deConz + Hue motion sensor - adjust senisitivity
HI @qlqheixs , sorry for pushing that old thread. I followed your steps but have difficulties with user rights.
My result is alwas “unauthorized user” even I used my normal credentials for Phoscon login
this is my request - what is wrong?
  "method": "GET",
  "transformRequest": [
    null
  "transformResponse": [
    null
  "url": "http://xxx.xxx.xxx.xx:40850/api/bbb5c510b3544e9181768c7532050b26/sensors",
  "headers": {
    "Authorization": "Basic cG9zdEBqb2VyZy1uYXVlbi5kZTpQaXJvbDYyMA==",
    "Accept": "application/json, text/plain, */*"
  "data": "",
  "timeout": {}
What is your deconz IP adress? The normal Home Assistant IP adress? Or the IP adress seen in the Hassio add-on? And what port number is deconz when using ingress? I tried the one stated in the config file “40850”, but I get a request failed.
I am using deconz via it’s own Docker container and just expose it through a bridged network.
I know Hassio uses Docker underneath so presumably it is similar. How do you connect to the Phoscon app - perhaps use that IP address?
Using Phoscon is via Hassio ingress, but when I am in Phoscon it states the IP adress is " 172.30.33.0", but if I use that instead and then use:“http://172.30.33.0:8080/api/54678998EA/sensors then” then I still get Request failed
You can use the home assistant service like:
entity: binary_sensor.bewegung_aussen_ug
field: /config
  sensitivity: 0
@qlqheixs, Thanks for posting this. It was hugely helpful. You may want to edit your post with the two points below.
@Morten_DK, What I did to make it work was first go to the Deconz add-on (click “Supervisor” on the left and then click Deconz on the right) and make sure that port 40850 is past through to port 40850. This is not enabled by default. Second, The IP you need is the IP of your HA server. The 172.30.33.0 is the IP for the Docker that is running the Deconz app and cannot be reached outside of the HA server itself.
Strangely, I am trying to do the same thing, but with “sensitivitymax” and getting the error below.
    "error": {
      "address": "/sensors/23/config/sensitivitymax",
      "description": "parameter, sensitivitymax, not available",
      "type": 6
Maybe it is a readonly parameter. What else would it mean if there is also a plain sensitivity parameter?
It is posible. My value for sensitivitymax is set to “4” and in the example from @qlqheixs has it set to “2”, both with Philips motion sensors, so I was hoping that it was possible to change. I set my sensitivity to “1” and I am still getting a lot of notifications so I thought I would check into lowering the sensitivitymax, it see if that changed any thing.
Like I said above, you can simple use the services on HA
I did a bit of Googling
And I found a discussion that confirmed what I suggested above. The sensitivitymax is a readonly value that tells the software that interface to it what the range is.
And it seems Philips motion sensors has this hardcoded to 2 for the indoor version and 4 for the outdoor version.
This tells us that the sensitivy valid range is 0 to 2 for the indoor and 0 to 4 for the outdoor
is that a random example or that the actual code to use in this instance?
Just sharing another solution in case others find this topic. I still hope configuring the motion sensors connected to deconz will become possible at any time. In the meanwhile you could also use the (android) app Hue Essentials. You can link in to the deconz API and gives you easy configuration of things like motion and light sensitivity.
iOS app works as well,
In the configuration page for the deconz addon, put 40850 in the top network field called “40820/tcp” and restart the add on
then in the hue essentials app, add a bridge manually, select deconz and put in the IP address of your device running HA (most likely a pi, but it is whatever you’re hosting on, not the IP shown in the phoscon app) and use 40850 for the port.
once it asks you for a username and password just don’t touch it and from your computer go the phoscon app from the add ons page in HA. Open the advanced section of the gateway page and click authenticate app.
I searched for hours before I found out how to change the sensitivity of my Philips Hue Outdoor Sensor with Home Assistant. Here is how I finally did it:
Developer Tools => Services => Service: deconz.configure
Service Data:
entity: binary_sensor.philips_outdoor_sensor
field: /config
  sensitivity: 0
bridgeid: 00212E0000E0
entity is the entity within Home Assistant
sensitivity 0 to 4, 0 being the least sensitive.
bridgeid can be found here:
Configuration => Integrations => code is visible on the Phoscon deCONZ tile.
The suggestion by X1pheR (Hue essentials app) worked too.
OK so I’m doing some thread digging here :slight_smile:
I’m stuck at the very first step, which is accessing the /sensors/ folder using YARC.
This is what I send: http://My_HA_IP@:40850/api/API Key/sensors
I always get an error: Unknown network error has occured. I added credentials (to the Deconz) same thing.
I’m sure of the IP address, it’s a fixed IP on my DHCP on my router. I’m also sure of the API, found exactly where it says.
What could I be missing ?
This is the Request Details:
  "method": "GET",
    null
    null
  "jsonpCallbackParam": "callback",
  "url": "http://xx.xx.xx.xx.xx:40850/api/apiKey/sensors",
  "headers": {
    "Authorization": "Basic Q2xhd0JlZUlJOkFkNCM1LXRZdTEzMkBmISRmRjUmdTApPSs3Nw==",
  "data": "",
  "timeout": {}
Not sure if Hue has changed their spec but I’m not seeing the sensitivity option in my config.
  "config": {
    "alert": "none",
    "battery": 100,
    "ledindication": false,
    "offset": 0,
    "on": true,
    "pending": [],
    "reachable": true,
    "usertest": false
  "ep": 2,
  "etag": "a8b50f8067a27f4a0e43a1d6f6d30092",
  "lastseen": "2021-05-21T11:14Z",
  "manufacturername": "Philips",
  "modelid": "SML001",
  "name": "Motion Sensor",
  "state": {
    "lastupdated": "2021-05-21T11:14:19.268",
    "temperature": 2111
  "swversion": "6.1.0.18912",
  "type": "ZHATemperature",
  "uniqueid": "00:17:88:01:09:15:ee:4a-02-0402"
Did you find your answer ? In case you did not: You are looking at the wrong sensor. The HUE Outdoor Sensor gives. you three different sensors. Just look further up :slight_smile:
