My recommendation is to NOT install SSL at this point. I could never get it to work with dashboard. I found TOR to be a better option for accessing HA and Dashboard away from home.
I will have a look at tor, Iâm currently setting up Hass.io, but feel tor may not be compatible with that, although I do have an OpenWrt router which may be an option if need be.
The reason I used ssl was for the home assistant iOS app as the household uses it for location tracking.
Edit⌠just seen tor in the Hassio addons
Oops, I was using ssl to be able to connect to my PI over the internet. I am not familiar with the requirement you just mentioned regarding IOS, so my comment about using tor may not apply in your circumstances.
my ISP uses a dynamic IP address for my residential broadband, so using duckdns with letâs encrypt means I only ever needed the duckdns address as the IP address assigned by my isp may change after a reboot of the router or what not, if I can use duckdns on the router instead of on the hassio machine it should help with the ssl certificate problems⌠unless anyone knows different?
seperately I have appdemon up and running on my new hassio install.
ta
Scott
Great, let me know what you need.
I know very little about Appdaemon, im assuming a lot, but using your code I have created âemailparse.pyâ inside the appdaemon/apps directory, added the reference in apps.yamlâŚ
hello_world:
module: hello
class: HelloWorld
email_parse:
module: emailparse
class: pavey
thats pretty much how far its got, until iâve done some reading I havenât a clue how to call the app let alone include it within hassio to parse the email and change a binary_sensors value!
I donât like to be spoon fed and the information is out there somewhere, so let me go away and see what I can work out and Iâll get back to you when / if I get stumped.
thanks so far!
Scott
After spending the day playing with your code, Iâve modified it as belowâŚ
import appdaemon.plugins.hass.hassapi as hass
import base64
import string
class pavey(hass.Hass):
def initialize(self):
email_body = "Alarm event: MotionDetectStart (1)"
y = email_body.find('DetectStart')
z = email_body.split('(')
camera_index = z[1]
if y == -1:
self.log("DetectStart not found")
self.set_state("sensor.motion", state = "clear", attributes = {"friendly_name": "Motion"})
else:
camera_where_motion_detected = camera_index[0]
self.log(camera_where_motion_detected)
self.set_state("sensor.motion", state = (camera_where_motion_detected), attributes = {"friendly_name": "Motion Detected"}
The state changes in hassio front end as expected in relation to the values I change in the email_body line, I realise I can run the required actions (light/turn_on) directly within the code, but I had ideas of using the sensor to run automations.
Of course Iâve not found a solution for the input from the email, I did have a stab at it using get_state but wasnât successful, Iâd appreciate a pointer on that one, the email arrives via the gmail_imap sensor if that matters.
thanks
Scott
Scott,
I like your approach, i.e., not being spoonfed, you learn more and it sticks that way. Let me share one of the basic things I learned working with a veteran. When you display code in this forum, start it and end it with three âticâ marks, see keyboard.
![image|690x232]
(upload://ndOykg7bZ5MjBeAxcyCTVyTc9Rn.jpg)
To illustrate, I will repeat your code here:
#!/usr/bin/env python
import base64
import string
email_body = âAlarm event: MotionDetectStart (1)â
y = email_body.find(âDetectStartâ)
z = email_body.split(â(â)
camera_index = z[1]
if y == -1:
self.log(âDetectStart not foundâ)
self.set_state(âsensor.motionâ, state = âclearâ, attributes = {âfriendly_nameâ: âMotionâ})
else:
self.set_state(âsensor.motionâ, state = (camera_where_motion_detected), attributes = {âfriendly_nameâ: âMotion Detectedâ}
This approach makes your code more readable.
When you code the state change of your imap sensor, the automation takes place. In my NVR system, I am able to change the subject of the email, so I make the âsubjectâ âAlertâ. In the IMAP sensor, the âsubjectâ is the state value, so in the following line of code:
self.listen_state(self.motion_detected,"sensor.backyard_motion", new="Alert")
the âlisten_stateâ is looking at the subject line to see if it says âAlertâ. If so, it triggers the motion detect routine. In the motion detect routine, the email body is parsed to determine what camera detected the motion. I donât think you need the following code:
What do you want to happen when motion is detected? In my application I turn on a light near the motion and keep it on for 5 minutes as shown in this code where I have 3 possible lights to turn on, depending on where the motion occurs:
if detected_by_camera == "3":
self.set_state("sensor.backyard_motion", new = "off")
self.turn_on("light.linear_lb60z1_dimmable_led_light_bulb_level", brightness = "120")
self.cancel_timer(self.camera_3_handle)
self.camera_3_handle = self.run_in(self.timer_handler, 300, myentity = "light.linear_lb60z1_dimmable_led_light_bulb_level")
self.log(self.get_state("light.linear_lb60z1_dimmable_led_light_bulb_level", attribute='friendly_name') + ", turned on due to motion - line 30")
# courtyard light
elif detected_by_camera == "2":
if self.now_is_between("sunset + 02:00:00", "sunrise"):
#if self.now_is_between("sunrise", "sunset"):
self.turn_on("light.linear_lb60z1_dimmable_led_light_bulb_level_4", brightness = "120")
self.cancel_timer(self.camera_2_handle)
self.camera_2_handle = self.run_in(self.timer_handler, 300, myentity = "llight.linear_lb60z1_dimmable_led_light_bulb_level_4")
self.log(self.get_state("light.linear_lb60z1_dimmable_led_light_bulb_level_4", attribute='friendly_name') + ", turned on due to motion - line 39")
# middle garage
elif detected_by_camera == "1":
self.turn_on("light.unknown_node_21_level", brightness = "120")
self.cancel_timer(self.camera_1_handle)
self.camera_1_handle = self.run_in(self.timer_handler, 300, myentity = "light.unknown_node_21_level")
self.log(self.get_state("light.unknown_node_21_level", attribute='friendly_name') + ", turned on due to motion - line 48")
else: self.log("Old email dated "+email_date+" ignored")
#self.notify("Motion detected from camera " + detected_by_camera)
detected_by_camera = ''
# else: self.log("Sun is not down")
def timer_handler(self, kwargs):
self.turn_off(kwargs['myentity'])
self.log(self.get_state(kwargs['myentity'], attribute='friendly_name') + ", turned on due to motion, is now off")
self.notify(self.get_state(kwargs['myentity'], attribute='friendly_name') + ", turned on due to motion, is now off")
One other subtle point, when Home Assistant is restarted, the IMAP sensor rereads all the emails from the beginning of your inbox, at 30 second intervals, and will go through your detection routine and can send false information to you. There is reference to a routine on this forum that will delete all old emails if Home Assistant is restarted (I thought I had it bookmarked, but I donât). In my case, I decided to manually delete the emails each day as I scan through to see what happened the night before, and in the interim I installed this code to ignore old email messages:
now = datetime.now()
now_string = str(now.hour)+':'+str(now.minute) +':'+str(now.second)
message_string = email_date[17:25] #Mon, 18 Jun 2018 15:21:43
FMT = '%H:%M:%S'
tdelta = datetime.strptime(now_string, FMT) - datetime.strptime(message_string, FMT)
self.log(str(tdelta.total_seconds()))
if tdelta.total_seconds() > 600:
detected_by_camera = "" #reading old email messages, bypass motion processing
elif tdelta.total_seconds() < -300: #There is a difference in time between NVR and Home Assistant
I hope this helps!
this is what I ended up with, ill look at your last post with great interest as I can see you have made allowances for old messages.
import base64
import string
x = self.get_state("sensor.alarmnotficationsgmailcom", attribute = "body")
email_body = (x)
camera_index = z[1]
if y == -1:
self.log(x)
else:
self.set_state("sensor.motion", state = (camera_where_motion_detected), attributes = {"friendly_name": "Motion Detected"})
self.log(x)```
What does your imap configuration look like?
Here is mine:
- platform: imap_email_content
server: imap.gmail.com
port: 993
username: xxxxxxxxxxx
password: !secret gmail_password
senders:
- [email protected]
I show this because the configuration creates the friendly name so you donât have to set it in code. I am wondering why you are not listening to the state change of the sensorâŚ
self.listen_state(self.motion_detected,âsensor.backyard_motionâ, new=âAlertâ)
just re-reading your post, my apologies to you and the other forum users, I looked for the way to format the code but I couldnât find it using the menu bar at the top of the post window.
I can certainly change the emails subject, the same as you I would like lights to come on to reflect the location at which the motion occurred.
My laptop battery just died, so will have to resume this later again thanks for your help thus far.
Scott
Im not sure I can listen for the sensor state using the email title as both the start motion and end motion emails contain the same title and I only want to listen for the start, although there is probably a way to parse the email body afterwards to check for end and ignore it.
ive amended my imap config to use a friendly name.
thanks
Scott
The example I provided parses the email body and eliminates the âendâ portion.
i did it much easier, just 1 line of code change to decode the body text ![]()
see here, my reply to that thread
now in my automations, i can look for a keyword
