I have a few Daikins with wifi controller. I had to add them manually with their IP address.
I can’t assign them a static IP address, so every time there is a power outage or modem reset, they get a new IP address, meaning that I have to remove them in HA and add them again.
Is there a solution for this?
If not, could the configuration logic be modified to also accept a mac address?
I have the same issue. Even when reserved due some malfunction the device sometimes gets new IP resulting in the same problem (remove & add in HA). May be some issues in daikin or my zyxel multy but this connection can be problematic sometimes.
I would also appreciate solution that is not based on static IP.
