Last ESPHome update introduced “color_interlock” to the RGBW and RGBWW light components, which gives you the same result as using better_rgbww_output.h.
Take a look: https://esphome.io/components/light/rgbw.html#rgbw-color-interlock
Yeah one of the recent updates wrecked my instance of “better_rgbww”. But when I stripped this custom work out and used it like a standard light it works great, even with CW and WW too! I think some changes must have gotten added on github to solve this perhaps.
Here’s my (new) working 0.114.4 hass code for the same bulb:
# Define output pins
output:
- platform: esp8266_pwm
pin: GPIO5
pin: GPIO4
pin: GPIO13
pin: GPIO12
pin: GPIO14
# Define a light entity
light:
- platform: rgbww
gamma_correct: 2.8
red: output_red
green: output_green
blue: output_blue
cold_white: output_cold_white
warm_white: output_warm_white
cold_white_color_temperature: 5000 K
warm_white_color_temperature: 2700 K
effects:
- flicker:
alpha: 95%
intensity: 2.5%
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 60s
Wow! Thank you! Less complicated. Bad for the time invested to make better_rgbww. Just one question… Maybe you know… Is there a possibility to hide the white bar since it is useless?
So far, not that I’m aware of…
Thanks so much for sharing!
