Worked for me too. Many thanks.
Has anyone else had a problem with 0.92.2?
For my checklist:
- I retrieved the
binary_sensor.py
anddlink.py
from the Feb 23 post by @postlund. - I placed both in
\home\homeassistant\.homeassistant\custom_components\dlink_motion_sensor
. - I added an empty file named
__init__.py
in thedlink_motion_sensor
folder. - I have this in my config:
# Binary Sensors
binary_sensor:
# Ring
- platform: ring
# D-Link Motion Sensor
- platform: dlink_motion_sensor
host: !secret motion_sensor_host
password: !secret motion_sensor_password
# Ping
- platform: ping
host: !secret ping_host
count: 2
scan_interval: 5
When I comment out or remove the motion sensor in the config, everything is fine. When I add it back I receive 500 Internal Server Error Server got itself in trouble
. My guess is that thereās an issue with the component; since the config worked before. Do I need some sort of boilerplate in the __init__.py
Where do you see the internal server error? You should have a stacktrace somewhere, wonāt be possible to debug without it.
Mon May 06 2019 11:27:29 GMT-0600 (Mountain Daylight Time)
Error handling request
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/real_ip.py", line 33, in real_ip_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 68, in ban_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/auth.py", line 216, in auth_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/view.py", line 115, in handle
result = await result
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/config/core.py", line 21, in post
errors = await async_check_ha_config_file(request.app['hass'])
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/config.py", line 824, in async_check_ha_config_file
res = await check_ha_config_file(hass) # type: ignore
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/scripts/check_config.py", line 389, in check_ha_config_file
platform = p_integration.get_platform(domain)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py", line 139, in get_platform
"{}.{}".format(self.pkg_path, platform_name)
File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 986, in _gcd_import
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 669, in exec_module
File "<frozen importlib._bootstrap_external>", line 775, in get_code
File "<frozen importlib._bootstrap_external>", line 735, in source_to_code
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/home/homeassistant/.homeassistant/custom_components/dlink_motion_sensor/binary_sensor.py", line 7
<!DOCTYPE html>
SyntaxError: invalid syntax
Here we go. I thought for a moment after looking at this that maybe the detectorās IP address had changed. But no, it is still the same.
OMG! never mindā¦
Dang!
I use the save link as in github. Of course that saved the whole html page not just the file⦠sorry /facepalm
Yeah, you did
Hi there, just a quick message to convey my thanks. Iāve been using home assistant as an end user for about a year now, but I havenāt got much programming skills, so this is just my way of contributing I guess. Your custom integration for the motion sensor works very well and was very usefull in my home situation!
Just summarizing for other people who would be interested: Put the two files from github in the config folder under ācustom_components/dlink_motion_sensorā. Then add an empty file called "__init__.py"
to the same folder, otherwise it wonāt work. Then reboot HA. Lastly, add this to the configuration.yaml:
binary_sensor:
host: dlink_motion_sensor_ip_address
The password should be the pin code that comes with the sensor.
If you use Hassio reboot system, not only HA. (menu: Hassio -> System -> Reboot). Iāve spent hours to solve this issue :).
Not working on 94.4 for anyone else?
It works in 0.94.4 as before.
Nevermind got it working. Just needed a power cycle
Iām now finding that after every HA restart or update i need to power cycle the motion sensor for it to work again
Iām still stuck at this error. On 0.95 here.
āIntegration dlink_motion_sensor not found when trying to verify its binary_sensor platform.ā
Thank you for the summary, this was really helpful. However I have one question, is there a way of retrieving the pin code if you cannot remember it? I do have the sensor setup in the dlink app and IFTTT if that helps me?
Itās on the back of the sensor. At least on the two units I have.
Thank you very much, the plug did have the pin!
I noticed today at 12:03 pm a sensor triggered and 12:09 pm another sensor triggered in home assistant, as we arenāt home right now I thought thatās strange but then I checked the Dlink app for both of these sensors and it shows these times but they show up as yesterday the 20th and none triggered today. Strange as these 2 sensors only triggered once today at these 2 times. Bit of a coincidence.
Could this be a bug in the code? At first I thought maybe I was reading the home assistant log incorrectly but I was not mistaken.
Does anyone know if this has happened to them, I wonder if it has something to do with it being just after 12.
is anybody still using this with Home Assistant 0.105.3?
I pulled down the 3 files from GitHub, tried different folders but then gives me error after the add to the configuration.yaml
in which path you guys have the 3 files? is it still compatible with 0.105.3?
thanks
I use it and it works.
where did you put the 3 file .py?
