Detecting if my car is parked in the "right" spot
Sounds like a plan.
You could get away with just using a simple relay, so unless you want to control or track the status from home assistant it doesn’t necessarily need to be ESP-compatible.
I can definitely think of some uses in home assistant, just make sure the light is triggered by the relay or microcontroller itself to prevent latency.
Oldie but Goldie :trophy:
For your use case you probably need to adapt the setup a bit
I’ll go for this option. Indeed not ESP-compatible, but covers the user requirement. I could still decide to extend the solution to ESP, if I want to trigger more complex action in HA.
Thanks!
