Deconz: new REST endpoint for alarm system
Ok. Then I don’t know.
Ok.
Thx anyway.
I can try in DeConz forum…
Good luck!
Hi, sorry to bother and thanks for all the hard work!
I think this instruction is exactly what I need to do to get my Frient Keypad up and running. I just don’t understand how the keypad can be made a keypad in hass instead of a sensor.
The keypad is paired with deconz and I see the sensors for battery/tampering/motion. But the keypad device itself does not show up.
the deconz diagnostic log shows the correct state for the keypad, see below. But the alarm panel in HA is not updated when the keypad changes state. Could you point me in the right direction?
 "sensors": {
      "2": {
        "config": {
          "battery": 0,
          "on": true,
          "pending": [],
          "reachable": true
        "ep": 44,
        "etag": "daa3a61f722f54eaf90488cad42b6a91",
        "lastannounced": null,
        "lastseen": "2023-10-16T16:51Z",
        "manufacturername": "frient A/S",
        "modelid": "KEPZB-110",
        "name": "AncillaryControl 2",
        "state": {
          "action": "disarmed",
          "lastupdated": "2023-10-17T21:28:45.093",
          "lowbattery": false,
          "panel": "disarmed",
          "seconds_remaining": 0,
          "tampered": false
        "type": "ZHAAncillaryControl",
        "uniqueid": "00:15:bc:00:43:00:0d:20-2c-0501"
If you don’t see the keypad in home assistant that means that you haven’t configured the alarm system to use the keypad device.
Thanks for the help! I tried that but it doesn’t seem to work.
Here is the current alarmsystem in deconz. The armmode was just set to armed_away via the keypad with the code that was set in deconz. I added the current device manually a few days ago since no device was added automatically. the conbee 2 firmware was updated a week ago or so.
[core-ssh ~]$ curl -X GET http://172.30.33.x:xxx/api/xxx/alarmsystems | jq
  "1": {
    "config": {
      "armed_away_entry_delay": 120,
      "armed_away_exit_delay": 120,
      "armed_away_trigger_duration": 120,
      "armed_night_entry_delay": 120,
      "armed_night_exit_delay": 120,
      "armed_night_trigger_duration": 120,
      "armed_stay_entry_delay": 120,
      "armed_stay_exit_delay": 120,
      "armed_stay_trigger_duration": 120,
      "armmode": "armed_away",
      "configured": true,
      "disarmed_entry_delay": 0,
      "disarmed_exit_delay": 0
    "devices": {
      "00:15:bc:00:43:00:0d:20-2c-0501": {
        "armmask": "none"
    "name": "xxx",
    "state": {
      "armstate": "exit_delay",
      "seconds_remaining": 117
the frient keypad looks like this:
  "lastseen": "2023-10-17T21:21Z",
  "name": "Presence 3",
  "productid": "KEPZB-110 Keypad",
  "subdevices": [
      "config": {
        "duration": {
          "lastupdated": null,
          "value": null
        "on": {
          "lastupdated": "2023-10-02T23:57:01Z",
          "value": true
        "reachable": {
          "lastupdated": "2023-10-17T08:01:11Z",
          "value": true
      "state": {
        "presence": {
          "lastupdated": "2023-10-03T00:06:31Z",
          "value": false
      "type": "ZHAPresence",
      "uniqueid": "00:15:bc:00:43:00:0d:20-01-0406"
      "config": {
        "battery": {
          "value": 0
        "on": {
          "value": true
        "pending": {
          "lastupdated": "2023-10-10T22:27:15Z",
          "value": 0
        "reachable": {
          "value": true
      "state": {
        "action": {
          "lastupdated": "2023-10-17T23:15:38Z",
          "value": "armed_away"
        "lowbattery": {
          "lastupdated": "2023-10-16T18:46:26Z",
          "value": false
        "panel": {
          "lastupdated": "2023-10-17T23:17:40Z",
        "seconds_remaining": {
          "lastupdated": "2023-10-17T23:17:38Z",
          "value": 0
        "tampered": {
          "value": false
  "swversion": null,
  "uniqueid": "00:15:bc:00:43:00:0d:20"
I tried adding the other subdevice and the device itself but that didn’t work:
[core-ssh ~]$ curl -X PUT http://172.30.33.x:xxx/api/xxx/alarmsystems/1/device/00:15:bc:00:43:00:0d:20-01-406 | jq
    "error": {
      "address": "/alarmsystems/1",
      "description": "resource, /alarmsystems/1/device/00:15:bc:00:43:00:0d:20-01-406, not available",
      "type": 3
[core-ssh ~]$ curl -X PUT http://172.30.33.x:xxx/api/xxx/alarmsystems/1/device/00:15:bc:00:43:00:0d:20 | jq
100   138  100   138    0     0   6266      0 --:--:-- --:--:-- --:--:--  6571
    "error": {
      "description": "resource, /alarmsystems/1/device/00:15:bc:00:43:00:0d:20, not available",
      "type": 3
I guess I’m missing something, but what :slight_smile:
So you have a keypad entity in home assistant?
So your issue is no state update?
I am not sure to be honest. I see four entities, see image, but the keypad doesn’t seem to be among them. the armed_away state is reported by the deconz rest api in response to a GET /alarmsystems.
Doesn’t look like it. Can you share a debug log see instructions on integration documentation
Sorry it took so long to reply. After an HA restart the IP changed so I had to find your other post on the Phoscon forum to figure that out first :slight_smile:
Anyway I see this entity now! :
And i see this:
That should be good right? I just have to figure out how to connect the keypad state to the alarm system in HA. this panel does not update when I change the keypad state. Can you point me in the right direction?
It should update automatically… I know there was some issue reported on alarm systems on deconz GitHub, take a google there or on phoscon forums. I think you might be experiencing an issue on deconz side.
