true
card_mod:
style:
.shape {
background: rgba(0,255,0,0.15) !important;
{% else %}
background: rgba(255,0,0,0.15) !important;
{% endif %}
R_A_L_F
December 13, 2023, 4:58pm
30
Thanks. You are asking an on/off question. How can I compare the number to > 0?
Olivier1974
(Olivier Toussaint)
December 13, 2023, 5:00pm
31
Replace is_state(config.entity,'on')
with states(config.entity) | float(0) > 0
R_A_L_F
December 13, 2023, 5:03pm
32
Like this?
card_mod:
style:
.shape {
background:
{% if states(config.entity) | float(0) > 0) %}
rgba(0,255,0,0.15)
{% else %}
rgba(255,0,0,0.15)
This doesnt work.
R_A_L_F:
This doesnt work.
check your templates in Dev tools → Templates
joeyar
(Joey)
September 24, 2024, 1:52pm
36
For anyone like myself who struggled to get this working. This worked perfectly for me
card_mod:
style: |
{% if states('switch.pool') == 'on' %}
ha-card {
background: lightblue;
ha-state-icon {
color: white;
ha-tile-icon {
--tile-color: var(--state-icon-color);
{% else %}
{% endif %}
You can also change var(–state-icon-color) to a color like white, or leave blank and it removes the icon background.
naamah75
(naamah75)
December 22, 2024, 6:01pm
37
I would like to remove the tile icon background, I tried all the solutions in this thread but I can’t!
as you can see, if I force the background-color of .shape::before, the result is what I want, but using card-mod the changes seem to be ignored!
naamah75:
card_mod:
style: |
ha-tile-icon {
--tile-icon-opacity: 0 !important;
Hello
This works for me when tap_icon_action isn’t set, but when it is, the background colour comes back, have you noticed this?
