Daikin BRP072C42 WIFI custom component
Hey @nzhook!
I’m the maintainer of pydaikin and the Daikin integration. It would be great if we could integrate your changes into the main Daikin integration.
Please send a pr on https://bitbucket.org/mustang51/pydaikin/ and I’ll try to merge it as soon as possible. (I believe that we only need minor changes in the Daikin integration after that.)
Edit:
I’ve started a branch with support for the BRP072C42 controller:
https://bitbucket.org/mustang51/pydaikin/branch/BRP072C42#diff
The idea is that we generate an UUID at HA side and pass that together with the KEY during init. Something like this: https://github.com/home-assistant/core/compare/dev...fredrike:daikin-BRP072C42
The changes are untested so beaware :slight_smile:.
The new config is:
daikin:
  hosts:
  - host: 192.168.1.123
    key: ABCD  # only used by BRP072Cxx
