Deprecated Harmony entity detected in script.theater_mode_off
You have to post your entire configuration. Because as it stands the switches (Outside all of your other stuff) behave this way:
if you turn on switch 1, all other switches will show as off. If you turn on switch 2, switch 2 will execute and switch 1 will naturally turn off without performing the turn off command.
So there’s something in your setup that’s causing that functionality to behave differently.
Use the template switches outside the interface you created above and you’ll see they behave correctly.
Upon further review…only the appletv button works. I cannot see any difference from the template entry to the call in the switches. I cannot start the system or change any inputs by calling any other switch.
However if I select the Activity on the remote, the appropriate button indicates the correct activity. (turns on and green).
I am sure I have something set wrong, but have no idea what.
the first code is the entire configuration.yaml
the second is a snippet of the appdaemon code that should call those switches from the template in the configuration.yaml
For test completness…
I created a duplicate alternate page with scripts that run the same activity commands as the current Harmony integration recommends and do not use the switches created by the template…they work fine. (well they operate as they should…but the icons don’t show as being active…but that is something in my script config somewhere)
Summary, my scripts work but don’t indicate activity…the template switches only appletv works, and they do indicate activity correctly.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
stream:
ffmpeg:
group: !include groups.yaml
# switch: !include switch.yaml
remote: !include remote.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
camera: !include camera.yaml
# for streaming radio stations
# input_number: !include input_number.yaml
# input_select: !include input_select.yaml
lovelace:
  resources:
    - url: /local/mini-media-player-bundle.js?v=1.16.4
      type: module
#  entry for Pioneer VSX1021
media_player:
  - platform: pioneer
    host: 192.168.
    port: 8102
    sources:
      'Phono': '00'
      'CD': '01'
      'Tuner': '02'
      'CD-R/Tape': '03'
      'DVD': '04'
      'TV/Sat': '05'
      'Video 1': '10'
      'Multi Channel In': '12'
      'Video 2': '14'
      'DVR/BDR': '15'
      'iPod/USB': '17'
      'XM Radio': '18'
      'HDMI 1': '19'
      'HDMI 2': '20'
      'HDMI 3': '21'
      'HDMI 4': '22'
      'HDMI 5': '23'
      'Blu-Ray': '25'
      'Home Media Gallery (Internet Radio)': '26'
      'Sirius': '27'
      'Adapter Port': '33'
logger:
  default: warning
switch:
    switches:
      ### hub LaserDisc Harmony Activty ###
      hub_laserdisc:
        unique_id: harmony-activity-hub-laserdisc
        friendly_name: hub LaserDisc
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'LaserDisc') }}
        turn_on:
          service: remote.turn_on
            entity_id: remote.hub
            activity: LaserDisc
        turn_off:
            activity: PowerOff
      ### hub Lights out Harmony Activty ###
      hub_lights_out:
        unique_id: harmony-activity-hub-lights_out
        friendly_name: hub Lights out
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Lights out') }}
        turn_on:
            activity: Lights out
        turn_off:
            activity: PowerOff
      ### hub Plug Power Toggle Harmony Activty ###
      hub_plug_power_toggle:
        unique_id: harmony-activity-hub-plug_power_toggle
        friendly_name: hub Plug Power Toggle
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Plug Power Toggle') }}
        turn_on:
            activity: Plug Power Toggle
        turn_off:
            activity: PowerOff
      ### hub Bluray Harmony Activty ###
      hub_bluray:
        unique_id: harmony-activity-hub-bluray
        friendly_name: hub Bluray
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Bluray') }}
        turn_on:
            activity: Bluray
        turn_off:
            activity: PowerOff
      ### hub theaterpower Harmony Activty ###
      hub_theaterpower:
        value_template: >
        turn_on:
            activity: Bluray
        turn_off:
            activity: PowerOff
      ### hub Receiver Power Harmony Activty ###
      hub_receiver_power:
        unique_id: harmony-activity-hub-receiver_power
        friendly_name: hub Receiver Power
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Receiver Power') }}
        turn_on:
            activity: Receiver Power
        turn_off:
            activity: PowerOff
      ### hub XBMC Harmony Activty ###
      hub_xbmc:
        unique_id: harmony-activity-hub-xbmc
        friendly_name: hub XBMC
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'XBMC') }}
        turn_on:
            activity: XBMC
        turn_off:
            activity: PowerOff
      ### hub Popcorn-Equipment Harmony Activty ###
      hub_popcorn_equipment:
        unique_id: harmony-activity-hub-popcorn_equipment
        friendly_name: hub Popcorn-Equipment
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Popcorn-Equipment') }}
        turn_on:
            activity: Popcorn-Equipment
        turn_off:
            activity: PowerOff
      ### hub DVD Changer Harmony Activty ###
      hub_dvd_changer:
        unique_id: harmony-activity-hub-dvd_changer
        friendly_name: hub DVD Changer
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'DVD Changer') }}
        turn_on:
            activity: DVD Changer
        turn_off:
            activity: PowerOff
      ### hub House Lights Dim Harmony Activty ###
      hub_house_lights_dim:
        unique_id: harmony-activity-hub-house_lights_dim
        friendly_name: hub House Lights Dim
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'House Lights Dim') }}
        turn_on:
            activity: House Lights Dim
        turn_off:
            activity: PowerOff
      ### hub AppleTV Harmony Activty ###
      hub_appletv:
        unique_id: harmony-activity-hub-appletv
        friendly_name: hub AppleTV
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'AppleTV') }}
        turn_on:
            activity: AppleTV
        turn_off:
            activity: PowerOff
      ### hub Dish Network Harmony Activty ###
      hub_dish_network:
        unique_id: harmony-activity-hub-dish_network
        friendly_name: hub Dish Network
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Dish Network') }}
        turn_on:
            activity: Dish Network
        turn_off:
            activity: PowerOff
      ### hub Kodi Harmony Activty ###
      hub_kodi:
        unique_id: harmony-activity-hub-kodi
        friendly_name: hub Kodi
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Kodi') }}
        turn_on:
            activity: Kodi
        turn_off:
            activity: PowerOff
      ### hub House Lights Up Harmony Activty ###
      hub_house_lights_up:
        unique_id: harmony-activity-hub-house_lights_up
        friendly_name: hub House Lights Up
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'House Lights Up') }}
        turn_on:
            activity: House Lights Up
        turn_off:
            activity: PowerOff
      ### hub Roku Harmony Activty ###
      hub_roku:
        unique_id: harmony-activity-hub-roku
        friendly_name: hub Roku
        value_template: >
          {{ is_state_attr('remote.hub', 'current_activity', 'Roku') }}
        turn_on:
            activity: Roku
        turn_off:
            activity: PowerOff
These are my appdaemon entries for the above Activities.
bluraya_scene:
    widget_type: switch
    title: Watch
    title2: Bluray
    entity: switch.hub_bluray
    icon_on: mdi-movie-roll
    icon_off: mdi-movie-roll
laserdisca_scene:
    widget_type: switch
    title: Watch
    title2: Laserdisc
    entity: switch.hub_laserdisc
    icon_on: mdi-movie
    icon_off: mdi-movie
DVDa_scene:
    widget_type: switch
    title: Watch
    title2: DVD
    entity: switch.hub_dvd_changer
disha_scene:
    widget_type: switch
    title: Watch
    title2: Dish Network
    entity: switch.hub_dish_network
    icon_on: mdi-satellite-uplink
    icon_off: mdi-satellite-uplink
applea_scene:
    widget_type: switch
    title: Watch
    title2: AppleTV
    entity: switch.hub_appletv
    icon_on: mdi-apple
    icon_off: mdi-apple
kodia_scene:
    widget_type: switch
    title: Watch
    title2: Kodi Media
    entity: switch.hub_kodi
    icon_on: mdi-play-network
    icon_off: mdi-play-network
rokua_scene:
    widget_type: switch
    title: Watch
    title2: Roku Media
    entity: switch.hub_roku
OMG…sometimes…
So digging through the logs I see the normal oddballs, (can’t connect to a device that is not turned on etc)
And I see this one…
Logger: homeassistant.components.switch
Source: helpers/entity_platform.py:764
integration: Switch (documentation, issues)
First occurred: 12:11:40 PM (1 occurrences)
Last logged: 12:11:40 PM
Platform template does not generate unique IDs. ID harmony-activity-hub-bluray is already used by switch.hub_bluray_2 - ignoring switch.hub_theaterpowera
So apparently the template generator created items that already existed somewhere else in HA…I will have to find them, but anyway I renamed ALL the hub_ ones on the template, and of course then my appdaemon buttons…
…works perfectly.
So I figured it was something in my system, thanks again Petro!
Mic
Final post on this subject.
Way back when, the Logitech Harmony integration created a bunch of entities based on activities etc.
Petro’s template generator creates switches with the same names.
So first I you still have all those auto generated entities from the Harmony integration…you need to delete all of them except for the two hub ones…(you can tell which ones to delete because their info will say not supported by the integration.)
Because I did not do that, I had to jump through hoops and rename everything to make it all work.
Mic
Hi Guys, hoping someone here can point me in the right direction, I’m very new to HA and searched a lot but not finding… How do we expose / use Harmony Hub actions as automation triggers?
I need automations to run based on… Pause, Play, Stop. I installed the Integration and see it exposes Activities. I need to detect the state / remote commands
thx!
There is no simple way to get this information. The harmony remote API doesn’t provide live updates like that.
Thanks so much for this @petro.
The Logitech Alexa skill was an absolute binfire, now being able to integrate the HA version via Matter I've got voice control back. Great work :trophy:
Not entirely true. You can set up an Emulated Roku device and link it with the Harmony remote. From there you can send commands from Harmony to HA. You can also encorporate it in existing activities, so up to a point you can see some things that you do with the remote.
However, there are only limited commands Harmony can send to the emulated roku, so you need to be creative.
