DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
Hi, this dashboard is really great, and I want to try. But I didn’t found a clear statement regarding the existing configuration. Therefore my question. If I install the Dwains Dashboard, are all my individuals developed dashboards still available? How to strap a try, but w/o any risk for given configs. Thx in advance.
First of all…
BACKUP BACKUP BACKUP and automate the backups
Secondly, I can speak from my experience… YES… you can install it and the other dashboards will be untouched
Thirdly, depending on the user profile settings, your other dashboards may have a theme forced
Thx a lot for your quick response. Of course backup as always, that’s a basic.
Great theme, just installed it and trying to get my head around it, but so far, its winning the thumbs up from the wife, but a couple of issues:
  1. Is it possible to add badges, like on Standard Lovelace, looking to add a couple of badges to know whether a couple of modes are active, don’t need a favourite for them.
    i.e. in the header:
    Screenshot
  2. Cameras are not appearing anywhere, I’ve got them listed in the config, but doesn’t appear to show in the top navigation bar, yaml below:
cameras:
  entities:
    - camera.aarlo_backdoor
    - camera.aarlo_front_door
    - camera.aarlo_garage
    - camera.aarlo_garden
Hoping someone can help, thanks!
1 - I dont know how to but I know the theme author said you can anything anywhere … so maybe someone will chime in
2 - in your cameras.yaml file
Does it have the line 2 commented out or set?
cameras:
  #main_menu: "false" #If you want to hide the cameras in the main nav then enable this line
  #live_view: "false" #If you want to disable live view then enable this line
  entities:
    - camera.blueiris_drivewayhd
    - camera.blueiris_frontdoorhd
    - camera.blueiris_backgardenhd
    - camera.blueiris_frenchdoorshd
Just installed this great looking dashboard and the only strange thing I had that all config files in dwains-dashboard/configs where is dos format (CR/LF) and had to convert them with dos2unix to edit them with vi.
As many of you maybe have read on the HA website (https://www.home-assistant.io/blog/2021/01/22/security-disclosure/) or on my Discord, my dashboard was also one of the custom components that had some security problems.
I patched the bug last week in version 2.0.1. So for everyone who is using my dashboard please upgrade to 2.0.1.
I couldn’t go further into this earlier and I also couldn’t tell at first why I release 2.0.1. and what’s changed in 2.0.1 to give people some time to upgrade in the mean time.
How can I uninstall and fully remove this theme?
Remove the folder dwains_dashboard in your custom_compontents folder. May I ask why you want to remove it? Don’t like it?
they were commented out.
Don’t know why but a couple of hours later the page appeared.
Now trying to get rid of the page, as the camera setup doesnt work with the default card.
@dwains are you able to help me with point 1?
I’ve looked around on your site and github, but nothing about making badges for here.
Thanks!
That isn’t currently possible. To add custom badges there.
I’m back to standard dashboard for all infos and change to HomeKit to control via phone.
Hello all, one question. After the update to 2.0.1, I can no longer access the dashboard because the link in the left navigation is missing. Of course I did everything as described (copy custom components, restart ha, clear browser cache … ), but the link does not appear. I also reinstalled the integration, but no improvement. Where can I start the investigation where the failure is. Any idea?
core-2021.1.5
supervisor-2021.01.7
Home Assistant OS 5.10
Any help is highly appreciated. Thanks a lot in advance.
Did you check your HA error log?
result of cat home-assistant.log | grep dwains
2021-01-24 17:26:24 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-01-24 17:26:53 ERROR (MainThread) [custom_components.dwains_dashboard.process_yaml] while parsing a block mapping
in “/config/dwains-dashboard/configs/rooms.yaml”, line 175, column 5
in “/config/dwains-dashboard/configs/rooms.yaml”, line 188, column 6
2021-01-24 17:26:53 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry for dwains_dashboard
File “/config/custom_components/dwains_dashboard/process_yaml.py”, line 67, in load_yaml
File “/config/custom_components/dwains_dashboard/process_yaml.py”, line 108, in compose_node
File “/config/custom_components/dwains_dashboard/process_yaml.py”, line 106, in compose_node
File “/config/custom_components/dwains_dashboard/init.py”, line 47, in async_setup_entry
File “/config/custom_components/dwains_dashboard/process_yaml.py”, line 170, in process_yaml
File “/config/custom_components/dwains_dashboard/process_yaml.py”, line 70, in load_yaml
2021-01-24 18:23:54 ERROR (MainThread) [frontend.js.latest.202012291] http://192.168.2.240:8123/lovelace/dwains-dashboard:0:0 Uncaught
2021-01-24 18:24:21 ERROR (MainThread) [frontend.js.latest.202012291] http://192.168.2.240:8123/lovelace/dwains-dashboard/start:0:0 Uncaught
Seems like a typo or wrong codeblock in your dwains-dashboard/configs/rooms.yaml. Can you post that here ?
thx for you your quick response. Let me try, if I replace the current file with the original rooms.yaml…
I reinstalled the integration. after replacing the room.yaml, i can access dwains dashboard again. OK. But is it really the case, that an failure in one of the configuration files affects the entire dashboard? There was only a minor mistake in there because I tried to assign different devices to a room - very sensitive… Anyway, compliments for the great dashboard. Great work! and thank you for the support.
Is it possible to have an entity displays a different name in the dashboard, than the entity itself has?
For example, I have named each group in my distribution board as Gr. 1, Gr. 2 etc, but I want to have two entities in the kitchen tab displayed as “Oven” and “Vaatwasser”
I have made several attempts without success.
