Daily Zigbee Coordinator Backup Blueprint - ZNP - ezsp/bellows
I’ve started support for EZSP/Bellows, but it looks like the ZHA Integration does not have the code yet to back up to "open-coordinator-backup’ format yet.
But it’s a start.
Edit:
The backup procedure makes an export to “open-coordinator-format”, but does not have the devices list, which should not be critical. Puddly recommends to use the use the CLI utility instead if you’re migrating.
Hi All.
I’ve had the disaster scenario happen where my sonoff ZHA bridge stopped communicating to HA. I had 29 devices added to it. Before deleting it from HA and then re-adding I used this blueprint to backup the configuration.
I have the bridge back up and running but I cant see where I can restore the backup I made?. Is it suppose to happen automatically once I re-added the bridge to HA?.
It’s not automatic - you can find some instructions here :
