delete:
in configuration.yaml
initializes the integration, similar to other integrations, where data has to be in configuration.yaml
for them to work. Only services delete.file_in_folder
and delete.file
are part of the integration, nothing else. Services would be visible after the integration is started (after adding folder in custom_components
and data to configuration.yaml
and restart is done to cache/register python files within HA)
Thank you both @DivanX10 and @chomu , works flawlessly, does its job, simple, plain, beatufil.
I love this community.
Hi Jodur
Ive just come across your integration and Im using it to create a MP4 from jpegs this works great, then im trying to movethe jpgs to another folder but I cant get it to work
any ideas
alias: move jpegs
sequence:
- service: imagedirectory.move_files
sourcepath: /media/front/photo
exclude: front_latest.jpg
destinationpath: /media/front
mode: single
Works
alias: jpeg to Mp4 media exclude latest
sequence:
- service: imagedirectory.create_gif_mp4
format: mp4
mode: single
@gazzaman i had a look in the code and found a typo-bug in the endtime default parameter. This is fixed in a new release, so if you update to the latest version, this should work now!
Thanks all working now
Hello, i have searched for such service and i am glad you have created one. What i don't get it to do is to delete files from outside config folder. Is it possible?
Thank you for your work
You can create a service using “Shell Command”. All you need is to add the following to your configuration.yaml file:
shell_command:
delete_file: rm /config/www/camera/snapshots/image.jpg
Restart HA and you will have the following service: shell_command.delete_file
You can create as many services as you want.
shell_command:
delete_snap1: rm /config/www/camera/snapshots/image.jpg
delete_snap2: rm /config/www/camera/snapshots/image2.jpg
rename_snap: mv /config/www/camera/snapshots/image.jpg /config/www/camera/snapshots/renamed.jpg
And so on…
@fberbert 's solution is the most straightforward. I just added the following to my configuration.yaml to give me a service I can call to delete everything more than 48 hours old in my /config/backups/ directory:
shell_command:
purge_backups_older_than_two_days: find backups/ -mtime +2 -delete -print
I have an automation that triggers once per hour to create a new backup and execute the above purge:
alias: Hourly Backups
description: ""
- platform: time_pattern
minutes: "0"
condition: []
- service: backup.create
data: {}
- service: shell_command.purge_backups_older_than_two_days
data: {}
mode: single
I just set this up so we’ll see how it goes but I think this should do the trick nicely without having to add any other HACS/add-ons for it. Thanks @fberbert !
EDIT: corrected a problem with my shell command above
EDIT2: corrected another problem with my shell command above. It actually executes from within the config directory.
What’s happened to the remote file delete option. I only see the delete file and delete files in folder option under services?
I need to create a task to delete old file from my NAS.
I’m trying to use this custom service to delete files from backup folder, but it gives me an error below:
Error while executing automation automation.daily_backup_housekeeping_1_week: Mandatory key “folder” is missing. @ data[‘folder’]
My config:
service: delete.files_in_folder
folder: /backup/
time: 604800
only_extensions:
- .tar
Can anyone help to advise?
hello I can ask you for help, I should do a command like what you did but that deletes a folder inside the directory media / frigate thanks
This worked for me except I missed step 6 at first.
@chomu great integration, if you could fix the reason why you need to do this additional step of adding to the config it would be absolutely awesome.
Needs a WTH to get it added to core. @frenck - how about it?
Have you found a solution? I get the same error: Fehler beim Aufrufen des Diensts delete.files_in_folder. Mandatory key “folder” is missing. @ data[‘folder’]. Got None
folder: ‘config/downloads/’
time: 604800
scan_subfolders: true
only_extensions: ‘.mp4’
Mandatory key "folder" is missing. @ data['folder']. Got None
Getting same error as the last couple of people. Was a fix ever found for this?
Disregard, I was able to figure out that I had to edit in YAML instead of the visual editor for my automation. Hope that will help someone else who runs across this thread.
Thanks. Exactly what I have been loking for after I couldnt manage to do shell commands
I was just wondering if this integration can delete files in folders with wildcards. Since 2024.02 version when the database purges it creates a home-assistant_v2.db.corrupt.xxxxxxx (where xxxxxxx is the timestamp).
I would like to use this integration to delete these files but trying as below it didn’t work for me:
folder: '/config/'
time: 0
only_extensions:
- '.fault'
- '.1'
- '.db.corrupt*'
Am i doing something wrong or the windcard is not supported by the integration?
Hoping someone might be able to help. I’ve added the add-on, however can’t work out which file I need to place my call service into.
folder: ‘/config/www/doorbell/’
time: 36000
I tried adding it to config.yaml and also automations.yaml but no joy.
