Dashboard Loading Error
the i can only hope that @aimc has an idea how to solve this.
Decided to start from scratch today using the docs including the initial test. The test failed to run HADashboard.
I’m at a loss to what i could be doing wrong at this point and can only assume its to do with running on Synology.
Command Ran:
docker run --rm -it -p 5050:5050 \
  -e HA_URL="<HA_URL value>" \
  -e HA_KEY="<HA_KEY value>" \
  -e DASH_URL="http://IP:5050" \
  acockburn/appdaemon:latest
Output:
2017-10-21 10:10:25.086538 INFO AppDaemon Version 2.1.10 starting
2017-10-21 10:10:25.086711 INFO Configuration read from: /conf/appdaemon.yaml
2017-10-21 10:10:25.351185 INFO Starting Apps
2017-10-21 10:10:25.466198 INFO Got initial state
2017-10-21 10:10:25.466576 INFO Loading Module: /conf/apps/hello.py
2017-10-21 10:10:25.467385 INFO Loading Object hello_world using class HelloWorld from module hello
2017-10-21 10:10:25.590774 INFO hello_world: Hello from AppDaemon
2017-10-21 10:10:25.591433 INFO hello_world: You are now ready to run Apps!
2017-10-21 10:10:25.591514 INFO App initialization complete
2017-10-21 10:10:25.591678 INFO Starting dashboard
2017-10-21 10:10:25.593466 WARNING ------------------------------------------------------------
2017-10-21 10:10:25.593556 WARNING Unexpected error in dashboard thread
2017-10-21 10:10:25.593627 WARNING ------------------------------------------------------------
2017-10-21 10:10:25.615723 WARNING Traceback (most recent call last):
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py", line 401, in __init__
    raise ValueError('Not a directory')
ValueError: Not a directory
  File "/usr/local/lib/python3.6/site-packages/appdaemon/rundash.py", line 318, in run_dash
    setup_routes(conf.dashboard_obj)
  File "/usr/local/lib/python3.6/site-packages/appdaemon/rundash.py", line 288, in setup_routes
    app.router.add_static('/compiled_javascript', dashboard.compiled_javascript_dir)
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py", line 845, in add_static
    follow_symlinks=follow_symlinks)
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py", line 404, in __init__
    "No directory exists at '{}'".format(directory)) from error
ValueError: No directory exists at '/conf/compiled/javascript'
2017-10-21 10:10:25.615877 WARNING ------------------------------------------------------------
2017-10-21 10:10:25.615972 INFO API is disabled
2017-10-21 10:10:25.690218 INFO Connected to Home Assistant 0.55.2
create the dirs:
/conf/compiled/css
/conf/compiled/html
und make sure that appdaemon has writing access to those dirs.
Ok its official i’m a fool. I finally found the cause of my problem i had not filled in entity_ids correctly for some of the widgets. It seems i’m back up and running once again.
Thank you so much for sticking with me @ReneTode
your welcome.
