Gas pressure regulator
Hello everyone,
I hope you’re well. :slight_smile:
Is someone found a gas pressure regulator that I connect to HA so I can monitor the gas pressure left on the cylinder ?
thanks
Best regards.
English please: How to help us help you - or How to ask a good question.
Something like this?
Thanks for your reply, appreciate it.
The kind of tank I have is like this and I’m unsure if your solution would work ?
I don’t know if it will work either but there are other potential solutions in that post including this and others.
You will have to do the research to see what solution is best for you.
Thanks a lot ! will dig this way, didn’t think about using ultrason to do the job… :slight_smile:
