we are talking about Theme change based on SUN trigger.
Yes. Sure.
Post the automation so we can help
in any case, use this:
- platform: sun
event: sunrise
- platform: sun
event: sunset
Here
Note, that the below used to work perfectly before the update
event: start
platform: homeassistant
entity_id: sun.sun
platform: state
to: above_horizon
entity_id: sun.sun
platform: state
to: below_horizon
data_template:
name: “{% if states.sun.sun.state == “above_horizon” %}\n Light - Light
\ Red\n{% else %}\n Dark - Light Red\n{% endif %}\n”
service: frontend.set_theme
well, that seems hardly possible… there’s no single spacing in the full automation. you might want to have a look at what’s in the docs and what people post here.
I’ve given you the correct triggers already, in the correct format. Why don’t you start with that and build, using
{% if trigger.event == 'sunrise' %} Sunrise theme name
{% else %} Sunset theme name
{% endif %}
have a look here, for 2 automations to give you an idea how things work:
automation:
- alias: Change current theme
id: Change current theme
platform: state
entity_id: input_select.theme
{{states('input_select.theme')}}
- alias: Sun based theme change
id: Sun based theme change
platform: state
entity_id: sensor.sun_based_theme
condition:
condition: numeric_state
entity_id: sensor.uptime_minutes
above: 1
- service: input_select.select_option
option: >
{{states('sensor.sun_based_theme')}}
- condition: state
entity_id: input_boolean.notify_system
state: 'on'
- service: notify.system
title: >
Ha Rpi4: Sun based Theme
message: >
{{as_timestamp(now())|timestamp_custom('%X')}}:
Sun is {{states('sun.sun')}} and Frontend is set to '{{states('sensor.sun_based_theme')}}'
any idea why this is unsuccessful ?
the theme is not set, nothing change. and no error in the logs
Also not working for me; not sure what is wrong or what changed?
Anyone have a working automation that is in a single automation (not separate)?
Good day, this must be a bug.
this definitely doesnt work.
I’ve set theme to back end selected and does nothing.
Hey,
this one has worked for me for years
- id: theme_change
alias: Theme Change
- platform: homeassistant
event: start
- platform: state
entity_id: sun.sun
to: above_horizon
- platform: state
entity_id: sun.sun
to: below_horizon
- service: frontend.set_theme
data_template:
{% if states.sun.sun.state == "above_horizon" %}
ios-dark-mode-light-blue-alternative
{% else %}
ios-dark-mode-blue-red-alternative
{% endif %}
I want to change the background theme based on my solar production. That is, if I am producing over 5KW theme color changes to green else remains red. Can this be done and if so how. I am aware of sun condition of day/night but that seems embedded with HA and is not what I am after.
