Daikin Heat pump Altherma Integration
You might find this video helpful. This is how I set up my Daikin Integration.
Speak to the Geek
Thank you Michael. I have managed to connect using the Daikin Onecta integration but have been unable to get the Daikin_Altherma integration to work. I’ll give that one a bit more time and see if there are any improvements / updates that help.
Hello, I have the following problem: My Altherma is connected to Home Assistant via the BRP069A61. Everything works fine with one exception: When my automation (controlled via better thermostat) switches off the heat pump (because it is warm enough inside) but it is still quite cold outside, the pump switches on again. I can’t do anything via the integration to switch the pump off again. Even manual switching via the integrations GUI makes no difference.
Does anyone know what setting I need to make in the Altherma menu to ensure that it is really off? By the way, my heat pump is also shown as “off” in the Onecta app even though it is running. my indoor unit is an EHVX08S23EJ9W, the outdoor unit is a 6kw split unit.
Thanks in advance
Dirk
