Thanks bud!
Just in case some else runs into this, I was using light_groups, when I changed and used groups it gave me the desired result.
Appreciate ya.
Thanks bud!
Appreciate ya.
I use weather data from ‘OpenWeatherMap’. How I can add data from ‘my sensor’ outside my building?
I would like to have this in area - see screen.
Data from ‘my sensor’…
I have setup rooms, and cameras, but I don`t see menu bar (no home, camera, setting).
Top of the browser:
Which HA version do you use? Did you try clearing your browser cache? Did you try to do a HA reboot?
I have the latest version of HA 118.2, installed on 117.6, then updated. What I did was I installed dwains desktop 2.0 and then copied my old room and camera yaml to the config (changed camera yaml to the new type). After reset I saw menu bar for the second, but then It disappeared. I rebooted the HA few times and cleared the cache.
Maybe the problem is Homekit infused theme that I also run.
How do you change the theme? my dashboard looks bland. the background is white, same as room icons.
i see there are 4 themes in the DD install folder…
Theme settings in the dashboard is useless
When i click on theme documentation it goes to https://dwainscheeren.github.io/dwains-lovelace-dashboard/ when serching the page for the word theme, it only appears in the “testimonials” section.
Integrations → Dwains Dashboard → Options
Is it possible to use other cards inside a room?
In the rooms file under page_entities or something like that?
Thank you
hey Dwain,
Very nice work, appreciated that and all works good and fast.
But a have one question
have a nice day
Sven
Depends on where you want to use it? You can create a own addon inside a room or a link to an addon from a room. A custom more page and put in the nav etc, you have 100% freedom to use the restriction card inside those addons. That’s the power of Dwains Dashboard Addons.
Again, I want to thank all people who donated for the 2.0 version release of Dwains Dashboard! I appreciate it a lot! Thank you all
First thanks for your Quick answer.
So to be honest, I don’t know how to Do it because my English is not the best haha. I am gona try to explain it to the best.
My wish would be to press a button to open my garage door and before I could do so I would be asked for a code to avoid accidental pressing. Any help would be greatly appreciated. Thank you.
Sven.
FInally gotten round to updating hass to a high enough version so I could install v2.0 - looking & feeling great!
Mind you, I screwed something up in putting the configs back and got mighty confused between dwains-dashboard and dwains_dashboard folders :-p (and being a linux sysadmin the folder inside should just be called “conf” anyway imho )
I think you did that on purpose to test us - our brains have a tendency to make a small difference like that disappear when you are looking for a problem
But thanks for all the great work - again!
ps: you wrote dekstop instead of desktop in the topic title
Hi Dwain, first of all thank you for your hard work. Really like the way it is working
One small question, as the header (different views) is now placed on the footer it’s sometimes hard, at least for me, to switch the views by a click as also the “virtual” homebutton from my iPhone is on the same place.
So would it be possible to integrate navigation like with https://github.com/maykar/lovelace-swipe-navigation ? I mean on my side i already installed that Frontend Plugin via HACS and it’s working on all my other Dashboards but it’s not working on my mobile phone with your dashboard
Hi guys!
I hope someone can help me. AS you can see from the image, the text of the weather is very long. How can I fix?
Hi question I get in my Dwains Dashboard
How can fix this
Unfortunately no, I think this is a language thing and the name is long in your language.
Check your HA error log
