Decoding Power Bar with Energy Monitoring
Thank you! I assume only 2 of the 4 channels are required right? Just considering getting something smaller
This is the circuit I used for level shifting in my original mod. Resistor values are not too important, as long as they are not too far off. (YMMV)
For my initial proof of concept, I used a 74LS00 just to boost the output to 5V…
I updated mine to use external component. Create the folders and files under esphome
__init__.py
# just required so Python treats the folder as a package
sensor.py
import esphome.codegen as cg
import esphome.config_validation as cv
from esphome.components import sensor
from esphome.const import (
    UNIT_WATT, ICON_FLASH, DEVICE_CLASS_POWER,
    UNIT_VOLT, DEVICE_CLASS_VOLTAGE,
    UNIT_AMPERE, DEVICE_CLASS_CURRENT,
wion_ns = cg.esphome_ns.namespace("wion_power_monitor")
WionPowerMonitor = wion_ns.class_("WionPowerMonitor", cg.PollingComponent)
CONFIG_SCHEMA = cv.Schema({
    cv.GenerateID(): cv.declare_id(WionPowerMonitor),
    cv.Optional("power"): sensor.sensor_schema(
        unit_of_measurement=UNIT_WATT,
        icon=ICON_FLASH,
        accuracy_decimals=1,
        device_class=DEVICE_CLASS_POWER,
    cv.Optional("voltage"): sensor.sensor_schema(
        unit_of_measurement=UNIT_VOLT,
        device_class=DEVICE_CLASS_VOLTAGE,
    cv.Optional("current"): sensor.sensor_schema(
        unit_of_measurement=UNIT_AMPERE,
        device_class=DEVICE_CLASS_CURRENT,
    cv.Optional("power_factor"): sensor.sensor_schema(
async def to_code(config):
    var = cg.new_Pvariable(config[cv.CONF_ID])
    await cg.register_component(var, config)
    if "power" in config:
        sens = await sensor.new_sensor(config["power"])
        cg.add(var.set_power_sensor(sens))
    if "voltage" in config:
        sens = await sensor.new_sensor(config["voltage"])
        cg.add(var.set_voltage_sensor(sens))
    if "current" in config:
        sens = await sensor.new_sensor(config["current"])
        cg.add(var.set_current_sensor(sens))
    if "power_factor" in config:
        sens = await sensor.new_sensor(config["power_factor"])
        cg.add(var.set_powerf_sensor(sens))
wion_power_monitor.cpp
#include "wion_power_monitor.h"
#include "esphome/core/log.h"
namespace esphome {
namespace wion_power_monitor {
void WionPowerMonitor::setup() {
  pinMode(0, OUTPUT);
  pinMode(12, INPUT);
  digitalWrite(0, HIGH);
void WionPowerMonitor::update() {
  const int numBlocks = 4;
  const int bitsPerBlock = 32;
  int data[numBlocks];
  for (int block = 0; block < numBlocks; block++) {
    for (int bitIdx = bitsPerBlock - 1; bitIdx >= 0; bitIdx--) {
      digitalWrite(0, LOW);
      delayMicroseconds(35);
      bitWrite(data[block], bitIdx, digitalRead(12));
    for (int bit = 24; bit < 32; bit++) {
      bitWrite(data[block], bit, 0);
  ESP_LOGD(TAG, "raw: %#08X; %#08X; %#08X; %#08X", data[0], data[1], data[2], data[3]);
  float power = data[0];
  float voltage = data[1];
  float powerF = data[2];
  float current = data[3];
  power = power / 3;  // calibrated against Sonoff S31
  if (power < 1 || power > 2000) {
    power = 0;
  if (data[0] != 0xFFFFFF && current < 3000) {
    if (power_sensor) power_sensor->publish_state(power);
    if (voltage_sensor) voltage_sensor->publish_state(voltage);
    if (powerf_sensor) powerf_sensor->publish_state(powerF);
    if (current_sensor) current_sensor->publish_state(current);
void WionPowerMonitor::dump_config() {
  ESP_LOGCONFIG(TAG, "Wion Power Monitor:");
  LOG_SENSOR("  ", "Power", this->power_sensor);
  LOG_SENSOR("  ", "Voltage", this->voltage_sensor);
  LOG_SENSOR("  ", "PowerF", this->powerf_sensor);
  LOG_SENSOR("  ", "Current", this->current_sensor);
}  // namespace wion_power_monitor
}  // namespace esphome
#pragma once
#include "esphome/core/component.h"
#include "esphome/components/sensor/sensor.h"
namespace esphome {
static const char *const TAG = "wion_power_monitor";
class WionPowerMonitor : public PollingComponent {
 public:
  WionPowerMonitor() : PollingComponent(15000) {}
  // setters called from sensor.py
  void set_power_sensor(sensor::Sensor *s) { power_sensor = s; }
  void set_voltage_sensor(sensor::Sensor *s) { voltage_sensor = s; }
  void set_current_sensor(sensor::Sensor *s) { current_sensor = s; }
  void set_powerf_sensor(sensor::Sensor *s) { powerf_sensor = s; }
  float get_setup_priority() const override { return esphome::setup_priority::BUS; }
  void setup() override;
  void update() override;
  void dump_config() override;
 protected:
  sensor::Sensor *power_sensor{nullptr};
  sensor::Sensor *voltage_sensor{nullptr};
  sensor::Sensor *current_sensor{nullptr};
  sensor::Sensor *powerf_sensor{nullptr};
esphome YAML
esphome:
  friendly_name: WION-Plug
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "key"
ota:
  - platform: esphome
    password: "password"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Wion-Plug Fallback Hotspot"
switch:
  - platform: gpio
    pin: GPIO15
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
    on_press:
     - switch.toggle: relay1
  - platform: status
light:
  - platform: binary
    output: light_output
    restore_mode: ALWAYS_OFF
output:
  - id: light_output
    platform: gpio
    pin: GPIO14
  - id: wifi_output
    platform: gpio
    pin: GPIO2
    inverted: true
interval:
  - interval: 5s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - output.turn_on: wifi_output
        else:
          - output.turn_off: wifi_output
external_components:
  - source:
      type: local
      path: ./external_components
  - platform: wion_power_monitor
    power:
captive_portal:
I am only using the power sensor, but the rest are in the code
hi, I did a complete reverse engineering of this plug, I posted the code here GitHub - Taxom/WiOn-50055-ESPHome: ESPHome replacement firmware for the Woods WiOn 50055 Wi-Fi outlet, retaining the stock power-monitoring hardware. · GitHub
