I agree, with @BikingViking that my devices must have come with 1.12 pre-installed. This is the most reasonable explanation.
I did some changes to my setup:
Changed Zigbee-Channel from 25 to 11 and also switched my 2.4 ghz wifi from lower channels to upper channels.
exchanged my CC2652P stick with a conbee 2
With this I did not encounter any issues with the Danfoss Allys so far. But since this setup has only been running for a few hours it’s quite early to relax…
I don’t think it’s publicly available yet. It appears some newer devices ship with it, and maybe you can update to it through their own bridge, but their website only has the 1.08 version listed.
@atus wrote them some days ago requesting a copy, but I don’t know what the output was from that.
With that said, I don’t know what the improvement would be with 1.12, so until I know that, I am not in a hurry.
I was using Danfoss’ own bridge until last week, and 1.08 was indeed the latest available there too. (I remember it automatically suggested a firmware update shortly after buying the set last November, which probably upgraded my TRVs to 1.08 back then.)
I just spoke to the Danish customer support. Very friendly. Here is the explanation: There is no functional difference between 1.08 and 1.12. They only changed some debug options to allow their factory to test something so they didn’t publish it.
A new version is coming out soon, mid November and the support person said that would be published.
P.S. don’t even try with Norwegian Danfoss support, no reply to email for 2 weeks and on the phone they were just dismissing me to go talk to a technician because they don’t deal with private persons.
Mine is keeping very hard to go with the set temp 22.5. Any suggestion how to tweak it? running 1.18 and have external temp sensor, and set covered to true.
Hi @massaquah ,
is your setup working good?
I am having the same issue (HA doesn’t set the target temperature on devices) using a zigbee dongle from Itead and ZHA.
My POPP TRVs updated to firmware 1.20, I guess the same will be the same for Danfoss/Hive etc. Has anyone seen any release notes for this and the cluster specification?
