Is it possible to upgrade the OS remotely as well and receive warnings if there’s a newer release out?
I like to keep things secure, but it’s hard to SSH into all these. If unattended-upgrades fails for some reason, it’d be good to know.
For me, monitoring the state of all my Pis is great (I have 20 active around the house), but I’d also like to ensure they’re not posing security risks either.
I’m using debian 12 and it gets informations pretty well. Except for temperature.
Is it possible to get extra storage information to other partitions or disks on my system ? For example : I have one partition to /home , one partition in other disk called /utils, other partition called /bkp and so on.
I installed it, but homeassistant didnt discover any new mqtt devices.
I think its because im running a seperate mqtt broker (not a HA addon).
I can see this monitor logon to the broker. Maybe it has to do with the discovery prefix (homeassistant)?
I didnt have to put that in anywhere during the install script.
Question 2:
How does one update a monitor profile afterwards? edit the *.py ?
Hi ,
To edit the initial configuration after installation you need to edit config.py
Regarding the prefix you are asking it’s also in the config file and defaults to homeassistant
mqtt_discovery_prefix = “homeassistant”
at the moment there is just one disk usage sensor and you can change the paths its checking to your external. I plan to add the option to have one more or many in feature versions.
Hello Masoko,
Thank you for your work. The installation was effortless.
I installed it on a mini PC with Ubuntu. Unfortunately, the CPU temperature and CPU load aren’t provided. I suspect it has something to do with my processor, an “AMD Ryzen 9 6900HX.”
Is there anything I can do to ensure that both values are evaluated?
Best regards, Agascha
