DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
Are you sure? Did you install 1.1.5? I double checked right now and on the homepage it first looks for an room temperature: variable, it that exists the theme uses that. If it doesn’t exists it looks for a climate: and then uses that instead. So temperature: must be leading.
Yes those photos above are from the update 1.1.5 that was installed… as you can see temperature is 23.5 whereas climate temperature attribute is 25… clicking on the master room it is correct but the landing page still shows climate.
Hello.i use traccar with home Assistant…it can show your address. Is it somehow possible to pass this information in person view ? My person contains multiple devices trackers for my presence detection at home
You mean you want to see a map with a marker on it where somebody is?
Okay and you got climate: and temperature: in that room set? Can you show me your rooms.yaml the master room object
Sure
Could you maybe join the EN Slack so I can look into this together with you?
I’d love to see a map for each person too, as I use that quite a bit :wink:
Thank you Dwain, your help on slack fixed my issue… turns out it was something to do with a cache issue…
I’m implementing this in a next update. A map on the person page of the device_tracker. Is that all right for you?
This is what I did with person addons
I appreciate this post. Its a very nice UI. What custom card(s) are you using for the drag down feature at the top and the buttons on the bottom? While I like your UI, I prefer a more custom personal solution for myself.
What do you mean with this? You could join the slack group for chatting live without me on this things :slight_smile:
The custom lovelace cards. I went through the required resources and I’m curious which cards you used to create that functionality. e.g. the card-mod card allows you to edit styles.
to clarify these 2 items:
yes… a small map would be nice… also address if available in attributes of device_tracker
Something like this :slight_smile:
On my touchscreen I have something like this
there is a dynamic_page for this. you can add whatever you want to this card.
I’m encountering the same mod-card error :frowning: Tried in Chrome and Safari. HACS “open URL” button opens up the code for mod-card correctly. I have already tried reinstalling/uninstalling-installing, no change.
I have also commented out as much as my theme config as possible in order to pin down a potential error but no such luck. Your help would be appreciated!
Thank you again so much for this projet :slight_smile:
Dumb question…
How do I add more Lovelace pages, outside of this?
I love this but still would like a different page for a tablet.
I just went into hacs, uninstalled card-mod, then restarted. Once restarted, open hacs and install card-mod again. Suddenly worked for me after doing that.
