PoE, 1080P, HD, VTO2201F-P
what do you mean by āimageā?
Yes I am
version: '3'
services:
dahuavto2mqtt:
image: "registry.gitlab.com/elad.bar/dahuavto2mqtt:latest"
container_name: "dahuavto2mqtt"
hostname: "dahuavto2mqtt"
restart: "unless-stopped"
environment:
- DAHUA_VTO_HOST=192.168.1.30
- DAHUA_VTO_USERNAME=myuser
- DAHUA_VTO_PASSWORD=MyPassword
- MQTT_BROKER_HOST=192.168.1.53
- MQTT_BROKER_PORT=1883
- MQTT_BROKER_USERNAME=myusername
- MQTT_BROKER_PASSWORD=MyPasswd
- MQTT_BROKER_TOPIC_PREFIX=DahuaVTO
- MQTT_BROKER_CLIENT_ID=DahuaVTO2MQTT
- DEBUG=True
when was the last time you have tried to update it?
seems that it is not the latest based on the logs
pls ignore, i do see the same log and same error in my log as well, will work on it
just to make sure we or on the same version, if you restart the docker container, can you see the following log message:
__main__ Starting DahuaVTO2MQTT, Version: 2023.12.26.30509
yes!
2024-03-04 23:22:05,872 INFO __main__ Starting DahuaVTO2MQTT, Version: 2023.12.26.30509
Could you take a look at my error too please?
sure, hope to get to it during the weekend
DahuaVTO2MQTT v2024.03.08.60699
Whatās New:
- Fix message parsing issues - Dahua RPC protocol deliver chunked messages, it depends on OS and other variables.
- Query the device with bulk messages (up to 20 in a call) to optimize proces
- Added much more configurations being extracted from device and being published over MQTT
User with non-Dahua-branded devices:
Please try this version, hope it will solve it for you as well and fully support all devices using the same API.
Plans for additional features:
- Multiple Dahua devices using configuration file (rather environment variables for one device)
- Auto-discovery of additional devices
- Set configuration in devices (instead of Web UI of Dahua devices)
- Supporting all features available in UI over MQTT and/or HA.
Willing to test it! Thanks!
Trying the latest version (2024.03.08.60699) on a Lorex 2K Doorbell (B451AJ) and it doesnāt seem to be publishing any āeventsā to MQTT, just configuration info.
I enabled debug and I can see it publishing to Dahua/Device/magicBox.* (I have customized my broker prefix to be just Dahua), but I get nothing else. I believe your docs state that events such as motion should be <broker_prefix>/VideoMotion/Event, but I see no such events ever getting fired at all.
Let me know if you want me to send you any of the debug logs. Iām assuming this did work at some point in time as I have found past posts about people getting these doorbells working, but Iāve also found info about firmware updates changing things on these (and the Dahua/Amcrest) doorbells.
I can also see back in Oct '23 you mentioned you werenāt officially supporting non Dahua VTO devices, but the latest post you mentioned about non Dahua branded devices seems like youāre now asking people to try it out - so I did.
I cannot test device that I donāt own, some people found out it can work for non Dahua branded devices and thatās greatā¦
I will enable devug mode at my place and check if such events are getting and will update,
But just to be sure, you donāt get any warning or error messages, ājustā not receiving set og events related to magicBox, is that correct?
I did notice some errors, and it might be in the parsing of the event but I wasnāt certain if they were related or not when I was looking at all the output. They only show on debug.
Thereās a lot that happens, and Portainer was only showing me 100 lines so Iāll have to get it to log everything as an event should trigger. Since thereās a lot of info, Itāll take me a bit to get you a sanitized copy to look at. Iāll see if I can get you something in the next day or two. Thx!
As an FYI, I donāt mind helping you testā¦ but just know Iām not a python programmer so my help might be a bit limited. Iād love to get this device working though - even just for doorbell button presses.
logs should do the work if there are error / warning messages
I have finally been able to check mine also, it seems mine is the same, I canāt see anything in MQTT and logs seem to suggest itās not working at all. As for logs from portainer I see this:
2024-03-23 03:50:11,533 ERROR clients.DahuaAPI Failed to handle message, Data: b' \x00\x00\x00DHIP\xa8\x0c\xbf7\\\n\x00\x00F\x00\x00\x00\x00\x00\x00\x00F\x00\x00\x00\x00\x00\x00\x00{"id":2652,"params":{"timeout":55},"result":true,"session":935267496}\n', Error: Failed to read data: id":2652,"params":{"timeout":55},"result":true,"session":935267496}, Error: Extra data: line 1 column 15 (char 14), Line: 123
2024-03-23 03:52:06,348 INFO clients.DahuaAPI Server sent EOF message
2024-03-23 03:52:06,348 INFO clients.DahuaClient Disconnected, will try to connect in 5 seconds
Got around to getting the debug output. Sanitized private info; if any of it is necessary for your debugging, let me know what you need.
DahuaVTO2MQTT debug output (github.com)
[edit] I forgot to mention - in the debug output there should be a motion event (nothing else) recorded, but as youāll see nothing was fired.
Dear @bar just tested your latest release (Version: 2024.03.26.31526
With the older version ( 2023.12.26.30509
) I always got a call notification after rebooting the Docker container. Which was the main issue.
Now I get no notifications at all, even when someone rings the bell.
Hereby the log:
2024-03-27 12:29:11,633 INFO __main__ Loading DahuaVTO2MQTT configuration, Version: 2024.03.26.31526
2024-03-27 12:29:11,634 INFO clients.BaseClient Initialize MQTTClient
2024-03-27 12:29:11,634 INFO clients.BaseClient Starting to connect MQTTClient, Should connect: True
2024-03-27 12:29:11,634 INFO clients.BaseClient Initialize DahuaClient
2024-03-27 12:29:11,634 INFO clients.BaseClient Starting to connect DahuaClient, Should connect: True
2024-03-27 12:29:12,634 INFO clients.MQTTClient MQTT Broker is trying to connect...
2024-03-27 12:29:12,635 INFO clients.DahuaClient Connecting
2024-03-27 12:29:12,638 INFO clients.MQTTClient MQTT Broker connected with result code 0
2024-03-27 12:29:12,729 INFO models.DahuaDevice Type: DHI-VTO2201F-P
2024-03-27 12:29:12,730 INFO models.DahuaDevice Version: 4.600.0000000.0.R
2024-03-27 12:29:12,730 INFO models.DahuaDevice Build Date: 2022-08-13
2024-03-27 12:29:12,781 INFO models.DahuaDevice Access Control Instance ID: 70082336
2024-03-27 12:29:12,781 INFO models.DahuaDevice Serial Number: 9C072E4PAJDCDBA
2024-03-27 12:29:12,844 INFO models.DahuaDevice Hold time: 15
2024-03-27 12:53:02,909 INFO __main__ Loading DahuaVTO2MQTT configuration, Version: 2024.03.26.31526
2024-03-27 12:53:02,910 INFO clients.BaseClient Initialize MQTTClient
2024-03-27 12:53:02,910 INFO clients.BaseClient Starting to connect MQTTClient, Should connect: True
2024-03-27 12:53:02,910 INFO clients.BaseClient Initialize DahuaClient
2024-03-27 12:53:02,911 INFO clients.BaseClient Starting to connect DahuaClient, Should connect: True
2024-03-27 12:53:03,911 INFO clients.MQTTClient MQTT Broker is trying to connect...
2024-03-27 12:53:03,911 INFO clients.DahuaClient Connecting
2024-03-27 12:53:03,913 INFO clients.MQTTClient MQTT Broker connected with result code 0
2024-03-27 12:53:04,019 ERROR clients.DahuaAPI Failed to handle message, Data: b':"dhdtb.bin.img"}},"ProductInfo":null,"ProductName":"DH_VTOXXXXD-G-S2_MultiLang_PN_PAAS_SIP_EMEA_V4.600.0000000.0.R.220813","PushMobileManager":{"PushMobileMaxRoomNum":500,"PushMobileMaxUserEachRoom":10,"PushMustVTHOnline":true,"SupportPushBindingSN":false,"SupportPushMobile":false},"PwdSpeci":{"CharList":"~!@#$%^","Combine":2,"Limit":[8,32],"Type":["Number","Lower","Upper"]},"PwdUpdatePeriod":{"CustomRange":[1,180],"PeriodList":[0,30,60,90,180],"SupportPwdUpdatePeriod":false},"RemoveAnonymous":true,"ReservedConfigs":["Network","IPv6","WLan"],"ResetPwd":{"PubVer":"17101800","Support":true},"RestoreExceptConfigList":{"RestoreExceptConfig":["Network"]},"Revision":0,"SSHD":{"Support":true},"SecretQuestionPath":"\\/mnt\\/data\\/question.txt","SecurityBaselineVersion":"V2.2","ShowLogo":false,"SmartType":"None","SpecVer":"PAAS","SupportCheckAdminGroup":true,"SupportCloudUpgrade":true,"SupportDebugInfoRedir":true,"SupportDevInit":true,"SupportExportEncrypedLog":true,"SupportLoginAuthCtrl":true,"SupportMaskSensitiveInfo":{"CurrentConfig":true,"DefaultConfig":true},"SupportMediaEncrypt":true,"SupportPwdRandSalt":true,"SupportSafetyAbnormalAlarm":true,"SupportSetLockAuthority":true,"SupportSetUnLockLocation":true,"SupportSubMCUUpgrade":true,"SupportVideo":true,"SystemService":{"Support":true},"TypeVersion":"R","UPnP":true,"UPnPSupport":{"PortReuse":true},"UpdateCheckLanguage":false,"VSP":"SIP","VSP_CGI":{"Support":true},"VTOPath":"\\/mnt\\', Error: 'unicodeescape' codec can't decode byte 0x5c in position 1447: \ at end of string, Line: 108
2024-03-27 12:53:04,020 ERROR clients.DahuaAPI Failed to handle message, Data: b'/mtd\\/Config\\/","Vendor":"Dahua","VendorAbbr":"","VideoInCrop":{"Support":true},"VideoInputChannels":1,"VideoOutputChannels":0,"VideoStandards":["PAL","NTSC"],"VideoTalkCaps":{"Protocol":["SIP"],"SIP":{"Class":"VTO","SupportSIPRoute":false},"Support":true,"SupportVTHPaaS":true,"maxOuterNetClientCount":5000},"Web":{"FTP":false,"QRcodeInNetwork":true,"SDEvents":true,"SafetyAbnormalAlarm":false,"SupportVTODBSyncButton":true},"WebStringFiles":["webEN.lang","webEN.lang","webDU.lang","webFR.lang","webDe.lang","webIT.lang","webPT.lang","webRU.lang","webSpl.lang","webTR.lang","webUK.lang","webArb.lang","webES.lang","webPbr.lang"],"WebVersion":"2.4","XSSBlockList":["VideoAnalyseRule"],"setVideoStandardNeedReboot":false}},"result":true,"session":1981763296}\n', Error: Failed to read data: {"id":7,"params":{"definition":{"3G":false,"ACSCaps":{"DBMainPath":"\/var\/tmp\/Database\/","GeneralPsdLenLimit":[6,6],"UserMaxFingerprintCount":3},"AOLCaps":{"Caps":{"SupportDeviceID":true,"SupportDeviceType":true,"SupportDiagnosis":true,"SupportDownLoadLog":true,"SupportModifyIP":true,"SupportReboot":true,"SupportSoftRest":true,"SupportUpgrade":true,"SupportVersion":true},"DGS":{"SupportDelAllInfo":true,"SupportDelInfo":true,"SupportReport":true},"Support":true},"AllDevicesName":"VTOXXXXD-G-S2","AllLanguages":["English","BritishEnglish","SimpChinese","TradChinese","TradChinese2","Dutch","French","German","Italian","Polish","Portuguese","Russian","Spanish","Turkey","Ukrainian","Arabic","Vietnamese","SpanishEU","PortugalBR","Japanese","Romanian","Hungarian","Finnish","Estonian","Korean","Farsi","Dansk","Czechish","Bulgaria","Slovakian","Slovenia","Croatian","Greek","Swedish","Serbian","Lithuanian","Filipino","Catalan","Latvian","Hebrew","Thai"],"Area":"Xiou","AudioInputChannels":1,"AudioOutputChannels":1,"BuildDate":"2022-08-13","BuildDateTime":"2022-08-13 11:09:10","ContainAllAuthority":true,"CustomDemand":"Dahua","CustomLanguages":null,"DB":"DB2","DEBUG":"NONE","DGS":{"SupportDelAllInfo":true,"SupportDelInfo":true,"SupportReport":true},"DH2EventFilter":{"FilterAll":false,"FilterTable":[29]},"DVRIP_TLS":{"DVRIP_TLS":true},"DataBaseZip":{"BackZip":true,"MainZip":false,"TempZipEnable":1},"DefaultLanguage":"English","DefaultVideoStandard":"PAL","DevStringFiles":["StringsEn.txt","StringsEn.txt","StringsDu.txt","StringsFr.txt","StringsDe.txt","StringsIt.txt","StringsPt.txt","StringsRu.txt","StringsSpl.txt","StringsTr.txt","StringsUk.txt","StringsArb.txt","StringsSp.txt","StringsPbr.txt"],"Device":"VTO2201F-P","EnableExtLockByConfig":true,"EncodingResolutionLimit":[["720P","WVGA","D1","CIF"],["1080P","WVGA","D1","QVGA","CIF"],["720P","WVGA","D1","CIF"]],"FLASH":"128M","Faceboard":{"NumericKey":false,"ShiftKey":false},"FileMapRules":[{"FileType":"openSourceNoticeFile","RealPath":"\/mnt\/data\/Strings\/StringsOpenSourceNotice\/openSource.txt","VirtualPath":"\/openSource.txt"},{"FileType":"privacyPolicyFile","RealPath":"\/mnt\/data\/Strings\/StringsPrivacyPolicy\/","VirtualPath":"\/privacyPolicy\/"},{"FileType":"softwareLicenseFile","RealPath":"\/mnt\/data\/Strings\/StringsSoftwareLicense\/","VirtualPath":"\/softwareLicense\/"}],"FilePathManager":{"BuiltInPath":[{"Path":"\/mnt\/sd"}],"Enable":true,"UploadFilePath":[{"Path":"\/mnt\/mtd\/CustomSound\/"},{"Path":"\/mnt\/data\/Strings\/StringsOpenSourceNotice\/"},{"Path":"\/mnt\/data\/Strings\/StringsPrivacyPolicy\/"},{"Path":"\/mnt\/data\/Strings\/StringsSoftwareLicense\/"}]},"Gamma":true,"HTMLStringFiles":["webEN.json","webEN.json","webDU.json","webFR.json","webDe.json","webIT.json","webPT.json","webRU.json","webSpl.json","webTR.json","webUK.json","webArb.json","webES.json","webPbr.json"],"HasPtz":false,"IPTableFilter":{"RulesNum":64,"SemiConnectAttack":true,"Support":true},"Inell":"None","IsGeneralRecord":false,"IsLocalStore":false,"IsLocalurgentStore":false,"IsPtzAlarm":false,"Languages":["English","BritishEnglish","Dutch","French","German","Italian","Portuguese","Russian","Spanish","Turkey","Ukrainian","Arabic","SpanishEU","PortugalBR"],"LegalinfoCaps":{"openSourceNotice":true,"privacyPolicy":true,"softwareLicense":true},"Login":"2","MajorVersion":4,"MaskConfigWhiteLists":["SIP","NAS","VTHRemoteIPCInfo","VTOCallLiftInfo","AccessControlGeneral"],"MaxExtraStream":1,"MaxGroup":8,"MaxRemoteInputChannels":0,"MaxStreamSendBitrate":32768,"MaxUsers":5000,"MediaCallBackCaps":{"AudioEnable":true,"VideoEnable":true},"MinorVersion":600,"MixLightSolution":{"LightingScheme":["InfraredMode"],"Support":true},"ModelDiff":[{"CustomValue":{"UpdateCheckLanguage":false},"DevName":"VTO4202F-P-S2"},{"CustomValue":{"UpdateCheckLanguage":false},"DevName":"VTO2202F-P-S2"},{"CustomValue":{"UpdateCheckLanguage":false},"DevName":"VTO2201F-P"}],"NeedCreateExtra3VideoEncoder":false,"NolockLocalUser":true,"OEMVersion":"0000000","OSDAllStreamDisplay":true,"OnlySupportSingleAuthority":true,"OnvifAuthorityCheck":false,"OnvifForceSync":true,"OuterNetRegistrationPeriod":{"AfterRegistered":60},"PackName":"DH","PassWordLimit":[8,32],"PasswdFindWay":"BC","PresetPwd":true,"Private":{"PatitionSwitchUpgrading":{"PartitionImageName"/mtd\/Config\/","Vendor":"Dahua","VendorAbbr":"","VideoInCrop":{"Support":true},"VideoInputChannels":1,"VideoOutputChannels":0,"VideoStandards":["PAL","NTSC"],"VideoTalkCaps":{"Protocol":["SIP"],"SIP":{"Class":"VTO","SupportSIPRoute":false},"Support":true,"SupportVTHPaaS":true,"maxOuterNetClientCount":5000},"Web":{"FTP":false,"QRcodeInNetwork":true,"SDEvents":true,"SafetyAbnormalAlarm":false,"SupportVTODBSyncButton":true},"WebStringFiles":["webEN.lang","webEN.lang","webDU.lang","webFR.lang","webDe.lang","webIT.lang","webPT.lang","webRU.lang","webSpl.lang","webTR.lang","webUK.lang","webArb.lang","webES.lang","webPbr.lang"],"WebVersion":"2.4","XSSBlockList":["VideoAnalyseRule"],"setVideoStandardNeedReboot":false}},"result":true,"session":1981763296}, Error: Expecting ':' delimiter: line 1 column 4313 (char 4312), Line: 123
2024-03-27 12:53:04,024 INFO models.DahuaDevice Type: DHI-VTO2201F-P
2024-03-27 12:53:04,025 INFO models.DahuaDevice Version: 4.600.0000000.0.R
2024-03-27 12:53:04,025 INFO models.DahuaDevice Build Date: 2022-08-13
2024-03-27 12:53:04,068 INFO models.DahuaDevice Serial Number: 9C072E4PAJDCDBA
2024-03-27 12:53:04,068 INFO models.DahuaDevice Access Control Instance ID: 70082336
2024-03-27 12:53:04,170 INFO models.DahuaDevice Hold time: 15
I think youāre closer! Thanks again!
