I’ll try to explain a few things I think I’ve learned, maybe it’ll help. TL;DR is at the end.
There are two “purge” options for the Recorder service. (1) Recorder: Purge
allows you to delete all entries older than a given number of days, which you can filter by entity_id and entity_type in addition to the time-based purge. You can also repack the database (recover unused space) after the purge, if you remember to check the box AND turn on the slider. You won’t free up any storage unless you do this.
(2) Recorder: Purge Entities
allows you to delete all of the records for an area, device, entity, domain or glob, or a bunch of those. But I don’t see any repack option, so you’ll want to go back and do that after.
Key points here are that you can be very selective about what and when you delete, and that you won’t recover any space in your database unless you correctly select the repack option.
That all applies to the “old” tables which have been part of the Recorder databaase for a long time; basically, the tables named events and states.
More recently, it was decided that the same database should be used to store permanent statistics data, such as is used by the energy management components. Among others, the statistics table was added. But as far as I can tell, there’s no purge option for this table. Apparently it’s designed to grow forever, so that you’ll always have your full energy use (or whatever) history.
I don’t happen to use HA to analyze my energy use, just to collect the data. So every month I end up deleting over 10,000 rows from this table. It should be noted that I never “opted in” to store this data in the first place; sometime in the past few releases HA created and started populating these new statistics tables without asking.
As far as I can tell, doing a purge and/or repack won’t impact the energy use data stored in these newer tables. The only way to purge them is with an SQL DELETE statement.
