2018-04-15 14:09:31 INFO (MainThread) [homeassistant.setup] Setting up deconz
2018-04-15 14:09:31 INFO (MainThread) [homeassistant.setup] Setup of domain deconz took 0.0 seconds.
2018-04-15 14:09:31 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=deconz>
2018-04-15 14:09:31 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=deconz, discovered=host=192.168.1.48, port=8080, ssdp_description=http://192.168.1.48:8080/description.xml, name=Philips hue (192.168.1.48) compatible Wireless Light Control Gateway, model_name=Philips hue bridge 2012, model_number=929000226503, serial=00212EFFFF01723C, manufacturer=Royal Philips Electronics, udn=uuid:71594311-5e6d-4a5f-b629-c7ff1d6d8bdc>
2018-04-15 14:09:31 INFO (MainThread) [homeassistant.loader] Loaded configurator from homeassistant.components.configurator
2018-04-15 14:09:31 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=configurator, service=configure>
2018-04-15 14:09:31 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=configurator.deconz, old_state=None, new_state=<state configurator.deconz=configure; configure_id=1862122992-1, fields=[], friendly_name=deCONZ, entity_picture=/static/images/logo_deconz.jpeg, description=
Unlock your deCONZ gateway to register with Home Assistant.
1. [Go to deCONZ system settings](http://192.168.1.48:8080/edit_system.html)
2. Press "Unlock Gateway" button
[deCONZ platform documentation](https://home-assistant.io/components/deconz/)
, submit_caption=I have unlocked the gateway @ 2018-04-15T14:09:31.580391+02:00>>
2018-04-15 14:09:35 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for zone 1 Zona Giorno
2018-04-15 14:09:35 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for device 126576 Casa
2018-04-15 14:09:46 INFO (SyncWorker_4) [homeassistant.components.tado] Querying mytado.com for zone 1 Zona Giorno
2018-04-15 14:09:46 INFO (SyncWorker_4) [homeassistant.components.tado] Querying mytado.com for device 126576 Casa
2018-04-15 14:09:53 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 82.50.159.251 (auth: False)
2018-04-15 14:09:54 INFO (MainThread) [homeassistant.components.http.view] Serving /api/themes to 82.50.159.251 (auth: True)
2018-04-15 14:09:54 INFO (MainThread) [homeassistant.components.http.view] Serving /api/translations/en to 82.50.159.251 (auth: True)
2018-04-15 14:09:55 INFO (MainThread) [homeassistant.components.http.view] Serving /api/cloud/account to 82.50.159.251 (auth: True)
2018-04-15 14:09:57 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app-es5/hassio-app.html to 82.50.159.251 (auth: False)
2018-04-15 14:09:57 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/build-temp/util.js to 82.50.159.251 (auth: False)
2018-04-15 14:09:58 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/supervisor/info to 82.50.159.251 (auth: True)
2018-04-15 14:09:58 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app-es5/index.html to 82.50.159.251 (auth: False)
2018-04-15 14:09:58 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/host/info to 82.50.159.251 (auth: True)
2018-04-15 14:09:58 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/homeassistant/info to 82.50.159.251 (auth: True)
2018-04-15 14:09:58 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/build-temp/util.js to 82.50.159.251 (auth: False)
2018-04-15 14:09:59 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 82.50.159.251 (auth: False)
2018-04-15 14:10:12 INFO (MainThread) [homeassistant.components.http.view] Serving /api/config/entity_registry/configurator.deconz to 82.50.159.251 (auth: True)
2018-04-15 14:10:17 INFO (SyncWorker_1) [homeassistant.components.tado] Querying mytado.com for zone 1 Zona Giorno
2018-04-15 14:10:17 INFO (SyncWorker_1) [homeassistant.components.tado] Querying mytado.com for device 126576 Casa
2018-04-15 14:10:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=configurator, service=configure, service_data=configure_id=1862122992-1, fields=, service_call_id=1968058576-20>
2018-04-15 14:10:23 DEBUG (MainThread) [pydeconz.utils] Sending {'auth': None, 'data': b'{"devicetype": "pydeconz"}'} to http://192.168.1.48:8080/api
2018-04-15 14:10:23 DEBUG (MainThread) [pydeconz.utils] HTTP request response: [{'success': {'username': '7DF593F64E'}}]
2018-04-15 14:10:23 INFO (MainThread) [pydeconz.utils] API key: 7DF593F64E
2018-04-15 14:10:23 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ config {'host': '192.168.1.48', 'port': 8080, 'api_key': '7DF593F64E'}
2018-04-15 14:10:23 DEBUG (MainThread) [pydeconz.utils] Sending {} to http://192.168.1.48:8080/api/7DF593F64E
2018-04-15 14:10:23 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall configurator.configure: configure_id=1862122992-1, fields=>
File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1002, in _event_to_service_call
await service_handler.func(service_call)
File "/usr/lib/python3.6/site-packages/homeassistant/components/configurator.py", line 224, in async_handle_service_call
call.data.get(ATTR_FIELDS, {}))
File "/usr/lib/python3.6/site-packages/homeassistant/components/deconz/__init__.py", line 168, in async_configuration_callback
result = await async_setup_deconz(hass, config, deconz_config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/deconz/__init__.py", line 99, in async_setup_deconz
result = await deconz.async_load_parameters()
File "/usr/lib/python3.6/site-packages/pydeconz/__init__.py", line 58, in async_load_parameters
data = await self.async_get_state('')
File "/usr/lib/python3.6/site-packages/pydeconz/__init__.py", line 109, in async_get_state
response_dict = await async_request(session, url)
File "/usr/lib/python3.6/site-packages/pydeconz/utils.py", line 54, in async_request
response = await session(url, **kwargs)
File "/usr/lib/python3.6/site-packages/aiohttp/client.py", line 208, in _request
raise RuntimeError('Session is closed')
RuntimeError: Session is closed
2018-04-15 14:10:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: timestamp=1523794223.8892875, level=ERROR, message=Error executing service <ServiceCall configurator.configure: configure_id=1862122992-1, fields=>, exception=Traceback (most recent call last):
, source=components/deconz/__init__.py>
2018-04-15 14:10:26 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.6/site-packages/homeassistant/components/light/hue.py", line 162, in async_update_items
await api.update()
File "/usr/lib/python3.6/site-packages/aiohue/api.py", line 12, in update
raw = await self._request('get', self._path)
File "/usr/lib/python3.6/site-packages/aiohue/bridge.py", line 58, in request
async with self.websession.request(method, url, json=json) as res:
File "/usr/lib/python3.6/site-packages/aiohttp/client.py", line 783, in __aenter__
self._resp = await self._coro
await api.update()
This is the log, when I try to configure deconz using the configurator, the are many more error like these.
if I disable discovery: and configure manually deconz, then it works. But i lose the hass.io page where can i manage add-ons in home assistant.
