Researching this a bit further made me aware that I need to use Visual Studio to get this working? Right? I need to run that remotely since my HA system is on a Raspberrypi which can not run VS (tried to use the add-on but it says no). So Have VS running on my Macbook. Tried to get it connected to the HA machine but do not get any connection. (created the requested key). Tried to add a repo VSCode Remote which might help but that is only giving errors when trying to install in HA add-on.
How to get this all working? Why is HA so complicated? Any help would be appreciated thanks!
Vscode is not req, as an aside I have it running on a pi as an addon. You need to modify apps.yaml
located /config/appdaemon/apps/apps.yaml
under hello world you would add
DahuaMQTT:
class: DahuaMQTT
module: dahua_mqtt
cameras:
- host: 192.168.4.108
port: 80
user: username
pass: password
retain: true
topic: cameras
events: CrossRegionDetection,CrossLineDetection,VideoMotion,LeftDetection
Programming is linear, there isnât room for extra/miss placed characters. As code executes, once it hits something it doesnât understand everything kinda halts.
Thanks for the feed back. I cant get the code editor to work. So, If I am on the server with ssh where can I find the mentioned files? I do not have any folder named /config as far as I can see? See my file-tree on the picture. the config folder in the tree I created manually⌠Will copy it over to the HomeAssitant folder.
What type of installation ha os? docker? vm? When you install the appdaemon addon it should create that folder. Is appdaemon running? what do the appdaemon logs say?
System.
The deamon is running I can open it.
2022-07-14 16:51:01.331254 DEBUG AppDaemon: get_state: thread.thread-0.None None True
2022-07-14 16:51:01.332558 DEBUG HASS: Utility
2022-07-14 16:51:01.333905 DEBUG AppDaemon: set_state(): sensor.appdaemon_uptime, {'state': '2 days, 3:07:35'}
2022-07-14 16:51:01.335583 DEBUG AppDaemon: parse_state: sensor.appdaemon_uptime, {'state': '2 days, 3:07:35'}
2022-07-14 16:51:01.337067 DEBUG AppDaemon: Old state: {'entity_id': 'sensor.appdaemon_uptime', 'state': '2 days, 3:07:34', 'last_changed': '2022-07-14T16:51:00+02:00', 'attributes': {}}
2022-07-14 16:51:01.338501 DEBUG AppDaemon: New state: {'entity_id': 'sensor.appdaemon_uptime', 'state': '2 days, 3:07:35', 'last_changed': '2022-07-14T16:51:01+02:00', 'attributes': {}}
2022-07-14 16:51:01.339758 DEBUG AppDaemon: sending event locally
2022-07-14 16:51:01.341526 DEBUG AppDaemon: Util loop compute time: 19.0ms, check_config()=8.0ms, other=11.0ms
2022-07-14 16:51:01.343343 DEBUG AppDaemon: Event type:state_changed:
2022-07-14 16:51:01.344810 DEBUG AppDaemon: {'entity_id': 'sensor.appdaemon_uptime', 'new_state': {'entity_id': 'sensor.appdaemon_uptime', 'state': '2 days, 3:07:35', 'last_changed': '2022-07-14T16:51:01+02:00', 'attributes': {}}, 'old_state': {'entity_id': 'sensor.appdaemon_uptime', 'state': '2 days, 3:07:34', 'last_changed': '2022-07-14T16:51:00+02:00', 'attributes': {}}}
2022-07-14 16:51:01.345947 DEBUG AppDaemon: process_event_callbacks() admin {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.appdaemon_uptime', 'new_state': {'entity_id': 'sensor.appdaemon_uptime', 'state': '2 days, 3:07:35', 'last_changed': '2022-07-14T16:51:01+02:00', 'attributes': {}}, 'old_state': {'entity_id': 'sensor.appdaemon_uptime', 'state': '2 days, 3:07:34', 'last_changed': '2022-07-14T16:51:00+02:00', 'attributes': {}}}}
2022-07-14 16:51:01.348196 DEBUG AppDaemon: thread_async loop, args={'function': <bound method ADStream.process_event of <appdaemon.stream.adstream.ADStream object at 0xb51af340>>, 'args': ({'event_type': 'state_changed', 'data': {'entity_id': 'sensor.appdaemon_uptime', 'new_state': {'entity_id': 'sensor.appdaemon_uptime', 'state': '2 days, 3:07:3
The log is showing a lot of info
Then search the ha folder for appdaemon or apps.yaml
, it has to be in there somewhere already.
So I added the dahua app into the apps folder and now it appears into the Appdaemon. Nice. Still do not see any camera related topics in mqtt so have to figure out what is missing⌠getting there I hope. I finally want to have the alarm from the SMD human - vehicle detection to control a light or push message. The detection works since I have some video recordings already when a person walks in camera sight. Which yaml setting should I use for that? AlarmOutput
: or does SMD has a special output available? Thanks.
I have all yaml files in place but still not getting it to work. Seems that there is an error thrown from the dahua_mqtt yaml file
The beginning of that file has a commented out section that shows what needs to be placed in apps.yaml, did you modify the example in dahua_mqtt.yaml
? it shouldnât be modified, you can delete the file and just copy a new one into the directory.
I have /had that exact file in place. But generating a lot of errors. So I have included it again this is what the error log shows:
The instance that I am running this on is an older version, Iâm wondering if that has something to do with it. Although the first error about âapps.yamlâ seems like there is a formatting error. Check your spacing and no extra spaces after entries.
If that doesnât work try the dahua integration in hacs. Try https first it may work, if not http.
I checked the app.yaml and the dahua_mqtt.yaml with validator. The app.yaml is ok now but the dahua_yaml is not ok and seems not to apply to (newer) yaml validate rules (tabs where spacing is needed). Maybe some one who has the experience can validate the dahua_mqtt yaml on github or publish it here :).
So we can use it in newer version of HA/ Appdaemon.
The other option you mentioned is also worth while checking out. But I prefer this solution because of the mqtt publishing which I wanted to use.
dahua_mqtt
is written in python, not yaml so you canât go by a yaml validator
Your right my mistake. I now changed in into the .py but still generating errors now the problem seems to be âpycurlâ which can not be installed.
I have installed that manually:
pi@raspberrypi4:~ $ sudo pip install pycurl
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pycurl in /usr/local/lib/python3.9/dist-packages (7.45.1)
pi@raspberrypi4:~ $
So it should be available in the system. Tried to leave import pycurl out but that throws other errors depending on it.
When I start/restart appdaemon you should see the build sequence as shown below. There should be specific packages aside from pycurl that show missing. You have to add them to the list on the appdaemon config. Then youâll need to look if the packages you add have dependencies.
Goto below to search the missing packages.
For those who are still using this â i believe there are a few, Ive had numerous issues every time ive done an appdaemon update, fiddling with the packages in order to get pycurl to install.
I did a re-write late last week using the python requests module, and after ~72 hours of operating it seems to be behaving as expected.
I have mine setup via a DVR with only a single entry, so cant 100% confirm if it works with multiple standalone cameras, but if anyone is keen to test it please DM me and ill share the link
For anyone having issues after updating AppDaemon recently, I managed to get it working after updating a couple of libraries.
Check here for details. Appdaemon 0.13.0 and curl-dev
You couldnt post your AppDaemon config as i cant get mines to start anymore since last update
i tried adding the stuff from the link but it still fails
Paul
