with the cold season approaching, I am also setting up my Ally TRVs
I am using ZHA, so I adapted @oveandâs version with the following two changes:
Went back to the original way of delaying because my automations were not triggering due to last_triggered being unknown. Not sure if this is now fixed; but I ran the automations manually once and that seemed to take care of the problem
Use a selector to only select the Danfoss TRV devices and extract the IEEE from the device
Thanks for this, it helps a lot to understand how things work.
I have a question though, that it might be obvious but is not for me. What is the reason for multiplying the temperature of the external sensor with 100 and sending this to the TRV? That means that instead of e.g., 25.17, we send 2517. Iâve actually noticed that then the TRV takes this value as is for its âexternal_measured_room_sensorâ. Is it just how this variable is encoded?
How did it work in âsingleâ mode? Iâm using this (adapted for zigbee2mqtt) and it works well but I noticed sometimes it misses an update which I think is caused by a temperature based trigger coming immediately after a time based trigger like you described.
Now that I think of it, I guess I could also add a trigger so that it updates if the external measured temperature changes to -8000 which would be something of a backstop if everything else fails.
Iâm going to write to Danfoss with some feedback and suggestions too because I think the thermostat should fall back to the non-covered radiator mode for 3 hours (well 2.5) if the external temperature isnât updated within 30 minutes in covered mode because at least then it would still reference the external sensor to some extent if thereâs a temporary loss of communications.
I also noticed that it seems to ignore the external sensor when I set âvertical orientationâ to true.
I would also like to know whether the adaptation uses the external temperature when in covered mode (it should!)
Iâve been wondering why my place is so cold - and why my TRVs are not taking my external temperature sensor into account. It turns out that there is a bug in the automation I posted above. I was a bit surprised that Home Assistant does not make it very obvious if an automation fails. I had to go into the traces section to see that thereâs a problem.
The problem was a missing variable declaration for the danfoss_trv input. This caused the last node with the call to set_zigbee_cluster_attribute to fail!
Updated blueprint:
# https://community.home-assistant.io/t/danfoss-ally-1-18-set-external-temperature-to-radiator-covered-trv/380219/15
blueprint:
name: Danfoss Ally TRV 1.18 - Set external temperature
description: Set external measured temperature to Danfoss Ally TRV firmware 1.18 with Radiator Covered = true
domain: automation
input:
danfoss_trv:
description: This is Danfoss Ally climate TRV entity with firmware 1.18 and Radiator Covered = true
selector:
device:
model: eTRV0100
temperature_sensor:
name: Temperature sensor in Celsius
description: This sensor acts as external temperature sensor for your Ally
selector:
entity:
domain: sensor
device_class: temperature
automation_entity:
name: Automation entity_id
description: This automation entity_id (only low case, underscores)
default: "automation.new_automation"
selector:
entity:
domain: automation
variables:
temperature_sensor: !input temperature_sensor
danfoss_trv: !input danfoss_trv
- platform: state
entity_id: !input temperature_sensor
- platform: state
entity_id: !input automation_entity
attribute: last_triggered
for:
hours: 0
minutes: 30
seconds: 0
condition:
- condition: numeric_state
above: "0"
- choose:
- conditions:
- condition: trigger
sequence:
- choose:
- conditions:
- condition: template
value_template: >-
{{ (utcnow()|as_timestamp -
this.attributes.last_triggered|as_timestamp)/60 <5 }}
sequence:
- delay:
minutes: >-
{{ 5 - (utcnow()|as_timestamp -
this.attributes.last_triggered|as_timestamp)/60 }}
default: []
default: []
- delay:
seconds: "{{ range(1, 21)|random }}"
- service: zha.set_zigbee_cluster_attribute
ieee: "{{ (device_attr(danfoss_trv, 'identifiers') |list).0.1 }}"
endpoint_id: 1
cluster_id: 513
attribute: 16405
cluster_type: in
value: "{{ (states(temperature_sensor) | float * 100) | round(0) }}"
mode: restart
When I remove the blueprint and the automation - I get this error on reboot of Home Assistent
Invalid config for [automation]: Failed to load blueprint: Unable to find luka6000/danfoss-ally-1-18-set-external-temperature-to-radiator-covered-trv.yaml (See /config/configuration.yaml, line 121).
18.58.10 â (FEJL) components/blueprint/models.py - beskeden forekom først kl. 18.35.01 og ses 12 gange
18.58.10 â (FEJL) components/blueprint/models.py - beskeden forekom først kl. 18.35.00 og ses 12 gange
I use the configuration script in another script so that I can repeat/adjust the configuration whenever needed (in visual mode you can easily select the valve and change the settings):
With regards to the remote temperature blueprint, you should select 5 minutes when in covered mode and 30 minutes in remote mode. IMHO covered mode is also recommended in situations where you radiator is not covered but when the remote temperature is lagging a lot on the local temperature or not very stable vs. the local temperature.
I have one automation for each TRV to link the remote temperature to the TRV.
Also, when the remote temperature is a zigbee device, the more 0.01°C precision temperature is retrieved by performing a read from cache (provided by zha_toolkit). While the absolute precision is worse, I do this so the TRV gets information about the delta changes in temperature to help adjust its regulation.
There is also a trick to let the automation know when a new temperature was received from the thermometer - even if it is only 0.01°C.
Finally there is a script to start the adaptation run.
This is supposed to have the TRV determine its regulation settings.
It was not straightforward to ensure that the device does not consider itself as adapted, but this automation does it.
You should not change the TRVâs settings until after the adaptation process is finished (which takes up to 3 hours or so according to the documentation).
One of the things I found the TRV to do is to increment the valve percentage 5% by 5%.
After triggering this automation, the TRV is set into mounting mode (which opens the valve completely to facillitate mounting). You need to press the TRV button for a second or so to exit the mounting mode - youâll hear the internal motor move to close the valve. The automation waits for this step (there is a repeat loop) and then initiates the adaptation run. The actions can be observed by listening on the âzha_doneâ event or by checking /config/csv/danfoss_adaptation_run.csv .
Hello le_top, may u explain how to use your zha based blueprints? I am new to home assistant, installed zha and activated it in configuration.yaml, copied your blueprints into blueprints folder, but i only get the following error âInvalid blueprint: required key not provided @ data[âblueprintâ]. Got Noneâ.
@Klausi You may have copied some scripts.
The blueprint files have âblueprint:â near the head and this is what Home Assistant is looking for.
The error message indicates this is missing.
Once you have the blueprint, you can add an automation using it.
Further above, I give an example of how to use the configuration script which is not a blueprint - you can add the script using the UI and call that script from another script.
In the example I show how to configure several valves by calling the configuration script.
When i try to call it, it gives me the following error:
Setup/Configure DANFOSS VALVES: Error executing script. Service not found for call_service at pos 1: Unable to find service script.conf_danfoss_ally
Maybe zha-toolkit is too powerful and nothing for beginners? I just the functionality to set parameters of the trvs, which i had with z2m before, back. Is it also possible, to set load balancing with 2 or more trvs with zha-toolkit?
Very nice explanation, now i understand that it didnt work, because the first script doesnt found the other one, because of the entity name. THANK you. Thats what i wanted to achieve.
Am I correct that with this, as with any scheme where there is an external thermometer updating the TRV at a relatively high rate, that battery consumption will be significantly higher?
Iâm assuming that with these TRVs (mine are Danfoss Ally), a âthermostaticâ mechanical element inside the device makes the real-time valve adjustments, and the motor moves that assembly according to the desired setpoint - in the same way that the big knob does on traditional TRVs.
Whereas with external sensing on an electronic unit, the effect of the external input is to âadjust the knobâ at relatively high frequency in order to outsmart the thermostatic element - thereby using the battery each time.
