@bhuvan Maybe you have some details in log
which log should I check
@AlexxIT
I pasted
curl -s https://www.dataplicity.com/xxxxxx.py | python
on
and i got the error on the same window after some time.
Check Hass logs. Maybe you block Internet for your Hass server
I pasted just https://www.dataplicity.com/xxxxxx.py
and got
2021-07-29 19:18:28 ERROR (MainThread) [custom_components.dataplicity.utils] Can't register dataplicity device
File "/config/custom_components/dataplicity/utils.py", line 12, in register_device
r = await session.post('https://www.dataplicity.com/install/', data={
File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 619, in _request
break
File "/usr/local/lib/python3.9/site-packages/aiohttp/helpers.py", line 656, in __exit__
raise asyncio.TimeoutError from None
asyncio.exceptions.TimeoutError
on core logs.
Yes. Problem with internet or with Dataplicity server
Dear Alexey,
I have successfully installed your custom component and it works very well for almost everything except that the location updates fail all times. Iâm running Companion App 2022.10.1 (2022.424) on iPhone X running iOS 16.1.1 (and also on my wifeâs iPhone 8 running the same iOS). Event log is full of messages like âDidnât update: location update from the pastâ with âerrorâ: âlocationUpdateTooOldâ and also âWebhook failed with status code 503â and some other. What may be wrong? I appreciate your response.
