Hello, I am rather new to HM, but I got it running without too many problems (none yaml-mode). Now I am working on the visualization, and I found your theme to be very nice! Thank you for all your work in this!
It works fine except one side effect, that I could not solve so far:
Next to Dwains Theme I do have some other Dashboards to play around with. Some of them use HACS additions also to generate custom cards / views.
The problem seems to be, that since installing Dwains Theme these do not work anymore: HACS is showing, that most of the installed additions (Frontend) are not be loaded properly in Lovelace, but not all of them. I think I have tracked it down to the yaml-mode for Lovelace that is activated by Dwains Theme in dwains_theme_configuration.yaml (in packages).
Commenting this line out solves the problem for standard Lovelace but Dwains Theme does not work anymore.
So far I could not solve this, can you give me a hint?
BTW: Is the More page or Dynamic page the right place to include special customized cards?
I have this fixed in my installation. Although not advised, you can edit these two files with the contents of my gists (make sure to remove the top lines. they just make sure you put them in the correct files.):
dwains-theme/views/main/devices/media_players.yaml
dwains-theme/views/main/rooms/room/media_players.yaml
How are you handling the zone cleanup with vacuum?
Usually we have scripts to be called and they can be used on the vacuum card.
Is there any way to put “generic” buttons on the rooms to call scripts?
You can set the mode to yaml in the config file then add all resources by hand in UI (from main.yaml resources folder)
I will add this in a future release, for now maybe look at the vacuum addon on my community addons repository: GitHub - dwainscheeren/dwains-dashboard-addons: Dwains Dashboard Community Addons
Really love the theme! I do have one weird issue. On my Iphone (works fine in browser and Ipad) I get a weather entity error (I use Darksky).
Any thoughts?
Again, computer or Ipad it works fine:
First I want to mention that I really love the theme! Was looking for something simple because I don’t have the time to code and design.
Now I encountered a little error. I’ve created an add-on page for my garbage collector. I want to use some markdown cards to show the information I needed. I’m using this card:
- type: horizontal-stack
cards:
- type: markdown
content: |
<ha-icon icon="mdi:trash-can"></ha-icon>
# Papier
### {{ states.sensor.papier.attributes.days.state }} dagen
- type: markdown
content: |
# Plastic
### {{ states.sensor.plastic.attributes.days.state }} dagen
- type: markdown
content: |
# GFT
### {{ states.sensor.gft.attributes.days.state }} dagen
First thing i’ve noticed is that the add-on page is an vertical-stack card on its own. So I added the " - " before the “type: horizontal-stack”. Now this card works fine outside this theme.
Inside this theme, so in garbage add-on page, it isn’t working. When I add it to the page, Its says Unknown Error when loading lovelace and the loggin says this:
Logger: homeassistant.components.websocket_api.http.connection.23210961561552
Source: dwains-theme/addons/more_page/garbage/page.yaml:9
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 8:30:26 PM (1 occurrences)
Last logged: 8:30:26 PM
Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 21, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/lovelace/websocket.py", line 30, in send_with_error_handling
result = await func(hass, connection, msg, config)
File "/usr/src/homeassistant/homeassistant/components/lovelace/websocket.py", line 72, in websocket_lovelace_config
return await config.async_load(msg["force"])
File "/usr/src/homeassistant/homeassistant/components/lovelace/dashboard.py", line 186, in async_load
self._load_config, force
File "/usr/src/homeassistant/homeassistant/components/lovelace/dashboard.py", line 204, in _load_config
config = load_yaml(self.path)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 61, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File "/usr/local/lib/python3.7/site-packages/yaml/__init__.py", line 114, in load
return loader.get_single_data()
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 51, in get_single_data
return self.construct_document(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 55, in construct_document
data = self.construct_object(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 100, in construct_object
data = constructor(self, node)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 192, in _ordered_dict
nodes = loader.construct_pairs(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 155, in construct_pairs
value = self.construct_object(value_node, deep=deep)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 183, in _include_dir_merge_list_yaml
loaded_yaml = load_yaml(fname)
File "/config/custom_components/dwains_theme/__init__.py", line 159, in load_yaml
return loader.yaml.load(stream, Loader=loader.SafeLineLoader) or OrderedDict()
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 223, in _construct_seq
(obj,) = loader.construct_yaml_seq(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 408, in construct_yaml_seq
data.extend(self.construct_sequence(node))
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 130, in construct_sequence
for child in node.value]
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 130, in <listcomp>
File "/config/custom_components/dwains_theme/__init__.py", line 179, in _include_yaml
return loader._add_reference(load_yaml(fname, args), ldr, node)
File "/config/custom_components/dwains_theme/__init__.py", line 156, in load_yaml
"_d_t_styles": dwains_theme_styles
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "/config/dwains-theme/addons/more_page/garbage/page.yaml", line 9, in top-level template code
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 471, in getattr
return getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'states' is undefined
I guess it can’t handle the way I added the sensor, but why? Is there a way to fix this?
Do you have the code for this, its awesome!
Dwain your theme is brilliant!
Ahh missed that somehow. Thanks!!
I can’t for the life of me get the person images to show.
I have the image setup for my person integration in HA and that works fine.
person.mike:
entity_picture: '"/local/mike.png"'
In the persons.yaml config file, I first copied/pasted the path I use for person.mike and got a broken image. So I tried different variations of ’ and " and same thing. So then I thought maybe the theme doesn’t support png and saved a copy of the file as a jpg. Nothing.
Then I tried creating an images/persons folder inside the theme folder and moved the files there.
picture_path: 'dwains-theme/images/persons/mike.jpg'
Nothing. Found an example in here that didn’t have the dwains-theme in the path so tried that.
picture_path: 'images/persons/mike.jpg'
Still nothing. This should be the simplest step and I can’t for the life of me get it to show the damn image lol
You must put the images in a folder underneath the www folder. Ie: www/images/persons
In the configuration you set the path as /local/images/persons
You shouldnt place the images anywhere else but the www folder.
Forgot to mention you, see my comment above.
/local/ == /www/
And I did try it with www/mike.png as well and it didn’t work. The file is there and it works for the person integration in HA, so it’s something different within the theme that I’m missing
I got this in my persons.yaml:
persons:
- name: Damian
track: person.damian
picture_path: 'images/persons/damian.png'
locally this is the folder: /www/images/persons
Maybe this helps?
That did help! moved www/mike.png to www/images/persons/mike.png and used the same path you listed above and image showed right up. Thank you!
It’s safe to update to HA 0.112 in combination with Dwains Theme 1.4.0, make sure you update all HACS plugins to the latest version.
After loading up this theme, in HACS I get the following:
One of the ones not loaded is the vacuum card
When trying to use that vacuum card with the vacuum addon, I get a “Custom element doesn’t exist: vacuum-card.”
Tips?
I don’t think these resources are added by default. You could try to add them to the following file:
dwains-theme\resources\custom_resources-sample.yaml
Also, see: https://dwainscheeren.github.io/lovelace-dwains-theme/how-tos/custom-cards.html
