Thanks. That is great
One last question : Isn’t this add-on available in the HACS store? Because that would make updating a whole lot easier
You can add it by hand in HACS. I’ve added it to become hacs default but its still in processing https://github.com/hacs/default/pull/698
I fell into the trap and tried to add the link above as a repository and failed, obviously. Just want to prevent others falling into the same trap …
Adding this one worked.
HI. I installed Dasboard 2.0.1. But I saw a white gap here, more clear in dark theme. Is it a bug? Have anyway to fix it?
are you maybe interested in polish one?
I’ve never used columns like that so just guessing, but remove “Test” and use columns: 1 and columns: 2.
problem found… wrong config folder. there are two after installation
/config/dwains-dashboard/configs
/config/custom_components/dwains_dashboard/installation/configs
I fell in the same trap. I feel this can be improved in the documentation. Or rename the 2nd one to */config_template
The folder is also called differently its dwains-dashboard and the integration itself is dwains_dashboard
Subtile difference ,-).
Any chance of support to add individual lights to a room? I have added all my living room lights to a group called light.woonkamer, however when i turn that on via the button it says lights on 1…
I’d rather have that display the correct number of lights, else its useless…
Seems like you made a light group and not a group with lights, there is a difference between those two.
Group - Home Assistant (You want this)
Group - Home Assistant (You currently have this)
Hmm thanks works :slight_smile
was fiddeling with these groups and light groups before but only the light groups worked.
hi, did you solve your problem? I have same one.
I have the same problem as your #2. Did you solve that?
You can create a group with the windows. It will show the group status and when you click on it will show the devices in the group and individual status.
Yes, just had to clear the browser cache.
